Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP crashes before run...
TPTP crashes before run... [message #56954] |
Thu, 09 March 2006 10:11  |
I have created a new testsuite file.
Whe clicking with the right button on the file and selection Run As... the
following error occures:
I use elipse3.2 M4 64 bit, with sun-jdk 1.5.0.06
Should i report this as a bug or the problem might be with me...
java.lang.NoClassDefFoundError: org/eclipse/core/internal/runtime/Assert
org.eclipse.hyades.test.core.internal.launch.extensions.Laun chConfigurationExtensionsManager.getExtensionDescriptor(Laun chConfigurationExtensionsManager.java:68)
org.eclipse.hyades.test.core.internal.launch.extensions.Laun chConfigurationExtensionsManager.registerRunHandlers(LaunchC onfigurationExtensionsManager.java:233)
org.eclipse.hyades.test.core.internal.launch.extensions.Laun chConfigurationExtensionsManager. <init>(LaunchConfigurationExtensionsManager.java:54)
org.eclipse.hyades.test.core.internal.launch.extensions.Laun chConfigurationExtensionsManager.getInstance(LaunchConfigura tionExtensionsManager.java:45)
org.eclipse.hyades.test.ui.internal.launch.shortcuts.LaunchP ropertyTester.getRunnableItemFromElement(LaunchPropertyTeste r.java:101)
org.eclipse.hyades.test.ui.internal.launch.shortcuts.LaunchP ropertyTester.test(LaunchPropertyTester.java:56)
at org.eclipse.core.internal.expressions.Property.test(Property .java:52)
org.eclipse.core.internal.expressions.TestExpression.evaluat e(TestExpression.java:65)
org.eclipse.core.internal.expressions.CompositeExpression.ev aluateAnd(CompositeExpression.java:48)
org.eclipse.core.internal.expressions.IterateExpression.eval uate(IterateExpression.java:108)
org.eclipse.core.internal.expressions.WithExpression.evaluat e(WithExpression.java:42)
org.eclipse.core.internal.expressions.EnablementExpression.e valuate(EnablementExpression.java:29)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchSho rtcutExtension.evalEnablementExpression(LaunchShortcutExtens ion.java:226)
org.eclipse.debug.ui.actions.ContextualLaunchAction.isApplic able(ContextualLaunchAction.java:270)
org.eclipse.debug.ui.actions.ContextualLaunchAction.fillMenu (ContextualLaunchAction.java:184)
org.eclipse.debug.ui.actions.ContextualLaunchAction$1.menuSh own(ContextualLaunchAction.java:131)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:117)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1059)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1083)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1064)
at org.eclipse.swt.widgets.Menu.gtk_show(Menu.java:581)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1372)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3692 )
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive
Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1344)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2741)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1762)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1726)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:397)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:109)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: TPTP crashes before run... [message #57014 is a reply to message #56954] |
Thu, 09 March 2006 10:16   |
This is the configuration of my eclipse...
*** Date: Thu Mar 09 17:13:10 EET 2006
*** Platform Details:
*** System properties:
catalina.base=/home/kiril/local/eclipse3.2M4_64/eclipse/plug ins/org.eclipse.tomcat_4.1.130.v20051212/
catalina.home=/home/kiril/local/eclipse3.2M4_64/eclipse/plug ins/org.eclipse.tomcat_4.1.130.v20051212/
catalina.useNaming=true
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I20051215-1506
eclipse.commands=-os
linux
-ws
gtk
-arch
x86_64
-launcher
/home/kiril/local/eclipse3.2M4_64/eclipse/eclipse
-name
Eclipse
-showsplash
600
-exitdata
318013
-vm
/opt/sun-jre-bin-1.5.0.06/bin/java
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1141915888886
