Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP crashes before run...
TPTP crashes before run... [message #56954] Thu, 09 March 2006 10:11 Go to next message
I have created a new testsuite file.
Whe clicking with the right button on the file and selection Run As... the
following error occures:
I use elipse3.2 M4 64 bit, with sun-jdk 1.5.0.06
Should i report this as a bug or the problem might be with me...
java.lang.NoClassDefFoundError: org/eclipse/core/internal/runtime/Assert
org.eclipse.hyades.test.core.internal.launch.extensions.Laun chConfigurationExtensionsManager.getExtensionDescriptor(Laun chConfigurationExtensionsManager.java:68)
org.eclipse.hyades.test.core.internal.launch.extensions.Laun chConfigurationExtensionsManager.registerRunHandlers(LaunchC onfigurationExtensionsManager.java:233)
org.eclipse.hyades.test.core.internal.launch.extensions.Laun chConfigurationExtensionsManager. <init>(LaunchConfigurationExtensionsManager.java:54)
org.eclipse.hyades.test.core.internal.launch.extensions.Laun chConfigurationExtensionsManager.getInstance(LaunchConfigura tionExtensionsManager.java:45)
org.eclipse.hyades.test.ui.internal.launch.shortcuts.LaunchP ropertyTester.getRunnableItemFromElement(LaunchPropertyTeste r.java:101)
org.eclipse.hyades.test.ui.internal.launch.shortcuts.LaunchP ropertyTester.test(LaunchPropertyTester.java:56)
at org.eclipse.core.internal.expressions.Property.test(Property .java:52)
org.eclipse.core.internal.expressions.TestExpression.evaluat e(TestExpression.java:65)
org.eclipse.core.internal.expressions.CompositeExpression.ev aluateAnd(CompositeExpression.java:48)
org.eclipse.core.internal.expressions.IterateExpression.eval uate(IterateExpression.java:108)
org.eclipse.core.internal.expressions.WithExpression.evaluat e(WithExpression.java:42)
org.eclipse.core.internal.expressions.EnablementExpression.e valuate(EnablementExpression.java:29)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchSho rtcutExtension.evalEnablementExpression(LaunchShortcutExtens ion.java:226)
org.eclipse.debug.ui.actions.ContextualLaunchAction.isApplic able(ContextualLaunchAction.java:270)
org.eclipse.debug.ui.actions.ContextualLaunchAction.fillMenu (ContextualLaunchAction.java:184)
org.eclipse.debug.ui.actions.ContextualLaunchAction$1.menuSh own(ContextualLaunchAction.java:131)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:117)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1059)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1083)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1064)
at org.eclipse.swt.widgets.Menu.gtk_show(Menu.java:581)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1372)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3692 )
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive
Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1344)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2741)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1762)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1726)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:397)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:109)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: TPTP crashes before run... [message #57014 is a reply to message #56954] Thu, 09 March 2006 10:16 Go to previous messageGo to next message
This is the configuration of my eclipse...
