Home » Archived » Visual Editor (VE) » Integration Build 20040825 available
Integration Build 20040825 available [message #57494] Wed, 25 August 2004 19:43 Go to next message
This driver is now available at
http://download.eclipse.org/tools/ve/downloads/drops/I-I2004 0825-200408251837/index.html
I just want to make everyone aware that this driver (and subsequent
drivers) will be built based on fairly recent Eclipse, EMF, and GEF
maintenance drivers. So please pay particular attention to the
Requirements list on the download page for each driver to ensure you
install the correct driver levels. The VE downloads page points directly
to the zips you will need. For example, in this driver you will need:
- Eclipse M20040818
- EMF M200408190924
- GEF M20040809
Also VE has changed to use EMF APIs that are in the latest EMF
maintenance driver and therefore will not work on previous EMF drivers.
The VE M2 (milestone 2) driver is still available for those that wish to
stay on Eclipse 3.0, EMF 2.0, and GEF 3.0.
Regards...
Peter Walker
Visual Editor Development
Re: Integration Build 20040825 available [message #57519 is a reply to message #57494] Thu, 26 August 2004 00:26 Go to previous messageGo to next message
What are requests for eclipse,emf and gef when download VEP from cvs HEAD ?
regards
> - Eclipse M20040818
> - EMF M200408190924
> - GEF M20040809
> Regards...
> Peter Walker
Re: Integration Build 20040825 available [message #57616 is a reply to message #57519] Thu, 26 August 2004 10:04 Go to previous message
This integration build is based on what is in the cvs HEAD for VEP. So if you
are setting up your development workspace, I would recommend going to the build
sites for Eclipse, EMF, and GEF... and getting their SDKs instead of the
runtimes for the build level in this VE driver. On the VE download page, their
is a link to each of these you can select to get to the respective build sites.
Regards...
Peter Walker
> regards
>>- Eclipse M20040818
>>- EMF M200408190924
>>- GEF M20040809
>>Regards...
>>Peter Walker
Re: Integration Build 20040825 available [message #597774 is a reply to message #57494] Thu, 26 August 2004 00:26 Go to previous message
regards
> - Eclipse M20040818
> - EMF M200408190924
> - GEF M20040809
> Regards...
> Peter Walker
Re: Integration Build 20040825 available [message #597807 is a reply to message #57519] Thu, 26 August 2004 10:04 Go to previous message
Regards...
Peter Walker
> regards
>>- Eclipse M20040818
>>- EMF M200408190924
>>- GEF M20040809
>>Regards...
>>Peter Walker
Previous Topic:Is there any easy way to disable the "visual nature"?
Next Topic:Eclipse VEP plugin not workingin my Fedora Core1
Current Time: Tue Jul 15 03:04:07 EDT 2025
Powered by FUDForum. Page generated in 0.30847 seconds
