Home » Language IDEs » C / C++ IDE (CDT) » CDT Debugging
CDT Debugging [message #56939] Tue, 07 January 2003 06:11 Go to next message
Originally posted by: erwin.de.ley.tuple.be
I am using CDT 1.0.1 org.eclipse.cdt-200212181146-win32_1.0.1.bin.dist.zip
in combination with eclipse 2.1 (eclipse-SDK-N20021115-win32.zip) on
Win2K, which is not an officially supported combination. I use
cygwin-1.3.18-1 with gcc-3.2-3 and gdb-20021218-1.
Editing and building works fine (after changing the build command in the
C-project-properties screen to something like
"C:\ProgramFiles\cygwin\bin\make.exe -f makefile").
Plain execution also works fine, even when referring to an executable in a
bin folder of the C project (e.g. putting "bin/dbc_ecs.exe" in the C/C++
application field of the "main" tab in the run configuration), and even
using a non-default working directory (e.g. referring to the bin project
sub-folder in the workspace).
The only thing I can't manage to get working is debugging, and apparently
many users have this same problem, also when using eclipse 2.0.x. I get
the same behaviour as mentioned in previous postings:
- when using the default debug settings:
cygwin GDB Debugger;
Run program in debugger
Stop at main() in startup
MI debugger: gdb
Load shared library ... NOT checked
=> result is alert :
"Unable to set temporary breakpoint in main.
Reason: No symbol table is loaded. Use the "file" command.
Continue?"
Log file info:
!SESSION Jan 07, 2003 12:20:38.387
java.version=1.3.1_05
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/ProgramFiles/eclipse/
!ENTRY org.eclipse.debug.ui 4 120 Jan 07, 2003 12:20:38.387
!MESSAGE Error logged from Debug UI:
!STACK 1
org.eclipse.debug.core.DebugException: No symbol table is loaded. Use the
"file" command.
at org.eclipse.cdt.debug.core.CDebugModel.stopInMain(CDebugMode l.java:468)
org.eclipse.cdt.debug.core.CDebugModel.newDebugTarget(CDebug Model.java:142)
org.eclipse.cdt.launch.internal.LocalCLaunchConfigurationDel egate.launch(LocalCLaunchConfigurationDelegate.java:101)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:144)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationDialog$11.run(LaunchConfigurationDialog.java:2283)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:95)
!ENTRY org.eclipse.cdt.debug.core 0 5010 Jan 07, 2003 12:20:38.417
!MESSAGE No symbol table is loaded. Use the "file" command.
- when trying the commands specified by Mikhael below straight in cygwin,
I get the same response as Michael (see below).
HEEELP!
Erwin.
Related postings:
Subject: Re: problem with step over debugging
Newsgroups: eclipse.tools.cdt
Organization: EclipseCorner
Date: Jan 02 2003 19:20:43
The response is:
&"Not symbol table is loaded. Use the \"file\" command. \n"
"Mikhail Khodjaiants" <mikhailk@qnx.com> wrote in message
news:av27gu$rob$1@rogue.oti.com...
> Please, try this:
> 1. start gdb with '-i mi' option
> 2. type '-gdb-set auto-solib-add off' and press Enter
Re: CDT Debugging [message #56996 is a reply to message #56939] Tue, 07 January 2003 10:01 Go to previous messageGo to next message
Originally posted by: bangham.neocera.com
I've been struggling against this issue for about 2 weeks - would love to
get this working as Eclipse is a really nice environment. I'm sure someone
out there has gotten this to work, but perhaps they have not seen these
recent postings/pleas on the subject.
Michael
"Erwin" <erwin.de.ley@tuple.be> wrote in message
news:aveclq$phl$1@rogue.oti.com...
> MI debugger: gdb
> Continue?"
> Log file info:
> !STACK 1
> "file" command.
> at
> at
> at
on.java:144)
> at
> at
..java:95)
> HEEELP!
> Erwin.
