Home » Archived » XML Schema Definition (XSD) » Create a simpleType from a DOM element
Create a simpleType from a DOM element [message #57106] Mon, 17 January 2005 10:24 Go to next message
I create an XSDSchema instance from a schema file. Another XML file (not a
schema file) contains simpleType definitions which should then be added to
the schema. Therefore I parse the XML file and extract the elements which
represent a simpleType definition.
How is it possible to create new XSDSimpleTypeDefinitions from these
elements and add them to the XSDSchema instance?
Cheers
Klaas
Re: Create a simpleType from a DOM element [message #57134 is a reply to message #57106] Tue, 18 January 2005 08:38 Go to previous message
I solved the problem myself. If someone is interested here is the solution:
private void parseSimpleType(XSDSchema schema, Element simpleTypeElement) {
XSDSimpleTypeDefinition simpleType = XSDSimpleTypeDefinitionImpl
.createSimpleTypeDefinition(simpleTypeElement);
profile.getUserDefinedSimpleTypes().add(simpleType);
It is important that the DOM element is not imported into the DOM document
of the schema.
Cheers
Klaas
Re: Create a simpleType from a DOM element [message #593598 is a reply to message #57106] Tue, 18 January 2005 08:38 Go to previous message
of the schema.
Cheers
Klaas
Previous Topic:Create a simpleType from a DOM element
Next Topic:Performance issues with loading xsds
Current Time: Fri Jul 18 01:38:08 EDT 2025
Powered by FUDForum. Page generated in 0.04270 seconds
