Home » Archived » BIRT » Mailing Labels with BIRT?
Mailing Labels with BIRT? [message #57305] Wed, 13 July 2005 04:08 Go to next message
Hi there, I'm new to new to BIRT and Eclipse. My company is trying to
move away from an ms access based system to a more web based one.
BIRT seems to be a great way of doing the reporting side which we do
rely on.
One thing we need to be able to do is to create mailing labels with
addresses lifted from the database.
What I'm trying to do is have a two column layout for the labels, going:
1 | 2
3 | 4
etc
I've tried putting two tables in a two column grid, but then I get
1 | 1
2 | 2
What's the best way of laying out the report to get labels in the order
I want?
If this can be accomplished with BIRT, then it would be fantastic. We
are slowly replacing access forms with asp front ends, and if we can use
BIRT for reports and mailing labels is would be a great help.
I would be grateful for any suggestions you may have.
Re: Mailing Labels with BIRT? [message #57431 is a reply to message #57305] Wed, 13 July 2005 05:32 Go to previous messageGo to next message
Originally posted by: none.none.com
Hi Alan,
The way to do this is to create a list, bind it to your dataset. Then inside
the list, create a single-cell grid, resize it so you can have several of
them on the same line (in your example 2) and set its Section/Display
property to Inline. The grid should not be bound to the dataset, since it
will use the dataset of the list.
I am attaching a sample report demonstrating this kind of mailing labels
reports with the sample database. I created it with BIRT 1.0
David
"Alan" <Alan@urdd.org> wrote in message
news:db2i4q$j1h$1@news.eclipse.org...
> rely on.
> 1 | 2
> 3 | 4
> etc
> 1 | 1
> 2 | 2
> I want?
Re: Mailing Labels with BIRT? [message #57560 is a reply to message #57431] Wed, 13 July 2005 09:47 Go to previous messageGo to next message
Thanks for your help
That seems to have don the trick.
The only problems I have now is that while it looks fine in the preview,
it dose not look the same in the viewer - I'm getting 4 columns, and
when I generate a PDF it reverts to being one column again.
Also, there are some fields in my database that can be blank e.g. village
when i do
row["Village"] + ", " + row["Town"]
in some cases I'm getting
null, Manchester
Is there any way of removing the nulls?
Any help with these 2 issues would be appreciated
David Michonneau wrote:
> Hi Alan,
> David
>>rely on.
>>1 | 2
>>3 | 4
>>etc
>>1 | 1
>>2 | 2
>>I want?
Re: Mailing Labels with BIRT? [message #57610 is a reply to message #57560] Wed, 13 July 2005 10:07 Go to previous messageGo to next message
Alan,
For the PDF issue please file a bugzilla entry describing the issue, so we
can fix it.
For the viewer issue, the number of columns depend on the size of the
viewer. The preview uses the same size you mention in the masterpage (by
default US Letter). So if you try to print on US letter paper, you should
get the number of columns you saw in the preview.
Regarding the null values, you can change your expression like this:
if (row["Village"] == null )
row["Town"]
else
row["Village"] + ", " +row["Town"]
David
news:db361s$d4k$1@news.eclipse.org...
> it dose not look the same in the viewer - I'm getting 4 columns, and when
> when i do
> null, Manchester
>> Hi Alan,
>> inside the list, create a single-cell grid, resize it so you can have
>> several of them on the same line (in your example 2) and set its
>> Section/Display property to Inline. The grid should not be bound to the
>> dataset, since it will use the dataset of the list.
>> Thanks,
>> David
>>>rely on.
>>>1 | 2
>>>3 | 4
>>>etc
>>>1 | 1
>>>2 | 2
>>>I want?
Re: Mailing Labels with BIRT? [message #58770 is a reply to message #57610] Fri, 15 July 2005 04:02 Go to previous messageGo to next message
I filed a bug report on the PDF formatting problems, the reply was as
follows
------- FOP does not support "fo:inline-container" so that we are not
able to make a table/grid inline. Postpone this bug to BIRT 2.0 in which
we will create a PDF writer of our own.
Is there another way I can lay out labels, that the PDF exporter will
support?
Any suggestions would be appreciated
> Alan,
> can fix it.
> row["Town"]
> else
> David
>>when i do
>>null, Manchester
>>>Hi Alan,
>>>Thanks,
>>>David
>>>>rely on.
>>>>1 | 2
>>>>3 | 4
>>>>etc
>>>>1 | 1
>>>>2 | 2
>>>>I want?
Re: Mailing Labels with BIRT? [message #59144 is a reply to message #58770] Fri, 15 July 2005 12:04 Go to previous message
Alan,
Thank you for submitting this bug. I suggest you input your comments
directly in the bugzilla entry.
Unfortunately I don't know any workaround to lay out the labels this way in
PDF.
David
news:db7qim$iaq$1@news.eclipse.org...
>follows
> ------- FOP does not support "fo:inline-container" so that we are not able
> to make a table/grid inline. Postpone this bug to BIRT 2.0 in which we
> support?
> Thanks
>> Alan,
>> we can fix it.
>> row["Town"]
>> else
>> Thanks,
>> David
>>>when i do
>>>null, Manchester
>>>>Hi Alan,
>>>>Thanks,
>>>>David
>>>>>rely on.
>>>>>going:
>>>>>1 | 2
>>>>>3 | 4
>>>>>etc
>>>>>1 | 1
>>>>>2 | 2
>>>>>I want?
>>>>>use
Previous Topic:Log File For my Previous Mail
Next Topic:BIRT API
Current Time: Mon Jul 07 08:41:01 EDT 2025
Powered by FUDForum. Page generated in 0.05473 seconds
