Using the "pde.build" target of generated ant scripts [message #565849] |
Fri, 18 April 2008 14:43 |
Originally posted by: le_nemo.yahoo.fr
I am trying to use the "pde.build" target of ant scripts generated by
PDE. I use the command specified in the the documentation. In my case,
it is :
java -Xmx1024m -jar
/opt/eclipse/plugins/org.eclipse.equinox.launcher_1.0.1.R33x _v20080118.jar
-application org.eclipse.ant.core.antRunner -buildfile
/full/path/to/my/project/build.xml -target main
The scripts are running well, until :
fetchElement:
BUILD FAILED
/full/path/to/my/project/build.xml:34: The following error occured
while executing this line:
/full/path/to/my/project/build.xml:77: The following error occured
/full/path/to/my/project/customTargets.xml:10: The following error
occured while executing this line:
/full/path/to/my/project/allElements.xml:12: The following error
/full/path/to/my/project/genericTargets.xml:42: Problem: failed to
create task or type eclipse.fetch
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/type have been declared.
Action: CHeck that any <presetdef>/<macrodef> declarations have taken
place.
I looked in the genericTargets.xml at line 42, and it seems to be all
right (this file is generated by PDE).
Is there something i did wrong ?
The scripts are executed on a GNU/Linux machine, with Eclipse 3.3.2
(Europa).
Thank you,
Francois-Xavier Bru
FUDForum. Page generated in 0.02903 seconds