> Related postings:
> From: bangham@neocera.com (Michael)
> The response is:
> > Please, try this:
Re: CDT Debugging [message #57022 is a reply to message #56939] Tue, 07 January 2003 11:23 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
Did you compile your executable with '-g' option?
> MI debugger: gdb
> Continue?"
> Log file info:
> !STACK 1
> "file" command.
> at
> at
> at
on.java:144)
> at
> at
..java:95)
> HEEELP!
> Erwin.
> Related postings:
> The response is:
> > Please, try this:
Re: CDT Debugging [message #57049 is a reply to message #56996] Tue, 07 January 2003 11:33 Go to previous messageGo to next message
Please, create a new simple project, compile it with '-g' and try to debug
it. Use 'Cygwin GDB debugger' and don't check the 'Automatically load shared
libraries' option. If this doesn't work post your project and I'll check it.
Mikhail
"Michael" <bangham@neocera.com> wrote in message
news:avep9s$3bm$1@rogue.oti.com...
someone
> Michael
> > Hi,
a
apparently
> > MI debugger: gdb
> > Continue?"
> > Log file info:
> > !STACK 1
the
> > "file" command.
> > at
> > at
> > at
> > at
> on.java:144)
> > at
> > at
> .java:95)
cygwin,
> > HEEELP!
> > Erwin.
> > Related postings:
> > The response is:
> > > Please, try this:
Re: CDT Debugging [message #57077 is a reply to message #57049] Tue, 07 January 2003 13:28 Go to previous messageGo to next message
Thank you very much! I am using the Cygwin GDB debugger as specified below.
I included a screen shot of my launch config.
news:aveulg$81a$1@rogue.oti.com...
shared
it.
> Mikhail
to
> someone
> > Michael
> > > Hi,
the
in
> a
C/C++
even
project
> apparently
get
> > > MI debugger: gdb
> > > Continue?"
> > > Log file info:
> > > !STACK 1
> the
> > > "file" command.
> > > at
> > > at
> > > at
> > > at
> > on.java:144)
> > > at
> > > at
> > .java:95)
> cygwin,
> > > HEEELP!
> > > Erwin.
> > > Related postings:
> > > The response is:
> > > > Please, try this:
  • Attachment: proj.zip
    (Size: 167.33KB, Downloaded 224 times)
Re: CDT Debugging [message #57129 is a reply to message #56996] Tue, 07 January 2003 20:54 Go to previous messageGo to next message
Originally posted by: javacard.hotmail.com
Hi Michael,
appreciate your work very much :)
actually I've the same feeling as you,I would like to see Eclipse platform
will fulfill all my development requirement someday in future.That's great
environment although it's buggy now.
xusoo
> Michael
> > Hi,
> > MI debugger: gdb
> > Continue?"
> > Log file info:
> > !STACK 1
> > "file" command.
> > at
> > at
> > at
> on.java:144)
> > at
> > at
> ..java:95)
> > HEEELP!
> > Erwin.
> > Related postings:
> > The response is:
> > > Please, try this:
Re: CDT Debugging [message #57157 is a reply to message #57049] Wed, 08 January 2003 04:07 Go to previous messageGo to next message
Hi Mikhael,
I\'ve created a simple HelloWorld project, very similar to the one in the
CDT FAQ. I use -g for compiling and linking and still get the same problem.
I\'ve sent you a mail with a zip file containing my project and the launch
configuration.
Thanks for the work on this plugin!
Erwin
Mikhail Khodjaiants wrote:
> Please, create a new simple project, compile it with \'-g\' and try to debug
> it. Use \'Cygwin GDB debugger\' and don\'t check the \'Automatically load
shared
> libraries\' option. If this doesn\'t work post your project and I\'ll check
it.
