Home » Language IDEs » ServerTools (WTP) » Where is the XML editor?
Where is the XML editor? [message #57429] |
Thu, 23 December 2004 06:37  |
Hello everyone,
I've just installed the brand new WTP M2 on top of Eclipse 3.1 M4
running on Windows XP SP2. I also followed the instructions for XML
validation (installing Xerces 2.6.2).
Unfortunately I can't find the XML editor/validator. XML files (and
HTML/HTM/GIF/JPG) now open in the internal Web Browser, which is not
very helpful.
I searched every menu, perspective and project type. The only new XML
related entry I could find is the new "XML Catalog" preferences page. I
uninstalled WTP M1 for a similar problem, but this time the XML editor
is part of the High Priority items on the milestone plan
( http://www.eclipse.org/webtools/downloads.html#milestonebuil dnotes).
Andreas
Re: Where is the XML editor? [message #58031 is a reply to message #57935] |
Fri, 24 December 2004 04:56   |
>> I uninstalled WTP M1 for a similar problem, but this time the XML
>> editor is part of the High Priority items on the milestone plan
> Andreas, it could be that in your workspaces the 'default' editor has
> been configured to be the web browser. I'd suggest right clicking on an
> XML file in the navigator view and seeing if the 'Open With...' option
> lists the XML editor as an available editor.
"Open with..." does not list the XML editor.
> If not I'd suspect that the
> plugins didn't get unzipped correctly (perhaps you ran out of disk
> space... I know I've done that before :-)
I just cross-checked and installed Eclipse from scratch. I made sure
that I have at least 1 GB free on my drive, then I unpacked
eclipse-SDK-3.1M4-win32.zip 90,0 MB (94.433.804 bytes) and
wtp-1.0M2.zip 15,3 MB (16.054.198 bytes)
and installed in the WTP as usual.
Again, Eclipse claims that the WTP is installed (Manage
Configuration...) but no XML/JSP anything is available. There is no
other Eclipse plugin installed.
My Eclipse .log:
!SESSION 2004-12-24 10:47:34.739
eclipse.buildId=I20041216-2000
java.version=1.5.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2004-12-24 10:47:34.739
!MESSAGE Invalid preference page path: XML Catalog
Andreas
Re: Where is the XML editor? (solved) [message #58331 is a reply to message #58129] |
Fri, 24 December 2004 13:23   |
On Fri, 24 Dec 2004 13:14:00 +0100, Andreas Schildbach <andreas@schildbach.de> wrote:
> I finally managed to solve my problem: I forgot to install some of the prerequisites listed on http://download.eclipse.org/webtools/downloads/drops/
> S-1.0M2-200412230036/index.html
>Eclipse/WTP should check that all required plugins are installed instead of silently "failing". If nobody as any objections, I will file a bug
> report/feature request about this.
Be sure to check your .log file (in the <workspace>/.metadata directory. There should have been errors listed there saying which plugins were disable due to missing pre-reqs.
We probably could, in theory, improve some of the error messages, but in general, not sure how much we can do (other than log the warnings).
Once we get "update manager" function supported, this will be easier, and it will report errors or "need" for other plugins/features.
Thanks for persisting with these early versions.
Re: Where is the XML editor? [message #58377 is a reply to message #58157] |
Fri, 24 December 2004 13:36  |
Dim Dimych wrote:
>> I have no other XML related plugins installed. Only Subclipse and
>> RegexTester. I cross-checked with a fresh installation without any extra
>> plugins - the problem prevails.
> Hmm... Even can't tell you what's wrong. I'd just told you my experience
> with similar problem. Removing extra XML editors had cured this. Then I
> can only join to Craig's advice to check if you extracted wtp-1.0M2.zip
> correctly. Traverse the 'features' and 'plugins' directories for
> 'eclipse' folder. If you're able to see it then file unzipped in wrong
> place. This is very common error because Eclipse guys like to cook their
> distros putting the 'eclipse' folder into archive.
>> I did this already. Even without the Xerces jars the XML editor should
>> appear in "Open with...", does it?
> Yes, you're perfectly right. There must be actually even three items:
> Web Browser, XML Editor, and XML Source Page Editor.
> Sorry pal, that's all I could made for you. Perhaps, Craig would be of
> assistance.
> Cheers,
> Dim Dimych
Andreas,
Just to make sure... did you unzip the dependencies required for wtp (EMF,
GEF, JEM) as listed on the download page [1]?
[1]
http://download.eclipse.org/webtools/downloads/drops/S-1.0M2 -200412230036/index.html
Current Time: Sat Jul 26 18:39:52 EDT 2025
Powered by FUDForum. Page generated in 0.31816 seconds
