Error while trying to get tables from a MySQL database [message #57457] |
Fri, 24 July 2009 09:59  |
Hi.
I encountered an error while trying to get the tables from a MySQL
database. More precisely, when I select the "Tables" folder of my MySQL
connection in the Data Source Explorer.
I created a MySQL profile connection, and I tested it with two versions
of a MySQL JDBC driver (mysql-connector-5.0.8 and 5.1.7). I got the same
error in the two cases. The database I'm using for tests was also used
with Talend (so, I know the problem is not on the database - and Talend
is not running at the same time).
I assume the error could be in the way I defined my connection (I don't
think it is a bug - I checked the DTP bugzilla and did not find it).
The exception I got is:
> java.sql.SQLException: An exception occurred invoking java.sql.DatabaseMetaData.getTables().
> at org.eclipse.datatools.enablement.mysql.catalog.loaders.MySql TableLoader.createResultSet(MySqlTableLoader.java:155)
> at org.eclipse.datatools.enablement.mysql.catalog.loaders.MySql TableLoader.loadTables(MySqlTableLoader.java:82)
> at org.eclipse.datatools.connectivity.sqm.core.rte.jdbc.JDBCSch ema.loadTables(JDBCSchema.java:128)
> at org.eclipse.datatools.connectivity.sqm.core.rte.jdbc.JDBCSch ema.getTables(JDBCSchema.java:89)
> at org.eclipse.datatools.modelbase.sql.schema.impl.SchemaImpl.e Get(SchemaImpl.java:597)
> at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1013)
> at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1005)
> at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1000)
> at org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.vnode.ServerExplorerVNodeCon tentProviderNav.getSchemaChildren(ServerExplorerVNodeContent ProviderNav.java:250)
> at org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.vnode.ServerExplorerVNodeCon tentProviderNav.displayTableNodeChildren(ServerExplorerVNode ContentProviderNav.java:187)
> at org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.AbstractOnDemandContentProvi derNav.getChildren(AbstractOnDemandContentProviderNav.java:1 73)
> at org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.AbstractOnDemandContentProvi derNav.getChildren(AbstractOnDemandContentProviderNav.java:2 43)
> at org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.AbstractLayoutProviderNav.ge tChildren(AbstractLayoutProviderNav.java:85)
> at org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.impl.ServerExplorerContentProviderN av.load(ServerExplorerContentProviderNav.java:153)
> at org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.loading.LoadingJob.run(LoadingJob.java:43)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by: java.lang.NullPointerException
> at org.eclipse.datatools.enablement.mysql.catalog.loaders.MySql TableLoader.createResultSet(MySqlTableLoader.java:145)
> ... 15 more
I put some breakpoints and I found that the exception occurs in
MySqlTableLoader, in the following lines:
> String catalogName = getCatalogObject().getConnection().getCatalog();
> if(catalogName == null || catalogName.trim().length() == 0){
> getCatalogObject().getConnection().setCatalog(getSchema().ge tCatalog().getName());
More exactly, the "getSchema().getCatalog()" returns "null" (catalogName
Does anyone know why this error is thrown?
Are there some properties to define or limitations on the JDBC drivers
we can use with DTP? I precise that this database and these drivers were
working with DTP on Ganymede.
Vincent.
Vincent Zurczak
EBM WebSourcing
Re: Error while trying to get tables from a MySQL database [message #257188 is a reply to message #57457] |
Mon, 27 July 2009 17:23  |
Hi Vincent...
Please log a bugzilla and we'll try and get this resolved for 1.7.1.
--Fitz
Re: Error while trying to get tables from a MySQL database [message #596149 is a reply to message #57457] |
Hi Vincent...
--Fitz
FUDForum. Page generated in 0.03963 seconds