*** Date: Thu Mar 09 17:13:10 EET 2006
*** Platform Details:
*** System properties:
catalina.base=/home/kiril/local/eclipse3.2M4_64/eclipse/plug ins/org.eclipse.tomcat_4.1.130.v20051212/
catalina.home=/home/kiril/local/eclipse3.2M4_64/eclipse/plug ins/org.eclipse.tomcat_4.1.130.v20051212/
catalina.useNaming=true
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I20051215-1506
eclipse.commands=-os
linux
-ws
gtk
-arch
x86_64
-launcher
/home/kiril/local/eclipse3.2M4_64/eclipse/eclipse
-name
Eclipse
-showsplash
600
-exitdata
318013
-vm
/opt/sun-jre-bin-1.5.0.06/bin/java
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1141915888886
eclipse.vm=/opt/sun-jre-bin-1.5.0.06/bin/java
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
/home/kiril/local/eclipse3.2M4_64/eclipse/startup.jar
eof=eof
file.encoding=ANSI_X3.4-1968
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/home/kiril/local/eclipse3.2M4_64/eclipse/st artup.jar
java.class.version=49.0
java.endorsed.dirs=/opt/sun-jre-bin-1.5.0.06/lib/endorsed
java.ext.dirs=/opt/sun-jre-bin-1.5.0.06/lib/ext
java.home=/opt/sun-jre-bin-1.5.0.06
java.io.tmpdir=/tmp
java.library.path=/opt/sun-jre-bin-1.5.0.06/lib/amd64/server :/opt/sun-jre-bin-1.5.0.06/lib/amd64:/opt/sun-jre-bin-1.5.0. 06/../lib/amd64:/usr/lib64/mozilla
java.naming.factory.initial=org.apache.naming.java.javaURLCo ntextFactory
java.naming.factory.url.pkgs=org.apache.naming
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.15-gentoo-r5
org.osgi.framework.processor=amd64
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=amd64
os.name=Linux
osgi.arch=x86_64
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.core.jobs@2:start, org.eclipse.equinox.registry@2:start,
org.eclipse.equinox.preferences, org.eclipse.core.contenttype,
org.eclipse.core.runtime@2:start, org.eclipse.update.configurator@3:start
osgi.bundlestore=/home/kiril/local/eclipse3.2M4_64/eclipse/c onfiguration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/home/kiril/local/eclipse3.2M4_ 64/eclipse/configuration/
osgi.framework=file:/home/kiril/local/eclipse3.2M4_64/eclips e/plugins/org.eclipse.osgi_3.2.0.v20051212a.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.0.v20051212a
osgi.install.area=file:/home/kiril/local/eclipse3.2M4_64/ecl ipse/
osgi.instance.area=file:/home/kiril/work/workspace/
osgi.instance.area.default=file:/home/kiril/workspace/
osgi.logfile=/home/kiril/work/workspace/.metadata/.log
osgi.manifest.cache=/home/kiril/local/eclipse3.2M4_64/eclips e/configuration/org.eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.splashLocation=/home/kiril/local/eclipse3.2M4_64/eclips e/plugins/org.eclipse.platform_3.2.0.v20051213/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/home/kiril/local/eclipse3.2M4_64/eclipse/plugi ns
osgi.ws=gtk
path.separator=:
sun.arch.data.model=64
sun.boot.class.path=/opt/sun-jre-bin-1.5.0.06/lib/rt.jar:/op t/sun-jre-bin-1.5.0.06/lib/i18n.jar:/opt/sun-jre-bin-1.5.0.0 6/lib/sunrsasign.jar:/opt/sun-jre-bin-1.5.0.06/lib/jsse.jar: /opt/sun-jre-bin-1.5.0.06/lib/jce.jar:/opt/sun-jre-bin-1.5.0 .06/lib/charsets.jar:/opt/sun-jre-bin-1.5.0.06/classes
sun.boot.library.path=/opt/sun-jre-bin-1.5.0.06/lib/amd64
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=gnome
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=ANSI_X3.4-1968
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/home/kiril
user.home=/home/kiril
user.language=en
user.name=kiril
user.timezone=Europe/Sofia
*** Features:
org.eclipse.jdt (3.2.0.v20051212-0800-05frhQbfqg) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.0.200512151515--EADAM88GP) "Eclipse Java
Development Tools SDK"
org.eclipse.pde (3.2.0.v20051114--mPWQsJJez) "Eclipse Plug-in Development
Environment"
org.eclipse.pde.source (3.2.0.v20051114--mPWQsJJez) "Eclipse Plug-in
Development Environment Developer Resources"
org.eclipse.platform (3.2.0.v20051214-5wrXvetwgj) "Eclipse Platform"
org.eclipse.platform.source (3.2.0.200512151514-0hy9xshiQ6) "Eclipse
Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.0.v20051128-30i-kzVN5X) "Eclipse RCP"
