[Hutn] problem and a general question [message #568274] |
Tue, 19 May 2009 13:48 |
Nikos Mising name Messages: 11 Registered: July 2009 |
Junior Member |
Dear all,
I have a problem instantiating a model using hutn. I follow the procedure
specified in http://www.eclipse.org/gmt/epsilon/cinema/HUTN.htm but I get
the following error:
org.eclipse.epsilon.hutn.exceptions.HutnGenerationException: Called
feature owner on undefined object (157:102)
Can you understand the nature of the problem? I have registered the
EPackage and added the Hutn nature to my project.
My reason for using Hutn is that I have a mathematical formula that I want
to transform to a model whose metamodel has been defined with ecore. I
plan to use Java to transform the formula to Hutn format and then get the
model. Is there a more practical way for my T2M transformation?
Thank you in advance,
Nikos
FUDForum. Page generated in 0.02811 seconds
