Home » Archived » BIRT » Using 2nd Dataset in Master Page
Using 2nd Dataset in Master Page [message #57071] Tue, 12 July 2005 23:34 Go to next message
Can anyone help me on how to use a 2nd dataset to insert a dataset field
when using a grid element in master page layout for I have to produce a
PDF format..
Example:
"Balance Statement as of period" + row["periodno"]<--this field should
come from the second dataset in the report.
Wins
Re: Using 2nd Dataset in Master Page [message #57098 is a reply to message #57071] Tue, 12 July 2005 23:43 Go to previous messageGo to next message
While in master page layout I tried to add a data element inside the grid
and binded the data element to my dataset where the field row["periodno"]
will come from and got this error message at the end of the PDF report...
There are errors on the report page:
Error1:Failed to evaluate row["periodno"]
ReferenceError: "row" is not defined. (#1)
Your timely support will be appreciated..Thanks.
Wins
Re: Using 2nd Dataset in Master Page [message #58067 is a reply to message #57098] Thu, 14 July 2005 02:53 Go to previous messageGo to next message
PDF format..
Example: "Balance Statement as of period" + row["periodno"]<--this field
should come from the second dataset in the report. Thanks,
Wins
Re: Using 2nd Dataset in Master Page [message #58625 is a reply to message #58067] Fri, 15 July 2005 01:49 Go to previous messageGo to next message
Dataset is not supported in Report header/footer of the master page layout.
Any report item like table, list bound to data is not supported in the
page header or footer.
--Rima Kanguri
BIRT Committer
Re: Using 2nd Dataset in Master Page [message #58892 is a reply to message #58625] Fri, 15 July 2005 05:55 Go to previous message
Hi Rima,
My header requires to display a parameter field from the dataset..e.g.
"Sales Report for the Month of" + row["Month"] and should be in PDF
format...can you please help me on how can I accomplished this requirement
if dataset is not supported in master page layout...Correct me if I'm
wrong but what I understand is that if I have to output my report in PDF
then I have to set my header in master page layout....
Wins
Previous Topic:Birt Scripting: String functions
Next Topic:Any support for: Scripted Reports with Drilldowns over SDO DataGraph Object ?
Current Time: Sun Aug 31 19:50:31 EDT 2025
Powered by FUDForum. Page generated in 0.05658 seconds
