Headless RCP Product Export [message #57460] |
Tue, 21 April 2009 15:11  |
I have managed to get a headless build working using many online
references. The output is not what I get when I use the Eclipse Product
Export Wizard manually inside the Eclipse SDK.
How do I get the same shippable product in a headless way?
Thanks!
Re: Headless RCP Product Export [message #57585 is a reply to message #57534] |
Tue, 21 April 2009 19:47  |
Originally posted by: n.n.nnn
On Tue, 21 Apr 2009 17:24:14 -0400, Andrew Niefer wrote:
>> Never mind, I just noticed the I.TestBuild directory. The zipped
>> versions of the product are located there.
>> Thanks
> For reference, it is named I.TestBuild because by default, the location
> of the resulting archives is ${buildDirectory}/${buildLabel}. If you
> look at the build.properties for your builder you will see the default
> value:
> buildLabel = ${buildType}.${buildId}
> buildType=I
> buildId=TestBuild
I'd not edited that part from the original and overlooked it.
Thanks for pointing it out Andrew.
Re: Headless RCP Product Export [message #596030 is a reply to message #57460] |
Tue, 21 April 2009 15:31  |
On Tue, 21 Apr 2009 19:11:50 +0000, Dilton McGowan II wrote:
> Thanks!
Never mind, I just noticed the I.TestBuild directory. The zipped versions
Re: Headless RCP Product Export [message #596038 is a reply to message #57508] |
Tue, 21 April 2009 17:24  |
value:
buildType=I
buildId=TestBuild
-Andrew
>> Thanks!
> Thanks
Re: Headless RCP Product Export [message #596057 is a reply to message #57534] |
>> Thanks
> value:
> buildType=I
> buildId=TestBuild
FUDForum. Page generated in 0.05840 seconds
