Home » Eclipse Projects » Technology Project and PMC » Problems with runtime workbench and jdt core
Problems with runtime workbench and jdt core [message #57015] Wed, 20 August 2003 00:28 Go to next message
I am building a plugin that uses the JDT Core APIs. I can build fine ( i
have ECLIPSE_HOME/plugins/org.eclipse.jdt.core_2.1.1/jdtcore.jar in the
classpath).
However when I launch the runtime workbench I get the following error:
java.lang.NoClassDefFoundError: org/eclipse/jdt/core/JavaCore
How do I find out what classpath is used by the runtime workbench? I tried
choosing "Choose plugins and fragments to launch from list" and made sure
the org.eclipse.jdtcore was checked. But I still have this problem.
The second issue is - when I make a code change, I am forced to shutdown the
runtime workbench and re-launch it to detect the new code changes. I thought
I saw a demo by one of the Eclipse team leads recently where he did not have
to restart the workbench after some code changes. Is this achieved through
some setting in the run configuration?
thanks
Vijay
Re: Problems with runtime workbench and jdt core [message #57044 is a reply to message #57015] Wed, 20 August 2003 06:17 Go to previous messageGo to next message
Did you add the required plugins to the classpath? If you did please enter a
bug report agains PDE.
Jerome
"Vijay Ganesan" <vijay@mindspring.com> wrote in message
news:bhutck$od2$1@eclipse.org...
> classpath).
the
thought
have
> thanks
> Vijay
Re: Problems with runtime workbench and jdt core [message #57096 is a reply to message #57044] Wed, 20 August 2003 11:16 Go to previous messageGo to next message
I added an entry to the .classpath file as follows (manually edited the
file):
<classpathentry kind="var"
path="ECLIPSE_HOME/plugins/org.eclipse.jdt.core_2.1.1/jdtcore.jar "
sourcepath=" ORG_ECLIPSE_PLATFORM_SOURCE_SRC/org.eclipse.jdt.core_2.1.1/r unti
mesrc.zip"/>
After adding the entry, I restarted the workbench and my code that used JDT
Core built fine. But the run-time workbench gave me the class not found
error i am reporting.
Does the runtime workbench use the entries in the .classpath file? It looks
like it does not and I am trying to figure out what classpath it uses. I
will write a bug report if I don't get some other response in the next few
days.
thanks
Vijay
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:bhvhsb$9qr$1@eclipse.org...
a
> Jerome
> > classpath).
tried
sure
> the
> thought
> have
through
> > thanks
> > Vijay
Re: Problems with runtime workbench and jdt core [message #57123 is a reply to message #57015] Wed, 20 August 2003 11:30 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
Don't forget to add jdt to the required plugins in the plugin.xml file.
If you do that, then PDE should take care of getting it into the classpath.
Re: Problems with runtime workbench and jdt core [message #57179 is a reply to message #57096] Thu, 21 August 2003 05:37 Go to previous messageGo to next message
I'm not sure how you created your plugin, but you should definitively not
have to edit the .classpath file. Please first read the PDE Guide from the
Help menu to learn how to add a required plugin to the plugin.xml file and
to update the classpath accordingly.
Jerome
news:bi03ba$s62$1@eclipse.org...
> file):
> mesrc.zip"/>
JDT
looks
> days.
> thanks
> Vijay
enter
> a
> > Jerome
( i
the
> > > classpath).
> tried
> sure
shutdown
> > the
> > thought
not
> > have
> through
> > > thanks
> > > Vijay
Problems with runtime workbench and jdt [message #57203 is a reply to message #57179] Thu, 21 August 2003 07:27 Go to previous message
Originally posted by: prameela.kumar.int-evry.fr
hi ,
I am trying to do add JavaCapabilityConfigurationPage to a wizard.
as following. But without success.
COde:
public void addPages()
IProject project = null;
JavaCapabilityConfigurationPage confPage = new
JavaCapabilityConfigurationPage();
confPage.init(JavaCore.create(project),null,null,false);
addPage(confPage);
Problem :
1) while trying to launch the wizard it is throwing "NoClassDefFoundErr"
2) Another Unrelated problem is I am unable luanch my plugin as
runtime workbench.
Thanx a lot
Prameela
> Jerome
>>file):
>>mesrc.zip"/>
> JDT
> looks
>>days.
>>thanks
>>Vijay
> enter
>>a
>>>Jerome
> ( i
> the
>>>>classpath).
>>tried
>>sure
> shutdown
>>>the
>>>thought
> not
>>>have
>>through
>>>>thanks
>>>>Vijay
Re: Problems with runtime workbench and jdt core [message #594915 is a reply to message #57015] Wed, 20 August 2003 06:17 Go to previous message
Jerome
> classpath).
the
thought
have
> thanks
> Vijay
Re: Problems with runtime workbench and jdt core [message #594938 is a reply to message #57044] Wed, 20 August 2003 11:16 Go to previous message
file):
mesrc.zip"/>
days.
thanks
Vijay
a
> Jerome
> > classpath).
tried
sure
> the
> thought
> have
through
> > thanks
> > Vijay
Re: Problems with runtime workbench and jdt core [message #594953 is a reply to message #57015] Wed, 20 August 2003 11:30 Go to previous message
Re: Problems with runtime workbench and jdt core [message #594967 is a reply to message #57096] Thu, 21 August 2003 05:37 Go to previous message
Jerome
> file):
> mesrc.zip"/>
JDT
looks
> days.
> thanks
> Vijay
enter
> a
> > Jerome
( i
the
> > > classpath).
> tried
> sure
shutdown
> > the
> > thought
not
> > have
> through
> > > thanks
> > > Vijay
Problems with runtime workbench and jdt [message #594976 is a reply to message #57179] Thu, 21 August 2003 07:27 Go to previous message
hi ,
COde:
addPage(confPage);
Problem :
runtime workbench.
Thanx a lot
Prameela
> Jerome
>>file):
>>mesrc.zip"/>
> JDT
> looks
>>days.
>>thanks
>>Vijay
> enter
>>a
>>>Jerome
> ( i
> the
>>>>classpath).
>>tried
>>sure
> shutdown
>>>the
>>>thought
> not
>>>have
>>through
>>>>thanks
>>>>Vijay
Previous Topic:ANNOUNCE: eclipse visualization tool
Next Topic:ANNOUNCE: eclipse visualization tool
Current Time: Sat Jul 12 16:31:22 EDT 2025
Powered by FUDForum. Page generated in 0.04737 seconds