eclipse.vm=/opt/sun-jre-bin-1.5.0.06/bin/java
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
/home/kiril/local/eclipse3.2M4_64/eclipse/startup.jar
eof=eof
file.encoding=ANSI_X3.4-1968
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/home/kiril/local/eclipse3.2M4_64/eclipse/st artup.jar
java.class.version=49.0
java.endorsed.dirs=/opt/sun-jre-bin-1.5.0.06/lib/endorsed
java.ext.dirs=/opt/sun-jre-bin-1.5.0.06/lib/ext
java.home=/opt/sun-jre-bin-1.5.0.06
java.io.tmpdir=/tmp
java.library.path=/opt/sun-jre-bin-1.5.0.06/lib/amd64/server :/opt/sun-jre-bin-1.5.0.06/lib/amd64:/opt/sun-jre-bin-1.5.0. 06/../lib/amd64:/usr/lib64/mozilla
java.naming.factory.initial=org.apache.naming.java.javaURLCo ntextFactory
java.naming.factory.url.pkgs=org.apache.naming
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.15-gentoo-r5
org.osgi.framework.processor=amd64
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=amd64
os.name=Linux
osgi.arch=x86_64
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.core.jobs@2:start, org.eclipse.equinox.registry@2:start,
org.eclipse.equinox.preferences, org.eclipse.core.contenttype,
org.eclipse.core.runtime@2:start, org.eclipse.update.configurator@3:start
osgi.bundlestore=/home/kiril/local/eclipse3.2M4_64/eclipse/c onfiguration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/home/kiril/local/eclipse3.2M4_ 64/eclipse/configuration/
osgi.framework=file:/home/kiril/local/eclipse3.2M4_64/eclips e/plugins/org.eclipse.osgi_3.2.0.v20051212a.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.0.v20051212a
osgi.install.area=file:/home/kiril/local/eclipse3.2M4_64/ecl ipse/
osgi.instance.area=file:/home/kiril/work/workspace/
osgi.instance.area.default=file:/home/kiril/workspace/
osgi.logfile=/home/kiril/work/workspace/.metadata/.log
osgi.manifest.cache=/home/kiril/local/eclipse3.2M4_64/eclips e/configuration/org.eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.splashLocation=/home/kiril/local/eclipse3.2M4_64/eclips e/plugins/org.eclipse.platform_3.2.0.v20051213/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/home/kiril/local/eclipse3.2M4_64/eclipse/plugi ns
osgi.ws=gtk
path.separator=:
sun.arch.data.model=64
sun.boot.class.path=/opt/sun-jre-bin-1.5.0.06/lib/rt.jar:/op t/sun-jre-bin-1.5.0.06/lib/i18n.jar:/opt/sun-jre-bin-1.5.0.0 6/lib/sunrsasign.jar:/opt/sun-jre-bin-1.5.0.06/lib/jsse.jar: /opt/sun-jre-bin-1.5.0.06/lib/jce.jar:/opt/sun-jre-bin-1.5.0 .06/lib/charsets.jar:/opt/sun-jre-bin-1.5.0.06/classes
sun.boot.library.path=/opt/sun-jre-bin-1.5.0.06/lib/amd64
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=gnome
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=ANSI_X3.4-1968
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/home/kiril
user.home=/home/kiril
user.language=en
user.name=kiril
user.timezone=Europe/Sofia
*** Features:
org.eclipse.jdt (3.2.0.v20051212-0800-05frhQbfqg) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.0.200512151515--EADAM88GP) "Eclipse Java
Development Tools SDK"
org.eclipse.pde (3.2.0.v20051114--mPWQsJJez) "Eclipse Plug-in Development
Environment"
org.eclipse.pde.source (3.2.0.v20051114--mPWQsJJez) "Eclipse Plug-in
Development Environment Developer Resources"
org.eclipse.platform (3.2.0.v20051214-5wrXvetwgj) "Eclipse Platform"
org.eclipse.platform.source (3.2.0.200512151514-0hy9xshiQ6) "Eclipse
Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.0.v20051128-30i-kzVN5X) "Eclipse RCP"
org.eclipse.rcp.source (3.2.0.v20051128-30i-kzVN5X) "Eclipse RCP Plug-in
org.eclipse.sdk (3.2.0.v20051121--fXTSkTJY9) "Eclipse Project SDK"
*** Plug-in Registry:
antlr (2.7.2) "ANTLR Plug-in" [Resolved]
com.ibm.icu (3.4.2) "International Components for Unicode for Java
(ICU4J)" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.batik (1.6.0) "Apache Batik" [Resolved]
org.apache.batik (1.5.1) "SVG Batik Toolkit" [Resolved]
org.apache.jakarta_commons_logging (1.0.3) "Jakarta Commons Logging"
[Resolved]
org.apache.jakarta_log4j_logging (1.2.8) "Jakarta Log4J Logging" [Resolved]
