Re: running datatools in a rap runtime [message #479582 is a reply to message #477845] |
Tue, 11 August 2009 11:36  |
Erdal Karaca wrote:
> I was able to use connectivity core and the oracle enablements in an
> experimental environment.
> There have been no problems except for the connection creation:
> connections are created in an eclipe job which are executed in a worker
> thread. Those worker threads have no access to the ui (in rap this is
> the user session). Now, if the connection is created, rap will complain
> about not being able to access the ui.
> For now, I changed the connection creation within
> org.eclipse.datatools.connectivity.internal.ConnectionProfil e.ConnectJob.run(..)
> to use the NullProgressMonitor whenever
> org.eclipse.core.runtime.jobs.IJobManager.createProgressGrou p() (fyi:
> https://dfruits.dev.java.net/source/browse/dfruits/trunk/com .dfruits.patches.rap/src/com/dfruits/patches/rap/Connectivit yPatch.java?rev=385&view=markup)
That's awesome that you got it to work. Interesting that RAP can't
access worker jobs. Is that a known issue with RAP that just has to be
worked around?
Re: running datatools in a rap runtime [message #596098 is a reply to message #57127] |
Mon, 20 July 2009 13:11  |
Erdal Karaca wrote:
> I do not mean to run the whole datatools plugins, just the core plugins
> like connectivity...
Hi Erdal...
Unfortunately I know I haven't had the time to spend with RAP that I
might like. So no, haven't tried it.
If you run into issues however, please log some Bugzillas with any
issues you find and we'll try and get to them in a maintenance release
or next year's major release. Or simply put questions up here and we'll
do our best to answer them.
--Fitz
Re: running datatools in a rap runtime [message #596274 is a reply to message #477845] |
worked around?
FUDForum. Page generated in 0.07596 seconds