org.eclipse.rcp.source (3.2.0.v20051128-30i-kzVN5X) "Eclipse RCP Plug-in
org.eclipse.sdk (3.2.0.v20051121--fXTSkTJY9) "Eclipse Project SDK"
*** Plug-in Registry:
antlr (2.7.2) "ANTLR Plug-in" [Resolved]
com.ibm.icu (3.4.2) "International Components for Unicode for Java
(ICU4J)" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.batik (1.6.0) "Apache Batik" [Resolved]
org.apache.batik (1.5.1) "SVG Batik Toolkit" [Resolved]
org.apache.jakarta_commons_logging (1.0.3) "Jakarta Commons Logging"
[Resolved]
org.apache.jakarta_log4j_logging (1.2.8) "Jakarta Log4J Logging" [Resolved]
org.apache.lucene (1.4.103.v20051212) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20051205) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.100.v20051205) "Ant UI" [Resolved]
org.eclipse.compare (3.2.0.v20051213) "Compare Support" [Active]
org.eclipse.core.boot (3.1.0.v20051108) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20051212-2000) "Commands" [Active]
org.eclipse.core.contenttype (3.2.0.v20051208) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.expressions (3.2.0.v20051212-0800) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.2.0.v20051214-0800) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20051208) "Core File Systems"
[Resolved]
org.eclipse.core.filesystem.linux.x86_64 (1.0.0.v20051114) "Core File
System for Linux" [Resolved]
org.eclipse.core.jobs (3.2.0.v20051208) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.0.v20051208) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.0.v20051128) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20051208) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0.v200511211912) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.variables (3.1.100.v20051128) "Core Variables" [Resolved]
org.eclipse.debug.core (3.2.0.v20051215a) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.v20051215a) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.2.0) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.2.0) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Installed]
org.eclipse.emf.codegen.ecore (2.2.0) "EMF Ecore Code Generation"
[Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.2.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.common.ui (2.2.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.0) "EMF Model Convert Support" [Resolved]
org.eclipse.emf.doc (2.2.0) "Eclipse Modeling Framework (EMF) Programmers
Guide" [Resolved]
org.eclipse.emf.ecore (2.2.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.0) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.2.0) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.2.0) "Sample Ecore Editor" [Resolved]
org.eclipse.emf.ecore.sdo (2.2.0) "EMF Service Data Objects (SDO)"
[Resolved]
org.eclipse.emf.ecore.sdo.doc (2.2.0) "EMF Service Data Objects (SDO)
Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO)
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
org.eclipse.emf.ecore.sdo.source (2.2.0) "EMF Service Data Objects (SDO)
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.0) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.0) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0) "EMF Model Export Support" [Resolved]
org.eclipse.emf.importer (2.2.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.2.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.2.0) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.2.0) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.2.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.2.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.ocl (1.0.0) "Eclipse Modeling Framework Technology OCL
Interpreter" [Resolved]
org.eclipse.emf.query (1.0.0) "Eclipse Modeling Framework Technology Query
Framework" [Resolved]
org.eclipse.emf.query.ocl (1.0.0) "Eclipse Modeling Framework Technology
Query OCL" [Resolved]
org.eclipse.emf.source (2.2.0) "Eclipse Modeling Framework (EMF) Source"
[Resolved]
org.eclipse.emf.validation (1.0.0) "Eclipse Modeling Framework Technology
Model Validation Core" [Resolved]
org.eclipse.emf.validation.ocl (1.0.0) "Eclipse Modeling Framework
