Home » Eclipse Projects » DTP » running datatools in a rap runtime
running datatools in a rap runtime [message #57101] Thu, 25 June 2009 08:26 Go to next message
Did anyone do this already and is he/she willing to share his/her
experiences?
Re: running datatools in a rap runtime [message #57127 is a reply to message #57101] Thu, 25 June 2009 08:30 Go to previous messageGo to next message
I do not mean to run the whole datatools plugins, just the core plugins
like connectivity...
Re: running datatools in a rap runtime [message #57382 is a reply to message #57127] Mon, 20 July 2009 13:11 Go to previous messageGo to next message
Hi Erdal...
Unfortunately I know I haven't had the time to spend with RAP that I
might like. So no, haven't tried it.
If you run into issues however, please log some Bugzillas with any
issues you find and we'll try and get to them in a maintenance release
or next year's major release. Or simply put questions up here and we'll
do our best to answer them.
--Fitz
Re: running datatools in a rap runtime [message #477845 is a reply to message #57382] Thu, 06 August 2009 02:54 Go to previous messageGo to next message
I was able to use connectivity core and the oracle enablements in an
experimental environment.
There have been no problems except for the connection creation:
connections are created in an eclipe job which are executed in a worker
thread. Those worker threads have no access to the ui (in rap this is the
user session). Now, if the connection is created, rap will complain about
not being able to access the ui.
For now, I changed the connection creation within
org.eclipse.datatools.connectivity.internal.ConnectionProfil e.ConnectJob.run(..)
to use the NullProgressMonitor whenever
org.eclipse.core.runtime.jobs.IJobManager.createProgressGrou p() (fyi:
https://dfruits.dev.java.net/source/browse/dfruits/trunk/com .dfruits.patches.rap/src/com/dfruits/patches/rap/Connectivit yPatch.java?rev=385&view=markup)
Re: running datatools in a rap runtime [message #479582 is a reply to message #477845] Tue, 11 August 2009 11:36 Go to previous message
> the user session). Now, if the connection is created, rap will complain
> about not being able to access the ui.
That's awesome that you got it to work. Interesting that RAP can't
access worker jobs. Is that a known issue with RAP that just has to be
worked around?
Re: running datatools in a rap runtime [message #596012 is a reply to message #57101] Thu, 25 June 2009 08:30 Go to previous message
Re: running datatools in a rap runtime [message #596098 is a reply to message #57127] Mon, 20 July 2009 13:11 Go to previous message
Hi Erdal...
--Fitz
Re: running datatools in a rap runtime [message #596260 is a reply to message #57382] Thu, 06 August 2009 02:54 Go to previous message
Re: running datatools in a rap runtime [message #596274 is a reply to message #477845] Tue, 11 August 2009 11:36 Go to previous message
worked around?
Previous Topic:About navigatorContent in connectivity
Next Topic:About navigatorContent in connectivity
Current Time: Thu Jul 17 06:58:01 EDT 2025
Powered by FUDForum. Page generated in 0.24175 seconds
