Home » Archived » XML Schema Definition (XSD) » showing the prefix
showing the prefix [message #57003] Wed, 12 January 2005 12:31 Go to next message
Originally posted by: ooi.de.ibm.com
I would like to know how do we "show" the prefixes in the schema we
generate.. for eg.
<xsd:import....> instead of <import>
<xsd:element ..> instead of <element>
thank you.
Re: showing the prefix [message #57057 is a reply to message #57003] Thu, 13 January 2005 12:06 Go to previous message
> generate.. for eg.
You can set the qname prefix used to reference the schema for schema
namespace via XSDSchema.setSchemaForSchemaQNamePrefix(). There's also a
map accesible via XSDSchema.getQNamePrefixToNamespaceMap() that defines
all of the namespace qname-namespace pairs to use in the schema. It must
have an entry that agrees with the above schema for schema namespace
prefix, too. So, for the result shown in your example:
XSDSchema schema = XSDFactory.eINSTANCE.createXSDSchema();
schema.setTargetNamespace("http://www.example.com/test");
schema.setSchemaForSchemaQNamePrefix("xsd");
Map namespaceMap = schema.getQNamePrefixToNamespaceMap();
namespaceMap.put(schema.getSchemaForSchemaQNamePrefix(),
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
You'd also want to set a prefix to use for the target namespace. Setting
null makes it the default namespace.
namespaceMap.put(null, schema.getTargetNamespace());
Dave
Re: showing the prefix [message #593566 is a reply to message #57003] Thu, 13 January 2005 12:06 Go to previous message
> generate.. for eg.
Dave
Previous Topic:complexContent
Next Topic:complexContent
Current Time: Sun Aug 31 22:39:01 EDT 2025
Powered by FUDForum. Page generated in 0.03927 seconds