Technology Validation Support for OCL" [Resolved]
org.eclipse.emf.validation.ui (1.0.0) "Eclipse Modeling Framework
Technology Validation UI" [Resolved]
org.eclipse.emf.validation.ui.ide (1.0.0) "Eclipse Modeling Framework
Technology Validation UI IDE" [Resolved]
org.eclipse.equinox.common (1.0.0.v20051205) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (1.0.0.v20051211) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (1.0.0.v20051214a) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.0) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.2.0) "Graphical Editing Framework
org.eclipse.gef.examples.flow (3.2.0) "GEF Flow Editor Example" [Resolved]
org.eclipse.gef.examples.logic (3.2.0) "GEF Logic Editor Example"
[Resolved]
org.eclipse.gef.examples.shapes (3.2.0) "GEF Shape Editor Example"
[Resolved]
org.eclipse.gef.examples.source (3.2.0) "GEF Examples" [Resolved]
org.eclipse.gef.examples.text (3.2.0) "GEF Text Editor Example" [Resolved]
org.eclipse.gef.source (3.2.0) "Graphical Editing Framework Developer
Resources" [Resolved]
org.eclipse.gmf (1.0.0) "Graphical Modeling Framework" [Resolved]
org.eclipse.gmf.bridge (1.0.0) "GMF Models Bridging Plug-in" [Resolved]
org.eclipse.gmf.codegen (1.0.0) "GMF GenModel and Code Generation"
[Resolved]
org.eclipse.gmf.codegen.edit (1.0.0) "GMF GenModel Edit Support" [Resolved]
org.eclipse.gmf.codegen.ui (1.0.0) "GMF Code Generation UI" [Resolved]
org.eclipse.gmf.graphdef (1.0.0) "GMF Graphical Definition" [Resolved]
org.eclipse.gmf.graphdef.codegen (1.0.0) "Graphical Definition Code
org.eclipse.gmf.graphdef.edit (1.0.0) "GMFGraph Edit Support" [Resolved]
org.eclipse.gmf.map (1.0.0) "GMF Mapping Model" [Resolved]
org.eclipse.gmf.map.edit (1.0.0) "GMF Mapping Edit Support" [Resolved]
org.eclipse.gmf.runtime.common.core (1.0.0) "GMF Common Core" [Resolved]
org.eclipse.gmf.runtime.common.ui (1.0.0) "GMF Common UI" [Resolved]
org.eclipse.gmf.runtime.common.ui.action (1.0.0) "GMF Common UI Action"
[Resolved]
org.eclipse.gmf.runtime.common.ui.action.ide (1.0.0) "GMF Common UI Action
IDE" [Resolved]
org.eclipse.gmf.runtime.common.ui.pathvariables.ide (1.0.0) "GMF Path
Variables IDE Plug-in" [Resolved]
org.eclipse.gmf.runtime.common.ui.printing (1.0.0) "GMF Printing"
[Resolved]
org.eclipse.gmf.runtime.common.ui.printing.win32 (1.0.0) "GMF Printing for
Win32" [Resolved]
org.eclipse.gmf.runtime.common.ui.services (1.0.0) "GMF Common UI
Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.action (1.0.0) "GMF Common UI
Action Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.dnd (1.0.0) "GMF Common UI DND
org.eclipse.gmf.runtime.common.ui.services.dnd.ide (1.0.0) "GMF Common UI
DND IDE Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.properties (1.0.0) "GMF Common
UI Properties Service Framework" [Resolved]
org.eclipse.gmf.runtime.diagram.core (1.0.0) "GMF Diagram Core" [Resolved]
org.eclipse.gmf.runtime.diagram.ui (1.0.0) "GMF Diagram UI" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.actions (1.0.0) "GMF Diagram Actions"
[Resolved]
org.eclipse.gmf.runtime.diagram.ui.dnd (1.0.0) "GMF Diagram Browse"
[Resolved]
org.eclipse.gmf.runtime.diagram.ui.geoshapes (1.0.0) "GMF Geometric
Shapes" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.printing (1.0.0) "GMF Diagram Printing"
[Resolved]
org.eclipse.gmf.runtime.diagram.ui.printing.render (1.0.0) "GMF Diagram UI
Printing Render Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.properties (1.0.0) "GMF Diagram UI
Properties" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.providers (1.0.0) "GMF Diagram
Providers" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.providers.ide (1.0.0) "GMF Diagram
Providers IDE" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.render (1.0.0) "GMF Diagram UI Render
Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.resources.editor (1.0.0) "GMF Diagram
UI Resources Editor Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide (1.0.0) "GMF IDE
Editor" [Resolved]
org.eclipse.gmf.runtime.draw2d.ui (1.0.0) "GMF Draw2d Additions" [Resolved]
