Home » Language IDEs » AspectJ » AspectJ 5 M4
AspectJ 5 M4 [message #57367] Tue, 11 October 2005 12:00 Go to next message
The latest AspectJ milestone release is now included in AJDT development
builds.
Please see the New Features page for more details:
http://www.eclipse.org/ajdt/newfeatures/#compilerM4
Matt
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: AspectJ 5 M4 [message #57417 is a reply to message #57367] Thu, 13 October 2005 18:18 Go to previous messageGo to next message
AspectJ 5 M4 is now also included in the early development build for
Eclipse 3.2M2:
http://www.eclipse.org/ajdt/downloads/#dev
The build id is: "1.3.0.20051013194900 for Eclipse 3.2M2" (zip file only).
Matt.
Re: AspectJ 5 M4 [message #57518 is a reply to message #57417] Mon, 17 October 2005 00:27 Go to previous messageGo to next message
Matt,
Is there are any plans to provide an update site for this branch?
I've tried to manually install one of the latest builds on 3.2M2 but
it didn't worked. Feature appeared in the about dialog, but none of the
ajdt actions and menus are there.
regards,
Eugene
> Eclipse 3.2M2:
> Matt.
Re: AspectJ 5 M4 [message #57596 is a reply to message #57518] Mon, 17 October 2005 09:07 Go to previous messageGo to next message
Hi Eugene,
There will be an update site available for Eclipse 3.2 in the not too
distant future but it will be after our 1.2.1 and 1.3 AJDT releases,
which are both due in the next month or so.
I have sometimes seen the problem you described below. You might want
to try deleting all the AJDT plug-ins and the AspectJ feature from the
plugins and features directories respectively and then re-installing
them. Otherwise a fresh install of Eclipse may work.
Sian
Eugene Kuleshov wrote:
> Matt,
> regards,
> Eugene
>> Eclipse 3.2M2:
>> only).
>> Regards,
>> Matt.
Re: AspectJ 5 M4 [message #57709 is a reply to message #57596] Mon, 17 October 2005 11:37 Go to previous message
Sian,
I did delete previous AJDT plugins and features before installing
this one and this plugin was the only AJDT verion I had at that point.
Unfortunately I can't afford to reinstall Eclipse or even use
different workspace, which means that I have to stay on Eclipse 3.2M1.
Too bad. :-(
By the way, it would be easier if all these different AJDT streams
would have the same update site. I believe Mylar's update site is done
this way.
regards,
Eugene
Sian January wrote:
> Hi Eugene,
> Sian
>> Matt,
>> the ajdt actions and menus are there.
>> regards,
>> Eugene
>>> Eclipse 3.2M2:
>>> only).
>>> Regards,
>>> Matt.
Re: AspectJ 5 M4 [message #590382 is a reply to message #57367] Thu, 13 October 2005 18:18 Go to previous message
Eclipse 3.2M2:
Matt.
Re: AspectJ 5 M4 [message #590445 is a reply to message #57417] Mon, 17 October 2005 00:27 Go to previous message
Matt,
regards,
Eugene
> Eclipse 3.2M2:
> Matt.
Re: AspectJ 5 M4 [message #590479 is a reply to message #57518] Mon, 17 October 2005 09:07 Go to previous message
Hi Eugene,
Sian
> Matt,
> regards,
> Eugene
>> Eclipse 3.2M2:
>> only).
>> Regards,
>> Matt.
Re: AspectJ 5 M4 [message #590542 is a reply to message #57596] Mon, 17 October 2005 11:37 Go to previous message
Sian,
Too bad. :-(
this way.
regards,
Eugene
Sian January wrote:
> Hi Eugene,
> Sian
>> Matt,
>> regards,
>> Eugene
>>> Eclipse 3.2M2:
>>> only).
>>> Regards,
>>> Matt.
Previous Topic:is ajdt support all common jdt refactorings?
Next Topic:Generating an update site with AJDT plug-in
Current Time: Sun Jul 06 09:28:30 EDT 2025
Powered by FUDForum. Page generated in 0.03700 seconds
