Home » Eclipse Projects » Plugin Development Environment (PDE) » Headless RCP Product Export
Headless RCP Product Export [message #57460] Tue, 21 April 2009 15:11 Go to next message
I have managed to get a headless build working using many online
references. The output is not what I get when I use the Eclipse Product
Export Wizard manually inside the Eclipse SDK.
How do I get the same shippable product in a headless way?
Thanks!
Re: Headless RCP Product Export [message #57508 is a reply to message #57460] Tue, 21 April 2009 15:31 Go to previous messageGo to next message
On Tue, 21 Apr 2009 19:11:50 +0000, Dilton McGowan II wrote:
> Thanks!
Never mind, I just noticed the I.TestBuild directory. The zipped versions
of the product are located there.
Re: Headless RCP Product Export [message #57534 is a reply to message #57508] Tue, 21 April 2009 17:24 Go to previous messageGo to next message
For reference, it is named I.TestBuild because by default, the location
of the resulting archives is ${buildDirectory}/${buildLabel}. If you
look at the build.properties for your builder you will see the default
value:
buildLabel = ${buildType}.${buildId}
buildType=I
buildId=TestBuild
-Andrew
>> Thanks!
> Thanks
Re: Headless RCP Product Export [message #57585 is a reply to message #57534] Tue, 21 April 2009 19:47 Go to previous message
Originally posted by: n.n.nnn
>> versions of the product are located there.
>> Thanks
> value:
> buildType=I
> buildId=TestBuild
I'd not edited that part from the original and overlooked it.
Thanks for pointing it out Andrew.
Re: Headless RCP Product Export [message #596030 is a reply to message #57460] Tue, 21 April 2009 15:31 Go to previous message
> Thanks!
Re: Headless RCP Product Export [message #596038 is a reply to message #57508] Tue, 21 April 2009 17:24 Go to previous message
value:
buildType=I
buildId=TestBuild
-Andrew
>> Thanks!
> Thanks
Re: Headless RCP Product Export [message #596057 is a reply to message #57534] Tue, 21 April 2009 19:47 Go to previous message
>> Thanks
> value:
> buildType=I
> buildId=TestBuild
Previous Topic:Headless build not adding jars from binary plug-ins to build path?
Next Topic:Invalid access restriction error?
Current Time: Tue Jul 08 08:20:01 EDT 2025
Powered by FUDForum. Page generated in 0.03532 seconds
