calling a java extension from inside an Xpand file [message #57052] |
Sun, 08 February 2009 07:44  |
Hi, again me,
I have the following problem. During the generation of java code out of
an activity diagram I use various extensions written in Java called
through Xtend. The part of the template file calling the extension looks
like the following:
«DEFINE ProcessStoryActivity FOR uml::Activity»
«LET getInitialNode(this) AS initNode»
«ENDLET»
«ENDDEFINE»
the defined extension in the Xtend file looks like:
org.eclipse.uml2.uml::InitialNode getInitialNode(uml::Activity act) :
JAVA template.Teststories.getInitialNode(org.eclipse.uml2.uml.Act ivity);
and the according implementation pof the java file has the following
signature:
package template;
import java.util.Iterator;
import org.eclipse.emf.common.util.EList;
import org.eclipse.uml2.uml.Activity;
import org.eclipse.uml2.uml.Element;
import org.eclipse.uml2.uml.InitialNode;
public class Teststories {
* Returns the initial node of the activity diagram.
* @param act
* the activity diagram
* @return the inital node
public static InitialNode getInitialNode(Activity act) {
So far everything seems to look ok for me, but now when i try to run the
generator file i get the following error:
5393 ERROR AbstractExpressionsUsingWorkflowComponent - Error in
Component generator of type org.openarchitectureware.xpand2.Generator:
EvaluationException : mismatched input '.' expecting '(' on line 1
template::Teststories.xpt[1565,35] on line 59
'getInitialNode((uml::Activity)this)'
this means that somehow i can't call the extension the way i'm doing it,
but unfortunately I can't figure out why. Has anyboday probably got a
hint for me, why this error occurrs?
Thanks a lot!
cheers,
Philipp
Re: calling a java extension from inside an Xpand file [message #57111 is a reply to message #57052] |
Sun, 08 February 2009 08:12  |
Philipp Zech schrieb:
> Hi, again me,
> like the following:
> «ENDLET»
> «ENDDEFINE»
> JAVA
> signature:
> package template;
> * @param act
> Thanks a lot!
> cheers,
> Philipp
again resolved,
the reason was that the return type of the declared extension has to be
written like:
JAVA
have a nice sunday everybody
FUDForum. Page generated in 0.04280 seconds
