Home » Language IDEs » Java Development Tools (JDT) » -> PDE JUnit
-> PDE JUnit [message #57211] Fri, 13 June 2003 18:12 Go to next message
Hi there,
just wanna ask if someone uses JUnit for Plugintesting. I got the
plugin but dont know where to look for documentation. I dont know
how to set up any testcases for plugin testing... .
So how does it work?
Martin (Kersten)
Re: -> PDE JUnit [message #57240 is a reply to message #57211] Fri, 13 June 2003 18:18 Go to previous messageGo to next message
Originally posted by: adam.kiezun.gmx.net.remove
i do
see how org.eclipse.jdt.ui.tests and org.eclipse.jdt.ui.refactoring.tests do it
a.
eclipse.org
Re: -> PDE JUnit [message #61455 is a reply to message #57211] Thu, 19 June 2003 03:28 Go to previous messageGo to next message
Originally posted by: me.home.com
Martin,
Kent Beck and Erich Gamma are writing a book "Contributing to Eclipse" where
they use the plugin for their unit tests
You might want to check it out (it is still a draft though), you can find it
at :
http://groups.yahoo.com/group/contributingtoeclipse/files/
Wim.
"Martin Kersten" <Martin.Kersten@student.uni-magdeburg.de> wrote in message
news:bcdi5o$4e0$1@rogue.oti.com...
> Hi there,
> Thanks
> Martin (Kersten)
Re: -> PDE JUnit [message #62177 is a reply to message #61455] Thu, 19 June 2003 16:55 Go to previous messageGo to next message
Hi Wim,
where
it
> at :
I know that work already. ;) My problem is how the lifecycle of a test case
of
a plugin in. Normaly every method gets a setup etc. But testing a plugin
seams
to be slightly diffrent. I will check the book again. Maybe they added
something
new. ;)
But I will also check the PDE TestCases used to test the eclipse plugins.
Maybe
I find some answers. If not I will touch the code of PDE Unit within next
days
(its not much, around 30k I think).
Martin (Kersten)
> Wim.
message
> > Hi there,
> > Thanks
> > Martin (Kersten)
Re: -> PDE JUnit [message #63589 is a reply to message #61455] Fri, 20 June 2003 16:41 Go to previous message
Hi Telenet,
where
it
> at :
Well they added a lot. And most important of all... they added the
informations
I needed. Thanks for telling me. It is 3 month ago since I've checked the
drafts there.
Kent and Gamma seams to have a productiv time then ;)
Thanks!!
Martin (Kersten)
> Wim.
message
> > Hi there,
> > Thanks
> > Martin (Kersten)
Previous Topic:Q: JUnit and Rerun single test from hierarchy
Next Topic:Package Explorer Directory Structute
Current Time: Wed Nov 19 01:50:14 EST 2025
Powered by FUDForum. Page generated in 0.05455 seconds