org.eclipse.gmf.runtime.draw2d.ui.render (1.0.0) "GMF Draw2d Image
Rendering Additions" [Resolved]
org.eclipse.gmf.runtime.emf.clipboard.core (1.0.0) "GMF EMF Clipboard
Support" [Resolved]
org.eclipse.gmf.runtime.emf.commands.core (1.0.0) "GMF Commands" [Resolved]
org.eclipse.gmf.runtime.emf.core (1.0.0) "GMF Modeling Service Layer"
[Resolved]
org.eclipse.gmf.runtime.emf.type.core (1.0.0) "GMF EMF Type Core"
[Resolved]
org.eclipse.gmf.runtime.emf.type.ui (1.0.0) "GMF EMF Type UI" [Resolved]
org.eclipse.gmf.runtime.emf.ui (1.0.0) "GMF MSL UI" [Resolved]
org.eclipse.gmf.runtime.emf.ui.properties (1.0.0) "GMF EMF UI Properties
org.eclipse.gmf.runtime.gef.ui (1.0.0) "GMF GEF Additions" [Resolved]
org.eclipse.gmf.runtime.notation (1.0.0) "GMF Notation Model Support"
[Resolved]
org.eclipse.gmf.runtime.notation.edit (1.0.0) "GMF Notation Edit Support"
[Resolved]
org.eclipse.gmf.runtime.notation.providers (1.0.0) "GMF Notation
Metamodel" [Resolved]
org.eclipse.gmf.sdk (1.0.0) "Graphical Modeling Framework SDK" [Resolved]
org.eclipse.gmf.sdk.source (1.0.0) "Graphical Modeling Framework SDK
Developer Resources" [Resolved]
org.eclipse.gmf.source (1.0.0) "Graphical Modeling Framework Runtime
org.eclipse.gmf.tooldef (1.0.0) "GMF Tooling Model" [Resolved]
org.eclipse.gmf.tooldef.edit (1.0.0) "GMF Tooling Edit Support" [Resolved]
org.eclipse.help (3.2.0.v20051215) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20051212) "Help Application Server"
[Active]
org.eclipse.help.base (3.2.0.v20051215) "Help System Base" [Active]
org.eclipse.help.ui (3.2.0.v20051213) "Help System UI" [Active]
org.eclipse.help.webapp (3.2.0.v20051212) "Help System Webapp" [Active]
org.eclipse.hyades.analysis.engine (4.0.0) "Hyades Analysis Engine"
[Resolved]
org.eclipse.hyades.execution (4.0.0) "TPTP Platform Execution Plug-In"
[Active]
org.eclipse.hyades.execution.correlation (4.0.0) "Hyades Runtime
Correlation Engine" [Resolved]
org.eclipse.hyades.execution.trace (4.0.0) "Hyades Execution Trace"
[Resolved]
org.eclipse.hyades.logging.adapter (4.0.1) "TPTP Monitoring Project
Generic Log Adapter" [Resolved]
org.eclipse.hyades.logging.adapter.ui (4.0.0) "Generic Adapter UI"
[Resolved]
org.eclipse.hyades.logging.core (4.0.0) "Hyades Logging Agent, Common Base
Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.core.sample (4.0.0) "Sample for Hyades Logging
Agent, Common Base Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.parsers (4.0.0) "TPTP Monitoring Project Log
File Parsers" [Resolved]
org.eclipse.hyades.perfmon (4.0.0) "Perfmon StatCon Module" [Resolved]
org.eclipse.hyades.probekit (4.0.1) "Hyades Probekit" [Resolved]
org.eclipse.hyades.probekit.doc.user (4.0.0) "Probekit User Documentation"
[Resolved]
org.eclipse.hyades.probekit.ui (4.0.1) "Probe Editor" [Resolved]
org.eclipse.hyades.resources.database (4.0.0) "Hyades Core Resource
Extensions" [Resolved]
org.eclipse.hyades.sdb (4.0.0) "Symptom Database tool" [Resolved]
org.eclipse.hyades.statistical.ui (4.0.1) "Statistical Analysis" [Active]
org.eclipse.hyades.test.core (4.0.0) "TPTP Test Core Plug-In" [Active]
org.eclipse.hyades.test.doc.user (4.0.0) "Test Tools user documentation"
[Resolved]
org.eclipse.hyades.test.tools.core (4.0.1) "TPTP Test Tools Core Plug-In"
[Active]
org.eclipse.hyades.test.tools.ui (4.0.1) "TPTP Test Tools UI Plug-In"
[Active]
org.eclipse.hyades.test.ui (4.0.1) "TPTP Test UI Plug-In" [Active]
org.eclipse.hyades.trace.sample (4.0.0) "Samples for the TPTP Monitoring
Tools Plugins" [Resolved]
org.eclipse.hyades.trace.ui (4.0.0) "Hyades Trace Core UI" [Active]
org.eclipse.hyades.trace.views (4.0.0) "Hyades Trace Views Plugin"
[Resolved]
org.eclipse.hyades.ui (4.0.1) "Hyades UI" [Active]
org.eclipse.jdt (3.2.0.v20051213) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.core (3.2.0.v_631) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.0.0.v20051214-0800) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.2.0.v20051214c) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.0.v20051214c) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.2.0.v20051213-0000) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20051212-0800) "Eclipse Java Development
