Home » Modeling » TMF (Xtext) » Modeling predefined and custom commands with same prefix
Modeling predefined and custom commands with same prefix [message #57143] Sun, 12 July 2009 17:01 Go to next message
Hi all,
I want to define a DSL where there are predefined commands starting with \
which I would like to parse. Also, there is the ability to define custom
commands and refer to them also in \command syntax. I'm not sure
whether/how this is possible. I tried:
PredefinedCommand: "\\commandPreset1" | "\\commandPreset2" // And so on
Assignment: id=ID "=" value=Value; // The Value rule is irrelevant here
CustomCommand hidden(): "\\" ref=[Assignment|ID];
But unfortunately the following sample file:
commandCustom = ...
\commandCustom
generates the following error:
no viable alternative at character 'C'
at the "commandCustom" token's 'C' character because the parser wants to
match one of the predefined command tokens. How could I tell the parser to
behave the right way? Any help would be highly appreciated!
Thanks in advance
thSoft
Re: Modeling predefined and custom commands with same prefix [message #57362 is a reply to message #57143] Mon, 13 July 2009 03:32 Go to previous messageGo to next message
I'm not sure why the lexer behaves like you described.
Looking at the grammar it should at least have parsed until the 'P'
because '\command' seems to be the common prefix.
Anyway, from a language design point of view, I would prefer to either
don't have built-in commands but try to define them using a library
approach or if you want to have them built-in doing it like so:
Command : '\\' (ref=[Assignment|ID] | builtInCommand=BuiltInCommans);
enum BuiltInCommand :
'commandPreset1'|
'commandPreset2';
Because then you're able to handle commands more generically in your code.
Hope that helps,
Sven
Dennis Harmath schrieb:
> Hi all,
> \ which I would like to parse. Also, there is the ability to define
> custom commands and refer to them also in \command syntax. I'm not sure
> commandCustom = ...
> \commandCustom
> to behave the right way? Any help would be highly appreciated!
> Thanks in advance
> thSoft
Re: Modeling predefined and custom commands with same prefix [message #58183 is a reply to message #57362] Tue, 14 July 2009 05:24 Go to previous message
Thank you for your help, Sven! Your second approach does work. However, it
will be tough work to refactor my grammar because there are many built-in
commands with "arguments" which I also want to parse, and there must be no
whitespace between \ and the command name (hence the hidden() directives).
It's time to give it a go...
Previous Topic:Error generating UI [ropject from TMF grammar
Next Topic:Left recursion: from binary to n-ary operations
Current Time: Sat Jul 26 15:58:06 EDT 2025
Powered by FUDForum. Page generated in 0.26140 seconds