org.apache.lucene (1.4.103.v20051212) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20051205) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.100.v20051205) "Ant UI" [Resolved]
org.eclipse.compare (3.2.0.v20051213) "Compare Support" [Active]
org.eclipse.core.boot (3.1.0.v20051108) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20051212-2000) "Commands" [Active]
org.eclipse.core.contenttype (3.2.0.v20051208) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.expressions (3.2.0.v20051212-0800) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.2.0.v20051214-0800) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20051208) "Core File Systems"
[Resolved]
org.eclipse.core.filesystem.linux.x86_64 (1.0.0.v20051114) "Core File
System for Linux" [Resolved]
org.eclipse.core.jobs (3.2.0.v20051208) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.0.v20051208) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.0.v20051128) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20051208) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0.v200511211912) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.variables (3.1.100.v20051128) "Core Variables" [Resolved]
org.eclipse.debug.core (3.2.0.v20051215a) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.v20051215a) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.2.0) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.2.0) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Installed]
org.eclipse.emf.codegen.ecore (2.2.0) "EMF Ecore Code Generation"
[Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.2.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.common.ui (2.2.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.0) "EMF Model Convert Support" [Resolved]
org.eclipse.emf.doc (2.2.0) "Eclipse Modeling Framework (EMF) Programmers
Guide" [Resolved]
org.eclipse.emf.ecore (2.2.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.0) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.2.0) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.2.0) "Sample Ecore Editor" [Resolved]
org.eclipse.emf.ecore.sdo (2.2.0) "EMF Service Data Objects (SDO)"
[Resolved]
org.eclipse.emf.ecore.sdo.doc (2.2.0) "EMF Service Data Objects (SDO)
Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO)
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
org.eclipse.emf.ecore.sdo.source (2.2.0) "EMF Service Data Objects (SDO)
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.0) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.0) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0) "EMF Model Export Support" [Resolved]
org.eclipse.emf.importer (2.2.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.2.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.2.0) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.2.0) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.2.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.2.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.ocl (1.0.0) "Eclipse Modeling Framework Technology OCL
Interpreter" [Resolved]
org.eclipse.emf.query (1.0.0) "Eclipse Modeling Framework Technology Query
Framework" [Resolved]
org.eclipse.emf.query.ocl (1.0.0) "Eclipse Modeling Framework Technology
Query OCL" [Resolved]
org.eclipse.emf.source (2.2.0) "Eclipse Modeling Framework (EMF) Source"
[Resolved]
org.eclipse.emf.validation (1.0.0) "Eclipse Modeling Framework Technology
Model Validation Core" [Resolved]
org.eclipse.emf.validation.ocl (1.0.0) "Eclipse Modeling Framework
Technology Validation Support for OCL" [Resolved]
org.eclipse.emf.validation.ui (1.0.0) "Eclipse Modeling Framework
Technology Validation UI" [Resolved]
org.eclipse.emf.validation.ui.ide (1.0.0) "Eclipse Modeling Framework
Technology Validation UI IDE" [Resolved]