User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.0.v20051212-0800) "Java Development Tools JUnit
support" [Active]
org.eclipse.jdt.junit.runtime (3.2.0.v20051212-0800) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.0.v20051213) "Java Development Tools
Launching Support" [Active]
org.eclipse.jdt.source (3.2.0.v20051212-0800-05frhQbfqg) "Eclipse Java
Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.0.v20051215-0910) "Java Development Tools UI"
[Active]
org.eclipse.jface (3.2.0.I20051214-0010) "JFace" [Active]
org.eclipse.jface.databinding (3.2.0.I20051212-0010) "JFace Data Binding"
[Resolved]
org.eclipse.jface.text (3.2.0.v20051214-0800) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.2.0.v20051214-0800) "Refactoring Core"
[Active]
org.eclipse.ltk.ui.refactoring (3.2.0.v20051214-0800) "Refactoring UI"
[Active]
org.eclipse.osgi.services (3.1.100.v20051205) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20051205) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.0.v20051213) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.0.v20051212) "Plug-in Development Environment
Build Support" [Resolved]
org.eclipse.pde.core (3.2.0.v20051215-1200) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.1.0.v20051122) "Eclipse Plug-in Development
org.eclipse.pde.junit.runtime (3.2.0.v20051206) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20051206) "Plug-in Development Environment
Runtime" [Active]
Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.0.v20051215-1500) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.0.v20051213) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.0.v20051214-1415) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.0.v20051213-1750) "Eclipse Workbench
org.eclipse.platform.source (3.2.0.v20051214-5wrXvetwgj) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.linux.gtk.x86_64 (3.2.0.v20051214-5wrXvetwgj)
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.2.0.v20051206) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source.linux.gtk.x86_64 (3.2.0.v20051128-30i-kzVN5X)
"Eclipse RCP Plug-in Developer Resources" [Resolved]
org.eclipse.sdk (3.2.0.I20051206-0800) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.0.v20051212-0800) "Search Support" [Resolved]
org.eclipse.swt (3.2.0.v3218f) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.linux.x86_64 (3.2.0.v3218) "Standard Widget Toolkit
for GTK 2.0" [Resolved]
org.eclipse.team.core (3.2.0.I20051213) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.0.I20051212-1600) "CVS Team Provider Core"
[Active]
org.eclipse.team.cvs.ssh (3.2.0.I20051128) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I20051128) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.2.0.I20051213) "CVS Team Provider UI" [Active]
org.eclipse.team.ui (3.2.0.I20051213) "Team Support UI" [Active]
org.eclipse.text (3.1.100.v20051212-0800) "Text" [Active]
org.eclipse.tomcat (4.1.130.v20051212) "Tomcat Wrapper" [Active]
org.eclipse.tptp.monitoring.doc.user (4.0.0) "TPTP Monitoring Tools
org.eclipse.tptp.monitoring.logui (4.0.0) "Logui Plug-in" [Resolved]
org.eclipse.tptp.monitoring.source (4.0.1) "TPTP Monitoring Source"
[Resolved]
org.eclipse.tptp.platform.agentcontroller (4.0.1) "TPTP Agent Controller"
[Resolved]
org.eclipse.tptp.platform.agentcontroller.doc.user (4.0.0) "Agent
Controller documentation" [Resolved]
org.eclipse.tptp.platform.analysis.engine.source (4.0.0) "TPTP Analysis
Engine Source" [Resolved]
org.eclipse.tptp.platform.analysis.examples (4.0.1) "TPTP Static Analysis
Examples Plug-in" [Active]
org.eclipse.tptp.platform.analysis.metrics (4.0.0) "Metrics Plug-in"
[Resolved]
org.eclipse.tptp.platform.analysis.source (4.0.1) "TPTP Analysis Feature
Source" [Resolved]
org.eclipse.tptp.platform.analysis.static.doc.user (4.0.1) "Static
Analysis User Documentation" [Resolved]
org.eclipse.tptp.platform.analysis.static.engine (4.0.0) "TPTP Static
Analysis Engine Plugin" [Active]
org.eclipse.tptp.platform.analysis.static.engine.ui (4.0.0) "TPTP Static
