Home » Modeling » TMF (Xtext) » [Xtext] A very generic terminal definition
[Xtext] A very generic terminal definition [message #57051] Fri, 10 July 2009 11:47 Go to next message
Hi everyone.
I have the following problem:
In my DSL, I have a Token that can be very generic.
Possible example values are:
- "abc" -> Single Line String with quotation marks
- "abc
defg
xyz" -> multi line String with quotation marks
- "abc
defg
xyz" "hello" "wor
ld" -> Multiple Quotation Mark Strings, possibly over multiple Lines
- [188, 365, 512, 604] -> numbers, commas, brackets and whitespaces
- 10 -> INT
- 20.02 -> FLOAT
- helloWorld -> Single line String without Quotation Marks and without
whitspaces
- hello100World -> same as before, but with digits
- 100World
- hello100
I've tried to define a terminal for that:
For all Quotation Mark Strings, I have defined:
terminal ML_STRINGVALUE : ('"' -> '"')+;
All values, with and without Quotation Marks shall be possible for my
generic token.
All of my attempts resulted in warnings like:
warning(208):
../org.de.***.parse.mdl/src-gen/org/de/***/parse/parser/antl r/internal/InternalMDL.g:619:1:
The following token definitions are unreachable: RULE_INT
Thats currently the import part from my Definition:
grammar org.de.***.parse.MDL with org.eclipse.xtext.common.Terminals
generate mDL "http://www.de.org/***/parse/MDL"
MDLModel :
model=Model;
terminal NOSTRINGVALUE : ('a'..'z'|'A'..'Z'|'.'|'-'|','|INT)+;
terminal VECTOR : '[' -> ']';
//terminal VALUE : (NOSTRINGVALUE|ML_STRINGVALUE);
ParamValuePair :
parameter=NOSTRINGVALUE value=(VECTOR|NOSTRINGVALUE|ML_STRINGVALUE)
Does anyone have an idea, how it is possible to also accept the values
without Quotation Marks and without getting warnings like "The following
token definitions are unreachable: RULE_INT"?
Also it is not possible yet, to have whitespaces between End and Start
Quotation Marks considering Multiple Quotation Mark Strings, possibly over
multiple Lines as mentioned above.
Kind regards, Helko
Re: [Xtext] A very generic terminal definition [message #57117 is a reply to message #57051] Sun, 12 July 2009 16:48 Go to previous messageGo to next message
I hit the same problem recently. From the Xtext doc: "Note, that the order
of terminal rules is crucial for your grammar, as they may hide each
other. This is especially important for newly introduced rules in
connection with mixed rules from used grammars." Your FLOAT rule may
shadow the INT rule from org.eclipse.xtext.common.Terminals. What are the
number rules from your grammar?
Re: [Xtext] A very generic terminal definition [message #57311 is a reply to message #57117] Mon, 13 July 2009 03:15 Go to previous messageGo to next message
Hi Dennis.
Currently, these are my grammar rules.
I think NOSTRINGVALUE is the reason for the warning message, because this
rules covers the INT rule.
ParamValuePair :
Rejecting INT from NOSTRINGVALUE and putting it to the alternative of
"value"
ParamValuePair :
parameter=NOSTRINGVALUE value=(VECTOR|NOSTRINGVALUE|ML_STRINGVALUE|INT)
will cause "Cannot find type for
'VECTOR|NOSTRINGVALUE|INT|ML_STRINGVALUE'."...
But back to main problem. To handle my generic token, I' thinking that
using predinfined rules from org.eclipse.xtext.common.Terminals is not
helpful here, because I will need a fine grained set of rule definition.
Do you agree with me?
regards, helko
Re: [Xtext] A very generic terminal definition [message #57336 is a reply to message #57051] Mon, 13 July 2009 03:17 Go to previous message
Hi Helko,
find my comments inlined :
Helko Glathe schrieb:
> Hi everyone.
> - "abc defg
> - "abc defg
> xyz" "hello" "wor
> - 10 -> INT
> - 20.02 -> FLOAT
> whitspaces
> - 100World
> - hello100
Why do you want to define all this in one terminal rule?
It should be separeted into multiple rules, one for each of the outlines
syntaxes.
This shouldn't be a terminal rule, but a parser rule:
QuotationMarkStrings : values+=STRING;
> generic token.
> warning(208):
> ./org.de.***.parse.mdl/src-gen/org/de/***/parse/parser/antlr /internal/InternalMDL.g:619:1:
This warning occurs if you have a token rule which shadows following
rules. See documentation or the other comment of Dennis Harmath.
> MDLModel :
> model=Model;
> ParamValuePair :
You should do this with datatype rules, or even real parser rules.
For instance:
Vector : '[' values+=INT (',' values+=INT)+ ']';
TextValue : STRING | ID;
> over multiple Lines as mentioned above.
It is possible, and automatically handled if you use datatype rules or
common parser rules. If you use terminal rules, you have to handle
whitespace explicitly. But you shouldn't use them for what you want to do.
Sven
Previous Topic:[xtext] Serializing parsed DSL Model
Next Topic:Grammar reuse
Current Time: Sat Jul 12 12:32:28 EDT 2025
Powered by FUDForum. Page generated in 0.03949 seconds
