Home » Modeling » M2T (model-to-text transformation) » OAW: issues with outlet path declaration in generator.oaw file
OAW: issues with outlet path declaration in generator.oaw file [message #56998] Sun, 08 February 2009 05:50 Go to next message
I'm still working on a code generator using Xpand and OAw to generate
java source files out of UML activity diagrams. Currently I'm facing the
problem, that in the corresponding generator.oaw file, inside the
Generator component, the outlet for the generated files can be set with
<outlet path="some_path"/>
The problem I'm facing now, is that inside my generated java files i
have to use a specific package declaration (for this example let it be
"some_path"), which may looks like
package some_path;
public class SomeClass{
Now the conrete problem is, that somehow inside the some_path directory
the default-package is automatically created and all the generated java
files are stored there, which for sure leads to classpath problems.
To summarize it:
In the workflow file the defined outlet-path is: "some_path"
In the java files the decalred pacakge is: "some_path"
What it should look like after the generation:
some_path/File1.java
File2.java
What it actually looks like:
some_path/(default-package)/File1.java
File2.java
Anybody has got any ideas how to resolve this problem?
Thanks a lot in advance.
Philipp
Re: OAW: issues with outlet path declaration in generator.oaw file [message #57026 is a reply to message #56998] Sun, 08 February 2009 05:59 Go to previous message
Philipp Zech schrieb:
> package some_path;
> To summarize it:
> File2.java
> File2.java
> Cheers,
> Philipp
again resolved: just some misconfigurations in eclipse: the path was
decalred as a source folder and not as a package. so now it works
Previous Topic:[Announce] M2T XPAND 0.7.0M5 is available
Next Topic:Xpand: invoking getValue() leads to an invocation target exception
Current Time: Sun Aug 31 12:04:02 EDT 2025
Powered by FUDForum. Page generated in 0.02898 seconds
