Home » Eclipse Projects » JFace » problem creating tableviewer on the wizardpage
problem creating tableviewer on the wizardpage [message #5119] |
Thu, 14 May 2009 13:51  |
I was trying to create a TableViewer on the WizardPage , I am setting the
input, content provider and label provider correctly, but It doesnt
render tableviewer on the wizardpage, do I need to do anything else.
thanks in advance
Manohar
Re: problem creating tableviewer on the wizardpage [message #6284 is a reply to message #6123] |
Sun, 17 May 2009 17:45   |
thanks Boris for the information.
I still dont see the table on the wizard page.
If you have some time, can you please see the code, coz I am not sure
what I am doing wrong.
thanks in advance
Manohar
package com.test;
import org.eclipse.jface.layout.GridLayoutFactory;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.ITableLabelProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.jface.wizard.WizardPage;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
* This page collects the first and last names
class JSFPreviewPage extends WizardPage {
* NamePage constructor
public JSFPreviewPage() {
super("JSF Preview Page", "JSF Preview Page", null);
setDescription("Layout of JSF Components");
* Creates the page contents
* @param parent
* the parent composite
public void createControl(Composite parent) {
Composite composite = new Composite(parent, SWT.NONE);
composite.setLayout(new GridLayout(2, false));
final TableViewer viewer = new TableViewer(composite);
viewer.setLabelProvider(new MyLabelProvider());
viewer.setContentProvider(new MyContentProvider());
MyModel[] model = createModel();
viewer.setInput(model);
// Set up the table
Table table = viewer.getTable();
new TableColumn(table, SWT.LEFT).setText("Items");
new TableColumn(table, SWT.LEFT).setText("Name");
viewer.getTable().setLinesVisible(true);
viewer.getTable().setHeaderVisible(true);
GridLayoutFactory.swtDefaults().generateLayout(composite) ;
setControl(composite);
public class MyLabelProvider extends LabelProvider implements
ITableLabelProvider
public String getColumnText(Object element, int columnIndex) {
MyModel person = (MyModel) element;
switch (columnIndex) {
case 0:
return person.getCounter() + "";
case 1:
return person.getName();
default:
throw new RuntimeException("Should not happen");
public Image getColumnImage(Object arg0, int arg1) {
// TODO Auto-generated method stub
return null;
private class MyContentProvider implements IStructuredContentProvider {
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.IStructuredContentProvider#getElem ents(java.lang.Object)
public Object[] getElements(Object inputElement) {
return (MyModel[]) inputElement;
/* (non-Javadoc)
* @see org.eclipse.jface.viewers.IContentProvider#dispose()
public void dispose() {
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.IContentProvider#inputChanged(org. eclipse.jface.viewers.Viewer,
java.lang.Object, java.lang.Object)
public void inputChanged(Viewer viewer, Object oldInput, Object
newInput) {
public class MyModel {
public int counter;
public String name;
public MyModel(int counter , String name) {
this.counter = counter;
this.name = name;
public int getCounter() {
return counter;
public void setCounter(int counter) {
public String getName() {
return name;
public void setName(String name) {
this.name = name;
public String toString() {
return "Item " + this.counter;
private MyModel[] createModel() {
MyModel[] elements = new MyModel[10];
for (int i = 0; i < 10; i++) {
elements[i] = new MyModel(i, "name");
return elements;
Re: problem creating tableviewer on the wizardpage [message #6299 is a reply to message #6284] |
Sun, 17 May 2009 22:36   |
Hi Manohar,
I am seeing a table, just no contents, and no table headers. I should have
asked you to attach a screenshot...
Here is what's missing:
TableColumn c1 = new TableColumn(table, SWT.LEFT);
c1.setText("Items");
c1.setWidth(100);
Boris
"Manohar " <manohar.babu@gmail.com> wrote in message
news:16624751fe1a0abe633750818a20a00a$1@www.eclipse.org...
> thanks in advance
> Manohar
> package com.test;
> * * @param parent
> // Set up the table
> ITableLabelProvider {
> case 0:
> case 1:
> return person.getName(); default:
> return null;
> /* (non-Javadoc)
> * @see
> /* (non-Javadoc)
> /* (non-Javadoc)
> * @see
> public void inputChanged(Viewer viewer, Object oldInput, Object newInput)
> public int counter;
> public String name;
> this.name = name;
> return counter;
> return name;
> this.name = name;
> return elements;
Current Time: Sun Aug 31 15:11:11 EDT 2025
Powered by FUDForum. Page generated in 0.03971 seconds
