Re: 1.0.1M1 question ? [message #60512 is a reply to message #60011] |
Thu, 21 July 2005 05:10  |
1.0.1 finial will support GEF 3.1
"Morten Moeller" <myname(with.between names)@lombardisoftware.com>
??????:dbk110$v2a$1@news.eclipse.org...
> Any ETA on when Birt will be converted to GEF 3.1? Is this planed for
> 1.0.1M2?
> Our application is at Eclipse 3.1/GEF 3.1 so Im anxious to start playing
> with BIRT integration :)
> Qiangsheng Wang wrote:
>> For GEF 3.1 is not code compatible with GEF 3.0, we'are working on this
>> issue now. Current code only support eclipse 3.1 + GEF 3.0.x + EMF 2.1
>> Thank
>> Qiangsheng
>> "snpe" <snpe@snpe.co.yu> wrote in message
>> news:db80tt$pdt$1@news.eclipse.org...
>>> I try 1.0.1M1 and cvs HEAD and I have problem with gef in with 2 classes
>>> (LabelFigure and TextFlow)because changes in FlowBox
>>> I try fix and it wokr, but I can't see label in desinger
>>> I try example from site (customer table) and I create report fine,
>>> but I see only empty rectangle in design mode (I don't see, for example
>>> row['xxx'] in field or customername in column header
>>> regards
>>> Wang QS wrote:
>>> > Could you try with lastest stable build?
>>> > it's eclipse 3.1 compatible
>>> > Becuase GEF 3.1 has code breaking changes, current code can only
>>> > support eclipse3.1+GEF 3.0.x +EMF 2.1 now.
>>> > Thanks
>>> > Wang Qiangsheng
>>> > "snpe" <snpe@snpe.co.yu> ??????:db18rp$b2r$1@news.eclipse.org...
>>> >> Is it eclipse 3.1 compatible ?
>>> >> Thanks
>>> >> Haris Peco
FUDForum. Page generated in 0.26074 seconds