org.eclipse.equinox.common (1.0.0.v20051205) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (1.0.0.v20051211) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (1.0.0.v20051214a) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.0) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.2.0) "Graphical Editing Framework
org.eclipse.gef.examples.flow (3.2.0) "GEF Flow Editor Example" [Resolved]
org.eclipse.gef.examples.logic (3.2.0) "GEF Logic Editor Example"
[Resolved]
org.eclipse.gef.examples.shapes (3.2.0) "GEF Shape Editor Example"
[Resolved]
org.eclipse.gef.examples.source (3.2.0) "GEF Examples" [Resolved]
org.eclipse.gef.examples.text (3.2.0) "GEF Text Editor Example" [Resolved]
org.eclipse.gef.source (3.2.0) "Graphical Editing Framework Developer
Resources" [Resolved]
org.eclipse.gmf (1.0.0) "Graphical Modeling Framework" [Resolved]
org.eclipse.gmf.bridge (1.0.0) "GMF Models Bridging Plug-in" [Resolved]
org.eclipse.gmf.codegen (1.0.0) "GMF GenModel and Code Generation"
[Resolved]
org.eclipse.gmf.codegen.edit (1.0.0) "GMF GenModel Edit Support" [Resolved]
org.eclipse.gmf.codegen.ui (1.0.0) "GMF Code Generation UI" [Resolved]
org.eclipse.gmf.graphdef (1.0.0) "GMF Graphical Definition" [Resolved]
org.eclipse.gmf.graphdef.codegen (1.0.0) "Graphical Definition Code
org.eclipse.gmf.graphdef.edit (1.0.0) "GMFGraph Edit Support" [Resolved]
org.eclipse.gmf.map (1.0.0) "GMF Mapping Model" [Resolved]
org.eclipse.gmf.map.edit (1.0.0) "GMF Mapping Edit Support" [Resolved]
org.eclipse.gmf.runtime.common.core (1.0.0) "GMF Common Core" [Resolved]
org.eclipse.gmf.runtime.common.ui (1.0.0) "GMF Common UI" [Resolved]
org.eclipse.gmf.runtime.common.ui.action (1.0.0) "GMF Common UI Action"
[Resolved]
org.eclipse.gmf.runtime.common.ui.action.ide (1.0.0) "GMF Common UI Action
IDE" [Resolved]
org.eclipse.gmf.runtime.common.ui.pathvariables.ide (1.0.0) "GMF Path
Variables IDE Plug-in" [Resolved]
org.eclipse.gmf.runtime.common.ui.printing (1.0.0) "GMF Printing"
[Resolved]
org.eclipse.gmf.runtime.common.ui.printing.win32 (1.0.0) "GMF Printing for
Win32" [Resolved]
org.eclipse.gmf.runtime.common.ui.services (1.0.0) "GMF Common UI
Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.action (1.0.0) "GMF Common UI
Action Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.dnd (1.0.0) "GMF Common UI DND
org.eclipse.gmf.runtime.common.ui.services.dnd.ide (1.0.0) "GMF Common UI
DND IDE Services" [Resolved]
org.eclipse.gmf.runtime.common.ui.services.properties (1.0.0) "GMF Common
UI Properties Service Framework" [Resolved]
org.eclipse.gmf.runtime.diagram.core (1.0.0) "GMF Diagram Core" [Resolved]
org.eclipse.gmf.runtime.diagram.ui (1.0.0) "GMF Diagram UI" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.actions (1.0.0) "GMF Diagram Actions"
[Resolved]
org.eclipse.gmf.runtime.diagram.ui.dnd (1.0.0) "GMF Diagram Browse"
[Resolved]
org.eclipse.gmf.runtime.diagram.ui.geoshapes (1.0.0) "GMF Geometric
Shapes" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.printing (1.0.0) "GMF Diagram Printing"
[Resolved]
org.eclipse.gmf.runtime.diagram.ui.printing.render (1.0.0) "GMF Diagram UI
Printing Render Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.properties (1.0.0) "GMF Diagram UI
Properties" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.providers (1.0.0) "GMF Diagram
Providers" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.providers.ide (1.0.0) "GMF Diagram
Providers IDE" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.render (1.0.0) "GMF Diagram UI Render
Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.resources.editor (1.0.0) "GMF Diagram
UI Resources Editor Plug-In" [Resolved]
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide (1.0.0) "GMF IDE
Editor" [Resolved]
org.eclipse.gmf.runtime.draw2d.ui (1.0.0) "GMF Draw2d Additions" [Resolved]
org.eclipse.gmf.runtime.draw2d.ui.render (1.0.0) "GMF Draw2d Image
Rendering Additions" [Resolved]
org.eclipse.gmf.runtime.emf.clipboard.core (1.0.0) "GMF EMF Clipboard
Support" [Resolved]
org.eclipse.gmf.runtime.emf.commands.core (1.0.0) "GMF Commands" [Resolved]
