Home » Archived » M2M (model-to-model transformation) » [ATL] KM3 metamodel extension
[ATL] KM3 metamodel extension [message #57155] Thu, 09 August 2007 14:57 Go to next message
Originally posted by: zhangj.cis.uab.edu
I have a question for ATL/KM3. How to specify a km3 metamodel that extends
another km3 metamodel which is defined somewhere else? Do I need to set up
any path to guide the km3 parser to find the superclass?
Jing
Re: [ATL] KM3 metamodel extension [message #57181 is a reply to message #57155] Thu, 09 August 2007 16:00 Go to previous message
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
You can use the generic editor, as if you were creating a complete KM3
metamodel. However, the editor will indicate syntax errors, since it
cannot refer to the extended elements.
We have a typical case of metamodel extension when using the AMW
plug-in. We define an extension like that:
class Attribute extends WLinkEnd {
The WLinkEnd class is defined in a core weaving metamodel. In this
particular case, it is not necessary to set up any path, because the
core metamodel is extended automatically when using the AMW tool.
Marcos.
Jing Zhang wrote:
> Hello,
> extends another km3 metamodel which is defined somewhere else? Do I need
> to set up any path to guide the km3 parser to find the superclass?
> Jing
Previous Topic:[ATL] Why returning a sequence of a sequence ?
Next Topic:[ATL] loadModel and SaveModel
Current Time: Mon Jul 21 21:06:12 EDT 2025
Powered by FUDForum. Page generated in 0.03921 seconds
