Home » Archived » Visual Editor (VE) » Eclipse VEP plugin not workingin my Fedora Core1
Eclipse VEP plugin not workingin my Fedora Core1 [message #57468] |
Wed, 25 August 2004 19:01  |
Originally posted by: pablopesb.yahoo.com
Hi there,
I have already posted this message in the Visual Editor
Developers mailing list. I tried following people's advice, but still got
the same awfull result. Well, here is my problem:
"I am completely new to Eclipse and Java
programming. I need to use Java in my final degree
project. That is why I checked for free sdks available
and found all these great reviews about eclipse.
So, I installed eclipse 2.1-3 and 3.0 on my "FEDORA
CORE 1 machine", and they both worked just fine. My machine
has j2sdk1.4.2_04 installed on it.
Then, I tried to install the Visual Editor Pluging
(VEP 0.5). I've downloaded and unzipped GEF, emf and
VEP zip files into the eclipse directories, for both
versions of eclipse (2.1-3 and 3.0).
But, for both versions I get the same error dialog
boxes when I try to open the Visual Editor:
Visual Editor for Java Error
Error trying to set new file into editor.
Reason:
Errors Running Operations
Create Remove VM for Visual Editor for Java (Error: An
internal error ocurred during: "Create Remove VM for
Visual Editor for Java")
org.eclipse.jem.internal.proxy.remote.REMRegistryController. getMasterSocketPort(REMRegistryController.java:172)
So, after I've read people's advice on the mailing list. They told me to
download and unzip the following files:
eclipse-SDK-3.0-linux-gtk.zip
emf-sdo-runtime-2.0.0.zip
emf-sd0-xsd-SDK-2.0.0.zip
xsd-runtime-2.0.0.zip
GEF-SDK-3.0.zip
GEF-examples-3.0.zip
GEF-Automated-Tests-3.0.zip
VE-runtime-1.0M2.zip
I did it, but I got the same awfull result.
Please, somebody help me. I also tried the Netbeans SDK, but I did not
find it as intuitive as eclipse. Besides, everybody says that eclipse is
the real deal, so I would really like to start using it. I am delaying my
final degree project development because of this.
Thanks in advance,
Pablo Salinas
Re: Eclipse VEP plugin not workingin my Fedora Core1 [message #57543 is a reply to message #57468] |
Thu, 26 August 2004 01:32   |
Pablo,
You try first delete configuration directory in ECLIPSE_HOME
or start eclipse with -clean
If it don't help thet check double where are plugins and features
from emf,gef and vep installed - They have to be in plugins and features
directory in eclipse home (is there dirs like
org.eclipse.emf..., org.eclipse.gef..., org.eclipse.ve... in both dirs)
regards
Pablo Salinas wrote:
> Hi there,
> Reason:
> java.lang.NullPointerException
> GEF-SDK-3.0.zip
> Thanks in advance,
> Pablo Salinas
Re: Eclipse VEP plugin not workingin my Fedora Core1 [message #57641 is a reply to message #57468] |
Thu, 26 August 2004 11:15  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Are there any other messages in the .log file? The only way that NPE
could occur was because we couldn't start a ServerSocket connection. And
if we couldn't start such a connection there should of been a stacktrace
in the .log telling us why we couldn't.
Thanks, Rich Kulp
Re: Eclipse VEP plugin not workingin my Fedora Core1 [message #597783 is a reply to message #57468] |
Pablo,
regards
> Hi there,
> Reason:
> GEF-SDK-3.0.zip
> Thanks in advance,
> Pablo Salinas
Re: Eclipse VEP plugin not workingin my Fedora Core1 [message #597813 is a reply to message #57468] |
Thanks, Rich Kulp
Current Time: Tue Jul 15 05:30:54 EDT 2025
Powered by FUDForum. Page generated in 0.11387 seconds
