Home » Eclipse Projects » GEF » How can I set one of the pages of multipage editor as GEF page?
How can I set one of the pages of multipage editor as GEF page? [message #57206] Wed, 22 January 2003 14:26 Go to next message
void createPage4()
Canvas canvas = new Canvas(getContainer(), SWT.NONE | SWT.NO_BACKGROUND);
FillLayout layout = new FillLayout();
canvas.setLayout(layout);
LightweightSystem lws = new LightweightSystem(canvas);
IFigure figure = new Figure();
lws.setContents(figure);
//Here, I want to add the GEF page
thanks
aithu
Re: How can I set one of the pages of multipage editor as GEF page? [message #57230 is a reply to message #57206] Wed, 22 January 2003 15:11 Go to previous messageGo to next message
I think you would just call addPage(canvas)? That would put your canvas on that page and the
lightweight system would be associated with that canvas.
Eric
> void createPage4()
> thanks
> aithu
Re: How can I set one of the pages of multipage editor as GEF page? [message #57257 is a reply to message #57230] Wed, 22 January 2003 15:12 Go to previous messageGo to next message
I want to add a gef page similar to the one in logic editor example. So,
how can i do that.
thanks
Re: How can I set one of the pages of multipage editor as GEF page? [message #57283 is a reply to message #57257] Wed, 22 January 2003 15:41 Go to previous messageGo to next message
There's also an addPage(IEditorPart, IEditorInput) method in MultiPageEditorPart. You can create a
new GraphicalEditor (i.e. LogicEditor) and set it as one of the pages. You can just use
getEditorInput() for the second parameter.
Eric
> how can i do that.
> thanks
Re: How can I set one of the pages of multipage editor as GEF page? [message #57334 is a reply to message #57283] Wed, 22 January 2003 16:00 Go to previous messageGo to next message
Hi Eric,
Thanks for your quick reply.
I tried the following code:
int index = addPage(new LogicEditor(),getEditorInput());
But, I get the error: "Unhandled exception type
org.eclipse.ui.PartInitException"
What is the problem.
thanks,
aithu
Re: How can I set one of the pages of multipage editor as GEF page? [message #58316 is a reply to message #57334] Mon, 27 January 2003 11:09 Go to previous message
Originally posted by: hudsonr.us.i_b_m.com
Are you doing this from within the Logic Plugin?
If you have your own plugin that is trying to reuse the Logic Plugin, then I
would gues that the problem is that the Logic Example does NOT export its
classes, so new LogicEditor() will cause a ClassNotFoundException.
Look at the .log file in the META area in the runtime workspace.
"Aithu" <aithu@hotmail.com> wrote in message
news:b0n0q6$c4$1@rogue.oti.com...
> Hi Eric,
> thanks,
> aithu
Previous Topic:Simple Examples and a Mouse Listener
Next Topic:Direct Edit in GEF
Current Time: Thu Jul 24 03:40:35 EDT 2025
Powered by FUDForum. Page generated in 0.24444 seconds