> Mikhail
> \"Michael\" <bangham@neocera.com> wrote in message
> > I\'ve been struggling against this issue for about 2 weeks - would love to
> > get this working as Eclipse is a really nice environment. I\'m sure
> someone
> > Michael
> > \"Erwin\" <erwin.de.ley@tuple.be> wrote in message
> > > Hi,
> > > \"C:\\ProgramFiles\\cygwin\\bin\\make.exe -f makefile\").
> a
> > > bin folder of the C project (e.g. putting \"bin/dbc_ecs.exe\" in the
C/C++
> > > application field of the \"main\" tab in the run configuration), and even
> > > The only thing I can\'t manage to get working is debugging, and
> apparently
> > > MI debugger: gdb
> > > \"Unable to set temporary breakpoint in main.
> > > Reason: No symbol table is loaded. Use the \"file\" command.
> > > Continue?\"
> > > Log file info:
> > > !STACK 1
> the
> > > \"file\" command.
> > > at
> > > at
> > > at
> > > at
> > on.java:144)
> > > at
> > > at
> > .java:95)
> > > !MESSAGE No symbol table is loaded. Use the \"file\" command.
> cygwin,
> > > HEEELP!
> > > Erwin.
> > > Related postings:
> > > The response is:
> > > &\"Not symbol table is loaded. Use the \\\"file\\\" command. \\n\"
> > > \"Mikhail Khodjaiants\" <mikhailk@qnx.com> wrote in message
> > > > Please, try this:
> > > > 1. start gdb with \'-i mi\' option
> > > > 2. type \'-gdb-set auto-solib-add off\' and press Enter
Re: CDT Debugging [message #57182 is a reply to message #57077] Wed, 08 January 2003 11:55 Go to previous messageGo to next message
Your makefile is incorrect. You inserted the '-g' option between '-o' and
the output file name. As a result the executable you are trying to debug
doesn't exist in the local file system. The debugger should verify this but
there is a bug in our code.
Fix your makefile and let me know if it works.
Mikhail
news:avf5eb$crt$1@rogue.oti.com...
below.
debug
> shared
> it.
> > Thanks,
> > Mikhail
> to
> > someone
these
> > > Michael
> > > > Hi,
> the
executable
> in
> > a
> C/C++
> even
> project
> > apparently
> get
> > > > MI debugger: gdb
> > > > Continue?"
> > > > Log file info:
> > > > !STACK 1
Use
> > the
> > > > "file" command.
> > > > at
> > > > at
> > > > at
> > > > at
> > > on.java:144)
> > > > at
> > > > at
> > > .java:95)
> > cygwin,
> > > > HEEELP!
> > > > Erwin.
> > > > Related postings:
> > > > The response is:
> > > > > Please, try this:
Re: CDT Debugging [message #57207 is a reply to message #57182] Wed, 08 January 2003 13:14 Go to previous messageGo to next message
The selections on the run menu are still not enabled. I modified the
makefile per your instructions to be:
objects = hello.o
hello : $(objects)
C:/cygwin/bin/g++ -g -o "C:\eclipse\workspace\HelloWorldWithMake\hello"
$(objects)
$(objects) : hello.cpp
C:/cygwin/bin/g++.exe -g -c
"C:\eclipse\workspace\HelloWorldWithMake\hello.cpp"
hello.cpp :
all :
${MAKE} objects
..PHONY : clean
clean :
-del hello.exe $(objects)
news:avhkb4$sm7$1@rogue.oti.com...
but
> Mikhail
> below.
> debug
> > shared
check
> > it.
> > > Thanks,
> > > Mikhail
love
> > to
> > > someone
> these
> > > > Michael
> > > > > Hi,
on
in
> > the
> executable
> > in
> > > a
> > C/C++
> > even
> > project
> > > apparently
I
> > get
> > > > > MI debugger: gdb
> > > > > Continue?"
> > > > > Log file info:
> > > > > !STACK 1
> Use
> > > the
> > > > > "file" command.
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > on.java:144)
> > > > > at
> > > > > at
> > > > .java:95)
> > > cygwin,
> > > > > HEEELP!
> > > > > Erwin.
