Home » Archived » BIRT » Problem with BIRT script
Problem with BIRT script [message #57481] Wed, 13 July 2005 05:43 Go to next message
Hi;
A BIRT report developer uses the Mozilla Rhino JavaScript engine which
provides excellent integration with Java. This means all functionalities
of Mozilla Rhino JavaScript must work in BIRT. But when I try use the
functionality importPackage (e.g. importPackage(java.io)) in BIRT(1.0.1M1)
script I get the error “importPackge is undifined”.
Does somebody know why I get this error?
Thanks in advance,
Piet
Re: Problem with BIRT script [message #58695 is a reply to message #57481] Fri, 15 July 2005 02:23 Go to previous messageGo to next message
Try to use
importPackage(Packages.java.util);
instead of
importPackage(java.util);
for now.
Stanley Wang
BIRT Engine
S.Taaouati wrote:
> I?m trying to use ?importPackage? in birt version 1.0.1M1 but I get the
> following error:
> Error0 : data.engine.JSScriptInvalid(1 time)
> detail: Invalid Javascript expression. Source: DataSet:setScript.open,
> line: 0, Expression:
> function_prefix_1121238524940();function
> function_prefix_1121238524940(){importPackage(java.io)}
> Script engine error: ReferenceError: "importPackage" is not defined.
"Piet" <said.taaouati@remain.nl>
??????:be51f50d7154f6b5bc254e771eabced4$1@www.eclipse.org...
> Hi;
Re: Problem with BIRT script [message #59991 is a reply to message #58695] Tue, 19 July 2005 19:02 Go to previous message
Originally posted by: myname(with.between names).lombardisoftware.com
Are you sure BIRT adds the ImporterTopLevel class that defines importClass()
and importPackage() to its runtime?
it sounds from the error that the function is missing not that the parameter
is wrong.
Wang QS wrote:
> Try to use
> instead of
> for now.
> Stanley Wang
> BIRT Engine
>> the following error:
>> Hi;
>> BIRT(1.0.1M1) script I get the error
Previous Topic:html preview ?
Next Topic:Problem with Data Set (Oracle DB)
Current Time: Wed Jul 09 08:19:43 EDT 2025
Powered by FUDForum. Page generated in 0.03322 seconds