Analysis Engine UI Plugin" [Active]
org.eclipse.tptp.platform.analysis.static.util (4.0.0) "TPTP Static
Analysis Utilities Plugin" [Active]
org.eclipse.tptp.platform.analysis.static.util.ui (4.0.1) "TPTP Analysis
UI Utilities Plugin" [Active]
org.eclipse.tptp.platform.collection.framework (4.0.0) "TPTP Collection
org.eclipse.tptp.platform.core.source (4.0.1) "TPTP Core Source" [Resolved]
org.eclipse.tptp.platform.doc.user (4.0.0) "TPTP Platform Project
org.eclipse.tptp.platform.log.views (4.0.0) "Hyades Logging Sequence
Diagrams" [Resolved]
org.eclipse.tptp.platform.lta.source (4.0.0) "TPTP Log and Trace Analyzer
Source" [Resolved]
org.eclipse.tptp.platform.models (4.0.0) "Hyades Models" [Active]
org.eclipse.tptp.platform.probekit.source (4.0.1) "TPTP ProbeKit Source"
[Resolved]
org.eclipse.tptp.platform.report.core (4.0.0) "TPTP Report Framework"
[Resolved]
org.eclipse.tptp.platform.report.source (4.0.0) "TPTP Charting Service
Source" [Resolved]
org.eclipse.tptp.platform.report.ui (4.0.0) "TPTP Report UI" [Resolved]
org.eclipse.tptp.platform.samples.source (4.0.0) "TPTP Platform Samples
Source" [Resolved]
org.eclipse.tptp.platform.statistical.ui.source (4.0.1) "TPTP Statistical
UI Source" [Resolved]
org.eclipse.tptp.platform.trace.source (4.0.0) "TPTP Platform Trace
Source" [Resolved]
org.eclipse.tptp.test.samples (4.0.0) "TPTP Test Tools UI Plug-In"
[Resolved]
org.eclipse.tptp.test.samples.source (4.0.0) "TPTP Test Samples Source"
[Resolved]
org.eclipse.tptp.test.source (4.0.1) "TPTP Test Source" [Resolved]
org.eclipse.tptp.test.tools.source (4.0.1) "TPTP Test Tools Source"
[Resolved]
org.eclipse.tptp.trace.source (4.0.0) "TPTP Trace Source" [Resolved]
org.eclipse.ui (3.2.0.I20051214-1200) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20051117) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.2.0.v20051213) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20051214b) "Console" [Active]
org.eclipse.ui.editors (3.2.0.v20051214-0800) "Default Text Editor"
[Active]
org.eclipse.ui.externaltools (3.1.0.v20051205) "External Tools" [Active]
org.eclipse.ui.forms (3.2.0.v20051213) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.0.I20051214-1200) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.0.v20051212) "Welcome Framework" [Resolved]
org.eclipse.ui.navigator (3.2.0.I20051215-1200) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.0.I20051215-1200) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20051212-0010) "R21 Presentation
Plug-in" [Resolved]
org.eclipse.ui.views (3.2.0.I20051129-0800) "Views" [Active]
org.eclipse.ui.workbench (3.2.0.I20051214-1200) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20051212-0010) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20051214-0800) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.1.100.v20051214) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.1.100.v20051215a) "Install/Update Core" [Active]
org.eclipse.update.core.linux (3.1.100.v20051205) "Install/Update Core for
Linux" [Resolved]
org.eclipse.update.scheduler (3.1.100) "Automatic Updates Scheduler"
[Active]
org.eclipse.update.ui (3.1.100.v20051215) "Install/Update UI" [Active]
org.eclipse.wst.common.ui.properties (1.0.0) "Common Properties UI"
[Resolved]
org.eclipse.xsd (2.2.0) "XML Schema Infoset Model (XSD)" [Resolved]
org.eclipse.xsd.doc (2.2.0) "XML Schema Infoset Model (XSD) Programmers
Guide" [Resolved]
org.eclipse.xsd.ecore.exporter (2.2.0) "XML Schema Exporter for EMF"
[Resolved]
org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF"
[Installed]
org.eclipse.xsd.ecore.importer (2.2.0) "XML Schema Importer for EMF"
[Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.2.0) "XML Schema Editor" [Resolved]
org.eclipse.xsd.source (2.2.0) "XML Schema Infoset Model (XSD) Source"
[Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
system.bundle (3.2.0.v20051212a) "OSGi System Bundle" [Active]
Re: TPTP crashes before run... [message #57174 is a reply to message #56954] Thu, 09 March 2006 17:27 Go to previous messageGo to next message
What kind of test suite did you created?
