Error in exported product log [message #57329] |
Tue, 21 April 2009 09:47  |
Hi!
This is x-posted from .equinox, in the hope that you guys might know more
I'm seeing this error in the log of my exported product:
java.io.IOException: Unable to initialize osgi.frameworkClassPath
at org.eclipse.core.launcher.Main.addBaseJars(Main.java:567)
at org.eclipse.core.launcher.Main.getDevPath(Main.java:466)
I solved it using the solution given here:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg12468.html
It says:
- Copy the org.eclipse.osgi_vernum.jar from the
plugins/org.eclipse.osgi_vernum directory to the plugins directory
- Delete the org.eclipse.osgi_vernum directory
- Launch the application
So this has solved my problem, but I haven't figured out _why_ I need to
do this. Is there something I can do to prevent it on the Eclipse GUI
side, so it doesn't happen if I'm exporting to a new product?
Thanks!
Maurice
Re: Error in exported product log [message #57658 is a reply to message #57356] |
Wed, 22 April 2009 07:19  |
This was indeed the issue. It's working perfectly now - thanks for your
help!
Maurice
Andrew Niefer wrote:
> It is probably caused by having org.eclipse.osgi imported into your
> workspace as a binary project.
> Try doing the export after closing all such imported binary projects.
> You don't need to have them in your workspace, it is enough that they
> are in your target.
> This would be a bug in the export, but the problem is that from the
> shape of the project, build can't tell that this is a spoofed up bundle
> created by the import and not the real binary bundle.
> Maurice O'Connor wrote:
>> Hi!
>> more :)
>> It says:
>> Thanks!
>> Maurice
Re: Error in exported product log [message #595977 is a reply to message #57329] |
Tue, 21 April 2009 11:58  |
are in your target.
> Hi!
> more :)
> It says:
> Thanks!
> Maurice
Re: Error in exported product log [message #596083 is a reply to message #57356] |
help!
Maurice
> are in your target.
>> Hi!
>> more :)
>> It says:
>> Thanks!
>> Maurice
FUDForum. Page generated in 0.03292 seconds
