Home » Language IDEs » Java Development Tools (JDT) » Debug and Run Configurations Speed Varies
Debug and Run Configurations Speed Varies [message #57132] Fri, 13 June 2003 17:39 Go to next message
Originally posted by: vnssoftware.myway.com
The same application takes less than a minute when doing Run>Run..It takes
more than 5 minutes when doing Debug>Debug..(that is in debug mode)
Why? PLEASE HELP OTHERWISE ALL MY EFFORTS TO GET ECLIPSE FOR DEBUGGING
WILL BE OF NO USE SINCE I CANNOT DEBUG WITH SUCH SLOW SPEED!
Thanks...
Re:INFO ADDED Debug and Run Configurations Speed Varies [message #57188 is a reply to message #57132] Fri, 13 June 2003 18:05 Go to previous messageGo to next message
vns wrote:
> Thanks...
Just for info sake-
I am using Eclipse 2.1
JDK from Sun 1.3.1
Thanks...
Re:INFO ADDED Debug and Run Configurations Speed Varies [message #57521 is a reply to message #57188] Sat, 14 June 2003 11:19 Go to previous messageGo to next message
No need to shout your needs....
Increase the memory of the JVM.
On MacOsX I modified -vm in the info.plist of Eclipse to have -Xms90M
and -Xmx250M. It incresed the speed a lot.
Patrice Drolet
Re: INFO ADDED Debug and Run Configurations Speed Varies [message #57967 is a reply to message #57521] Sun, 15 June 2003 20:25 Go to previous messageGo to next message
I am on Windows 2000. Is info.plist present there?
Can there be any other reason for this difference. Is Memory Requirement
for Run and debug configurations so different? Thanks.....
Re: INFO ADDED Debug and Run Configurations Speed Varies [message #58015 is a reply to message #57967] Sun, 15 June 2003 20:36 Go to previous messageGo to next message
>> Xms90M and -Xmx250M. It incresed the speed a lot.
> Requirement for Run and debug configurations so different? Thanks.....
On Windows 2000... I do not know. Somebody can certainly helps here.
I know that on Macosx, if I debug it is faster when I increase the
memory of the JVM.
Patrice Drolet
Re: INFO ADDED Debug and Run Configurations Speed Varies [message #58039 is a reply to message #58015] Sun, 15 June 2003 21:14 Go to previous messageGo to next message
Can Hotspot / Classic version help in debugging with jdk 1.3.1
Should I be passing -classic parameter in the command line options?
Thanks once again for help....
Re: INFO ADDED Debug and Run Configurations Speed Varies [message #58089 is a reply to message #57967] Sun, 15 June 2003 22:11 Go to previous message
Originally posted by: bob.objfac.com
Don't look for other reasons until you've tried more memory.
If you're on Win2K, and you're starting Eclipse by double-click, make a
shortcut. Then right-click the shortcut > Properties and enter the Target as
G:\eclipse\eclipse.exe -vmargs -Xmx256MB
adjusting the path to fit your configuration.
Bob
"vns" <vnssoftware@myway.com> wrote in message
news:bcj2pa$2fb$1@rogue.oti.com...
Previous Topic:-> Plugin referrences Project
Next Topic:workingset enhancement
Current Time: Tue Jul 15 11:47:33 EDT 2025
Powered by FUDForum. Page generated in 0.30976 seconds
