Home » Language IDEs » AspectJ » is ajdt support all common jdt refactorings?
is ajdt support all common jdt refactorings? [message #57492] Mon, 17 October 2005 00:04 Go to next message
I'm using Eclipse 3.2M1 and latest AJDT 1.3.0 build available from
the update site.
I've tried to use some basic refactoring such as inline method from
within advice code (before or around) and got an error "compilation unit
must end with .java". Is it a bug or I am doing something wrong here?
Eugene
PS: here is the stack trace
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:327)
org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDia log2.run(RefactoringWizardDialog2.java:293)
org.eclipse.ltk.ui.refactoring.RefactoringWizard.internalPer formFinish(RefactoringWizard.java:547)
org.eclipse.ltk.ui.refactoring.UserInputWizardPage.performFi nish(UserInputWizardPage.java:153)
org.eclipse.ltk.ui.refactoring.RefactoringWizard.performFini sh(RefactoringWizard.java:613)
org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDia log2.okPressed(RefactoringWizardDialog2.java:417)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:4 09)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:868)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3137)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2765)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n$1.run(RefactoringWizardOpenOperation.java:125)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n.run(RefactoringWizardOpenOperation.java:138)
org.eclipse.jdt.internal.ui.refactoring.actions.RefactoringS tarter.activate(RefactoringStarter.java:40)
org.eclipse.jdt.internal.corext.refactoring.RefactoringExecu tionStarter.startInlineMethodRefactoring(RefactoringExecutio nStarter.java:255)
org.eclipse.jdt.internal.ui.refactoring.actions.InlineMethod Action.run(InlineMethodAction.java:133)
org.eclipse.jdt.internal.ui.refactoring.actions.InlineMethod Action.run(InlineMethodAction.java:126)
org.eclipse.jdt.internal.ui.refactoring.actions.InlineMethod Action.tryInlineMethod(InlineMethodAction.java:142)
at org.eclipse.jdt.ui.actions.InlineAction.run(InlineAction.jav a:114)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:226)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:198)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler. java:182)
org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execut e(LegacyHandlerWrapper.java:108)
at org.eclipse.core.commands.Command.execute(Command.java:311)
org.eclipse.core.commands.ParameterizedCommand.execute(Param eterizedCommand.java:396)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:459)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:781)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:828)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:550)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:493)
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:117)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:920 )
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:892)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:877)
at org.eclipse.swt.widgets.Control.traverse(Control.java:2794)
at org.eclipse.swt.widgets.Control.translateMnemonic(Control.ja va:2635)
at org.eclipse.swt.widgets.Composite.translateMnemonic(Composit e.java:854)
at org.eclipse.swt.widgets.Control.translateMnemonic(Control.ja va:2653)
at org.eclipse.swt.widgets.Display.translateMnemonic(Display.ja va:3571)
at org.eclipse.swt.widgets.Display.filterMessage(Display.java:9 34)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2761)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1734)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1698)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.IllegalArgumentException: Compilation unit name
must end with .java
org.eclipse.jdt.internal.core.PackageFragment.getCompilation Unit(PackageFragment.java:192)
org.eclipse.jdt.core.dom.TypeBinding.getCompilationUnit(Type Binding.java:128)
org.eclipse.jdt.core.dom.TypeBinding.getUnresolvedJavaElemen t(TypeBinding.java:438)
org.eclipse.jdt.core.dom.TypeBinding.getUnresolvedJavaElemen t(TypeBinding.java:377)
at org.eclipse.jdt.core.dom.TypeBinding.getJavaElement(TypeBind ing.java:370)
org.eclipse.jdt.core.dom.MethodBinding.getUnresolvedJavaElem ent(MethodBinding.java:168)
org.eclipse.jdt.core.dom.MethodBinding.getJavaElement(Method Binding.java:161)
org.eclipse.jdt.internal.corext.refactoring.code.TargetProvi der$MemberTypeTargetProvider.getAffectedCompilationUnits(Tar getProvider.java:366)
org.eclipse.jdt.internal.corext.refactoring.code.InlineMetho dRefactoring.checkFinalConditions(InlineMethodRefactoring.ja va:199)
org.eclipse.ltk.core.refactoring.CheckConditionsOperation.ru n(CheckConditionsOperation.java:84)
org.eclipse.ltk.core.refactoring.CreateChangeOperation.run(C reateChangeOperation.java:114)
org.eclipse.ltk.core.refactoring.PerformChangeOperation.run( PerformChangeOperation.java:189)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
org.eclipse.ltk.internal.ui.refactoring.WorkbenchRunnableAda pter.run(WorkbenchRunnableAdapter.java:86)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Root exception:
java.lang.IllegalArgumentException: Compilation unit name must end with
..java
Re: is ajdt support all common jdt refactorings? [message #57544 is a reply to message #57492] Mon, 17 October 2005 06:19 Go to previous messageGo to next message
Hi Eugene,
Yes this is a bug. AJDT has some support for editor functions such as
organise imports and code completion but no refactoring support at the
moment. If you want to raise a bug on bugzilla
(https://bugs.eclipse.org/bugs/enter_bug.cgi?product=AJDT) a general
refactoring bug would probably be the most useful.
Sian
Eugene Kuleshov wrote:
> I'm using Eclipse 3.2M1 and latest AJDT 1.3.0 build available from the
> update site.
> Thanks
> Eugene
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> must end with .java
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Root exception:
> .java
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: is ajdt support all common jdt refactorings? [message #57683 is a reply to message #57544] Mon, 17 October 2005 11:31 Go to previous message
Thanks Sian. The strange thing is that extract method refactoring
does work.
Anyway, here is bugzilla issue for this.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=112806
regards,
Eugene
Sian January wrote:
> Hi Eugene,
> Sian
>> the update site.
>> unit must end with .java". Is it a bug or I am doing something wrong
>> here?
>> Thanks
>> Eugene
Re: is ajdt support all common jdt refactorings? [message #590456 is a reply to message #57492] Mon, 17 October 2005 06:19 Go to previous message
Hi Eugene,
Sian
> update site.
> Thanks
> Eugene
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> must end with .java
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Root exception:
> .java
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: is ajdt support all common jdt refactorings? [message #590533 is a reply to message #57544] Mon, 17 October 2005 11:31 Go to previous message
does work.
regards,
Eugene
Sian January wrote:
> Hi Eugene,
> Sian
>> the update site.
>> here?
>> Thanks
>> Eugene
Previous Topic:Problem with Eclipse 3.0.2 and AJDT 1.2.1
Next Topic:AspectJ 5 M4
Current Time: Sat Jul 26 09:53:59 EDT 2025
Powered by FUDForum. Page generated in 0.08211 seconds
