Query on multipackages metamodel [message #568200] |
Wed, 22 February 2006 10:40 |
No real name Messages: 29 Registered: July 2009 |
Junior Member |
Dear all,
i'm trying to use the OCL/QUERY plugins functionality in order to create
ocl query working on a metamodel defined with multiple packages, i.e
pkg 1
-- pkg 2
-- pkg 3
-- pkg4
but i haven't found a way to make things works when the ocl expression use
attributes (or features) of elements defined into different packages (i.e
starting from an object defined into pkg2 look for all the related object
defined into pkg4 using some attributes defined into pkg3...)
It seems to me that all provided example works on models defined with just
one package, whats the proper way to make the query works even in the
general case?
The same problem applys for the VALIDATION plugin too when it is time to
define which package an (ocl) constraint works on in the plugin.xml file...
Any help will be appreciated.
Best regards
FUDForum. Page generated in 0.03012 seconds