org.eclipse.gmf.runtime.emf.core (1.0.0) "GMF Modeling Service Layer"
[Resolved]
org.eclipse.gmf.runtime.emf.type.core (1.0.0) "GMF EMF Type Core"
[Resolved]
org.eclipse.gmf.runtime.emf.type.ui (1.0.0) "GMF EMF Type UI" [Resolved]
org.eclipse.gmf.runtime.emf.ui (1.0.0) "GMF MSL UI" [Resolved]
org.eclipse.gmf.runtime.emf.ui.properties (1.0.0) "GMF EMF UI Properties
org.eclipse.gmf.runtime.gef.ui (1.0.0) "GMF GEF Additions" [Resolved]
org.eclipse.gmf.runtime.notation (1.0.0) "GMF Notation Model Support"
[Resolved]
org.eclipse.gmf.runtime.notation.edit (1.0.0) "GMF Notation Edit Support"
[Resolved]
org.eclipse.gmf.runtime.notation.providers (1.0.0) "GMF Notation
Metamodel" [Resolved]
org.eclipse.gmf.sdk (1.0.0) "Graphical Modeling Framework SDK" [Resolved]
org.eclipse.gmf.sdk.source (1.0.0) "Graphical Modeling Framework SDK
Developer Resources" [Resolved]
org.eclipse.gmf.source (1.0.0) "Graphical Modeling Framework Runtime
org.eclipse.gmf.tooldef (1.0.0) "GMF Tooling Model" [Resolved]
org.eclipse.gmf.tooldef.edit (1.0.0) "GMF Tooling Edit Support" [Resolved]
org.eclipse.help (3.2.0.v20051215) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20051212) "Help Application Server"
[Active]
org.eclipse.help.base (3.2.0.v20051215) "Help System Base" [Active]
org.eclipse.help.ui (3.2.0.v20051213) "Help System UI" [Active]
org.eclipse.help.webapp (3.2.0.v20051212) "Help System Webapp" [Active]
org.eclipse.hyades.analysis.engine (4.0.0) "Hyades Analysis Engine"
[Resolved]
org.eclipse.hyades.execution (4.0.0) "TPTP Platform Execution Plug-In"
[Active]
org.eclipse.hyades.execution.correlation (4.0.0) "Hyades Runtime
Correlation Engine" [Resolved]
org.eclipse.hyades.execution.trace (4.0.0) "Hyades Execution Trace"
[Resolved]
org.eclipse.hyades.logging.adapter (4.0.1) "TPTP Monitoring Project
Generic Log Adapter" [Resolved]
org.eclipse.hyades.logging.adapter.ui (4.0.0) "Generic Adapter UI"
[Resolved]
org.eclipse.hyades.logging.core (4.0.0) "Hyades Logging Agent, Common Base
Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.core.sample (4.0.0) "Sample for Hyades Logging
Agent, Common Base Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.parsers (4.0.0) "TPTP Monitoring Project Log
File Parsers" [Resolved]
org.eclipse.hyades.perfmon (4.0.0) "Perfmon StatCon Module" [Resolved]
org.eclipse.hyades.probekit (4.0.1) "Hyades Probekit" [Resolved]
org.eclipse.hyades.probekit.doc.user (4.0.0) "Probekit User Documentation"
[Resolved]
org.eclipse.hyades.probekit.ui (4.0.1) "Probe Editor" [Resolved]
org.eclipse.hyades.resources.database (4.0.0) "Hyades Core Resource
Extensions" [Resolved]
org.eclipse.hyades.sdb (4.0.0) "Symptom Database tool" [Resolved]
org.eclipse.hyades.statistical.ui (4.0.1) "Statistical Analysis" [Active]
org.eclipse.hyades.test.core (4.0.0) "TPTP Test Core Plug-In" [Active]
org.eclipse.hyades.test.doc.user (4.0.0) "Test Tools user documentation"
[Resolved]
org.eclipse.hyades.test.tools.core (4.0.1) "TPTP Test Tools Core Plug-In"
[Active]
org.eclipse.hyades.test.tools.ui (4.0.1) "TPTP Test Tools UI Plug-In"
[Active]
org.eclipse.hyades.test.ui (4.0.1) "TPTP Test UI Plug-In" [Active]
org.eclipse.hyades.trace.sample (4.0.0) "Samples for the TPTP Monitoring
Tools Plugins" [Resolved]
org.eclipse.hyades.trace.ui (4.0.0) "Hyades Trace Core UI" [Active]
org.eclipse.hyades.trace.views (4.0.0) "Hyades Trace Views Plugin"
[Resolved]
org.eclipse.hyades.ui (4.0.1) "Hyades UI" [Active]
org.eclipse.jdt (3.2.0.v20051213) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.core (3.2.0.v_631) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.0.0.v20051214-0800) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.2.0.v20051214c) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.0.v20051214c) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.2.0.v20051213-0000) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20051212-0800) "Eclipse Java Development
User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.0.v20051212-0800) "Java Development Tools JUnit
