Home » Language IDEs » C / C++ IDE (CDT) » C++ Make
C++ Make [message #57324] Wed, 08 January 2003 16:54 Go to next message
Originally posted by: mcgahan.huntsville.sparta.com
I am having difficulty getting the "Make" to work in the C++ project. I
notice a box flashes on the screen rather rapidly stating "invoking
command: c:\cgwin\bin\make". Unfortunately my cygwin is installed in the
c:\cygwin path. Yes, I can rename the path and it works, but I would like
to now how to change the path eclipse is searching for make.
thanks,
mike
Re: C++ Make [message #57504 is a reply to message #57324] Thu, 09 January 2003 07:50 Go to previous messageGo to next message
Originally posted by: mhu.gft.com
You have to change the Build Command.
Right click your project -> Properties -> C/C++ project -> Build Settings
Now insert in the Build Command Box c:\cygwin\bin\make -f makefile
Greetings Martin
> thanks,
> mike
Re: C++ Make - Thanks [message #57529 is a reply to message #57504] Thu, 09 January 2003 08:18 Go to previous messageGo to next message
Looked every where, so I thought. Thanks for the help. Your response
solved my problem.
thanks,
mike
> Greetings Martin
> > thanks,
> > mike
Re: C++ Make [message #57553 is a reply to message #57324] Thu, 09 January 2003 12:19 Go to previous message
FYI,
This is coverered ... for Windows in the User FAQ.
www.eclipse.org/cdt
Select User FAQ
Select Building C/C++ Projects
Although the only entry is for Windows this portion of the FAQ is true for
all platforms.
-Judy
"Michael McGahan" <mcgahan@huntsville.sparta.com> wrote in message
news:avi6m2$a3t$1@rogue.oti.com...
| thanks,
| mike
Previous Topic:autoconf and automake integration
Next Topic:CDT Debugging
Current Time: Tue Jul 22 01:36:06 EDT 2025
Powered by FUDForum. Page generated in 0.03945 seconds