I quickly tested this with TPTP-4.2.0-200602281515 (which is dependent on
*M5a*) and couldn't reproduce the problem.
What specific TPTP driver are you using? If it's an older 4.2.0 driver,
then update it to the one above (and update the dependecies).
"kiril mitov" <kiril_mitov@abv.bg> wrote in message
news:a512a8ec8d031a7d3771c171ea888548$1@www.eclipse.org...
> at
xtensionsManager.getExtensionDescriptor(LaunchConfigurationE xtensionsManager
..java:68)
> at
xtensionsManager.registerRunHandlers(LaunchConfigurationExte nsionsManager.ja
va:233)
> at
xtensionsManager.<init>(LaunchConfigurationExtensionsManager.java:54)
> at
xtensionsManager.getInstance(LaunchConfigurationExtensionsMa nager.java:45)
> at
tRunnableItemFromElement(LaunchPropertyTester.java:101)
> at
> at
..java:65)
> at
> at
ession.java:108)
> at
> at
..java:42)
> at
> at
> at
valEnablementExpression(LaunchShortcutExtension.java:226)
> at
> at
hAction.java:184)
> at
> at
> Method)
> at
> at
java:109)
> at
> at
pLauncher.java:68)
> at
> at
Re: TPTP crashes before run... [message #57199 is a reply to message #57174] Fri, 10 March 2006 04:24 Go to previous messageGo to next message
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:duqa66$qn6$1@utils.eclipse.org...
> on
Yes, I am using exactly that combination, i.e.:
Eclipse 3.2M5a
emf-sdo-SDK-2.1.0
xsd-SDK-2.1.0
The error msg. in the log seems to indicate some log4j configuration or
version problem:
!MESSAGE Exception occurred starting application server.
!STACK 0
org.apache.commons.logging.LogConfigurationException:
org.apache.commons.logging.LogConfigurationException: Class
org.apache.commons.logging.impl.Log4JLogger does not implement Log
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:532)
org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:272)
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java :414)
at org.apache.commons.digester.Digester.<init>(Digester.java:346)
Caused by: org.apache.commons.logging.LogConfigurationException:
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:416)
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:525)
... 47 more
Caused by: org.apache.commons.logging.LogConfigurationException: Class
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:412)
... 48 more
Any ideas or hints on that?
Michael
Re: TPTP crashes before run... [message #57224 is a reply to message #57199] Fri, 10 March 2006 04:25 Go to previous messageGo to next message
ooops - wrong thread - please ignore...
Re: TPTP crashes before run... [message #57409 is a reply to message #57174] Fri, 10 March 2006 11:42 Go to previous message
Sorry - suppose I have made a mistake when downloading.
I have downloaded
TPTP-4.2.0-200512011334D
and now everything seems to be working just fine...:)
Previous Topic:Swing
Next Topic:TpTp4.1 : data collection Problem
Current Time: Tue Jul 22 02:49:53 EDT 2025
Powered by FUDForum. Page generated in 0.07975 seconds