support" [Active]
org.eclipse.jdt.junit.runtime (3.2.0.v20051212-0800) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.0.v20051213) "Java Development Tools
Launching Support" [Active]
org.eclipse.jdt.source (3.2.0.v20051212-0800-05frhQbfqg) "Eclipse Java
Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.0.v20051215-0910) "Java Development Tools UI"
[Active]
org.eclipse.jface (3.2.0.I20051214-0010) "JFace" [Active]
org.eclipse.jface.databinding (3.2.0.I20051212-0010) "JFace Data Binding"
[Resolved]
org.eclipse.jface.text (3.2.0.v20051214-0800) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.2.0.v20051214-0800) "Refactoring Core"
[Active]
org.eclipse.ltk.ui.refactoring (3.2.0.v20051214-0800) "Refactoring UI"
[Active]
org.eclipse.osgi.services (3.1.100.v20051205) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20051205) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.0.v20051213) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.0.v20051212) "Plug-in Development Environment
Build Support" [Resolved]
org.eclipse.pde.core (3.2.0.v20051215-1200) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.1.0.v20051122) "Eclipse Plug-in Development
org.eclipse.pde.junit.runtime (3.2.0.v20051206) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20051206) "Plug-in Development Environment
Runtime" [Active]
Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.0.v20051215-1500) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.0.v20051213) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.0.v20051214-1415) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.0.v20051213-1750) "Eclipse Workbench
org.eclipse.platform.source (3.2.0.v20051214-5wrXvetwgj) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.linux.gtk.x86_64 (3.2.0.v20051214-5wrXvetwgj)
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.2.0.v20051206) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source.linux.gtk.x86_64 (3.2.0.v20051128-30i-kzVN5X)
"Eclipse RCP Plug-in Developer Resources" [Resolved]
org.eclipse.sdk (3.2.0.I20051206-0800) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.0.v20051212-0800) "Search Support" [Resolved]
org.eclipse.swt (3.2.0.v3218f) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.linux.x86_64 (3.2.0.v3218) "Standard Widget Toolkit
for GTK 2.0" [Resolved]
org.eclipse.team.core (3.2.0.I20051213) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.0.I20051212-1600) "CVS Team Provider Core"
[Active]
org.eclipse.team.cvs.ssh (3.2.0.I20051128) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I20051128) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.2.0.I20051213) "CVS Team Provider UI" [Active]
org.eclipse.team.ui (3.2.0.I20051213) "Team Support UI" [Active]
org.eclipse.text (3.1.100.v20051212-0800) "Text" [Active]
org.eclipse.tomcat (4.1.130.v20051212) "Tomcat Wrapper" [Active]
org.eclipse.tptp.monitoring.doc.user (4.0.0) "TPTP Monitoring Tools
org.eclipse.tptp.monitoring.logui (4.0.0) "Logui Plug-in" [Resolved]
org.eclipse.tptp.monitoring.source (4.0.1) "TPTP Monitoring Source"
[Resolved]
org.eclipse.tptp.platform.agentcontroller (4.0.1) "TPTP Agent Controller"
[Resolved]
org.eclipse.tptp.platform.agentcontroller.doc.user (4.0.0) "Agent
Controller documentation" [Resolved]
org.eclipse.tptp.platform.analysis.engine.source (4.0.0) "TPTP Analysis
Engine Source" [Resolved]
org.eclipse.tptp.platform.analysis.examples (4.0.1) "TPTP Static Analysis
Examples Plug-in" [Active]
org.eclipse.tptp.platform.analysis.metrics (4.0.0) "Metrics Plug-in"
[Resolved]
org.eclipse.tptp.platform.analysis.source (4.0.1) "TPTP Analysis Feature
Source" [Resolved]
org.eclipse.tptp.platform.analysis.static.doc.user (4.0.1) "Static
Analysis User Documentation" [Resolved]
org.eclipse.tptp.platform.analysis.static.engine (4.0.0) "TPTP Static
Analysis Engine Plugin" [Active]
org.eclipse.tptp.platform.analysis.static.engine.ui (4.0.0) "TPTP Static
Analysis Engine UI Plugin" [Active]
org.eclipse.tptp.platform.analysis.static.util (4.0.0) "TPTP Static
Analysis Utilities Plugin" [Active]
org.eclipse.tptp.platform.analysis.static.util.ui (4.0.1) "TPTP Analysis
UI Utilities Plugin" [Active]
org.eclipse.tptp.platform.collection.framework (4.0.0) "TPTP Collection
org.eclipse.tptp.platform.core.source (4.0.1) "TPTP Core Source" [Resolved]
org.eclipse.tptp.platform.doc.user (4.0.0) "TPTP Platform Project
org.eclipse.tptp.platform.log.views (4.0.0) "Hyades Logging Sequence
Diagrams" [Resolved]
org.eclipse.tptp.platform.lta.source (4.0.0) "TPTP Log and Trace Analyzer
Source" [Resolved]
org.eclipse.tptp.platform.models (4.0.0) "Hyades Models" [Active]
org.eclipse.tptp.platform.probekit.source (4.0.1) "TPTP ProbeKit Source"
[Resolved]
org.eclipse.tptp.platform.report.core (4.0.0) "TPTP Report Framework"
[Resolved]
org.eclipse.tptp.platform.report.source (4.0.0) "TPTP Charting Service
Source" [Resolved]
org.eclipse.tptp.platform.report.ui (4.0.0) "TPTP Report UI" [Resolved]
org.eclipse.tptp.platform.samples.source (4.0.0) "TPTP Platform Samples
Source" [Resolved]
org.eclipse.tptp.platform.statistical.ui.source (4.0.1) "TPTP Statistical
UI Source" [Resolved]
org.eclipse.tptp.platform.trace.source (4.0.0) "TPTP Platform Trace
Source" [Resolved]
org.eclipse.tptp.test.samples (4.0.0) "TPTP Test Tools UI Plug-In"
[Resolved]
org.eclipse.tptp.test.samples.source (4.0.0) "TPTP Test Samples Source"
[Resolved]
org.eclipse.tptp.test.source (4.0.1) "TPTP Test Source" [Resolved]
org.eclipse.tptp.test.tools.source (4.0.1) "TPTP Test Tools Source"
[Resolved]
org.eclipse.tptp.trace.source (4.0.0) "TPTP Trace Source" [Resolved]
org.eclipse.ui (3.2.0.I20051214-1200) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20051117) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.2.0.v20051213) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20051214b) "Console" [Active]
org.eclipse.ui.editors (3.2.0.v20051214-0800) "Default Text Editor"
[Active]
org.eclipse.ui.externaltools (3.1.0.v20051205) "External Tools" [Active]
org.eclipse.ui.forms (3.2.0.v20051213) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.0.I20051214-1200) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.0.v20051212) "Welcome Framework" [Resolved]
org.eclipse.ui.navigator (3.2.0.I20051215-1200) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.0.I20051215-1200) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20051212-0010) "R21 Presentation
Plug-in" [Resolved]
org.eclipse.ui.views (3.2.0.I20051129-0800) "Views" [Active]
org.eclipse.ui.workbench (3.2.0.I20051214-1200) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20051212-0010) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20051214-0800) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.1.100.v20051214) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.1.100.v20051215a) "Install/Update Core" [Active]
org.eclipse.update.core.linux (3.1.100.v20051205) "Install/Update Core for
Linux" [Resolved]
org.eclipse.update.scheduler (3.1.100) "Automatic Updates Scheduler"
[Active]
org.eclipse.update.ui (3.1.100.v20051215) "Install/Update UI" [Active]
org.eclipse.wst.common.ui.properties (1.0.0) "Common Properties UI"
[Resolved]
org.eclipse.xsd (2.2.0) "XML Schema Infoset Model (XSD)" [Resolved]
org.eclipse.xsd.doc (2.2.0) "XML Schema Infoset Model (XSD) Programmers
Guide" [Resolved]
org.eclipse.xsd.ecore.exporter (2.2.0) "XML Schema Exporter for EMF"
[Resolved]
org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF"
[Installed]
org.eclipse.xsd.ecore.importer (2.2.0) "XML Schema Importer for EMF"
[Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.2.0) "XML Schema Editor" [Resolved]
org.eclipse.xsd.source (2.2.0) "XML Schema Infoset Model (XSD) Source"
[Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
system.bundle (3.2.0.v20051212a) "OSGi System Bundle" [Active]
Current Time: Fri Jul 25 00:43:41 EDT 2025
Powered by FUDForum. Page generated in 0.07286 seconds