> > > > > Related postings:
> > > > > The response is:
> > > > > > Please, try this:
Re: CDT Debugging [message #57235 is a reply to message #57207] Wed, 08 January 2003 14:09 Go to previous messageGo to next message
What do you mean by 'The selections on the run menu are still not enabled'?
Did you check if the make was successful?
Can you you send me the .launch file? It is in the
'eclipse\workspace\.metadata\.plugins\org.eclipse.debug.core ' directory.
news:avhp0n$vuv$1@rogue.oti.com...
> objects = hello.o
> hello : $(objects)
> $(objects)
> hello.cpp :
> all :
> ${MAKE} objects
> .PHONY : clean
> clean :
and
> but
> > Mikhail
> > below.
> > debug
load
> > > shared
> check
> > > it.
> > > > Thanks,
> > > > Mikhail
> love
> > > to
sure
> > > > someone
> > these
> > > > > Michael
> > > > > > Hi,
> on
command
> in
> > > the
> > executable
> > > in
> > > > a
the
> > > C/C++
and
> > > even
> > > project
> > > > apparently
2.0.x.
> I
> > > get
> > > > > > MI debugger: gdb
> > > > > > Continue?"
> > > > > > Log file info:
> > > > > > !STACK 1
loaded.
> > Use
> > > > the
> > > > > > "file" command.
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > on.java:144)
> > > > > > at
> > > > > > at
> > > > > .java:95)
12:20:38.417
in
> > > > cygwin,
> > > > > > HEEELP!
> > > > > > Erwin.
> > > > > > Related postings:
> > > > > > The response is:
> > > > > > > Please, try this:
Re: CDT Debugging [message #57287 is a reply to message #57235] Wed, 08 January 2003 15:49 Go to previous messageGo to next message
I deleted the .exe and .o file before I rebuilt. Launch file is attached.
In the debug perspective the run menu has selections like "Step Into", "Step
Over", etc., to control the debugger.
news:avhs6b$2kh$1@rogue.oti.com...
enabled'?
> > objects = hello.o
> > hello : $(objects)
> > $(objects)
> > hello.cpp :
> > all :
> > ${MAKE} objects
> > .PHONY : clean
> > clean :
> and
debug
this
> > but
> > > Mikhail
> > > below.
to
> > > debug
> load
> > > > shared
> > check
> > > > it.
> > > > > Thanks,
> > > > > Mikhail
would
> > love
> > > > to
> sure
> > > > > someone
seen
> > > these
> > > > > > Michael
> > > > > > > Hi,
> > on
> command
> > in
> > > > the
> > > executable
> > > > in
> > > > > a
> the
> > > > C/C++
> and
> > > > even
bin
> > > > project
> > > > > apparently
> 2.0.x.
> > I
> > > > get
> > > > > > > MI debugger: gdb
command.
> > > > > > > Continue?"
> > > > > > > Log file info:
> > > > > > > !STACK 1
> loaded.
> > > Use
> > > > > the
> > > > > > > "file" command.
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > on.java:144)
> > > > > > > at
> > > > > > > at
> > > > > > .java:95)
> 12:20:38.417
> in
> > > > > cygwin,
> > > > > > > HEEELP!
> > > > > > > Erwin.
> > > > > > > Related postings:
> > > > > > > The response is:
> > > > > > > > Please, try this:
Re: CDT Debugging [message #57399 is a reply to message #57157] Wed, 08 January 2003 23:00 Go to previous messageGo to next message
Originally posted by: mikhailkhod.rogers.com
Hi Erwin,
The path of your project contains space character ('HelloWorld C++'). When
CDT starts gdb it passes the full path of the executable as an argument. If
path contains space characters it should be put in quotes, otherwise gdb
accepts only the first part of the path. I will submit bug for this.
Thank you,
Mikhail
news:avgpo1$9tj$1@rogue.oti.com...
> Hi Mikhael,
problem.
> configuration.
> Erwin
debug
load
> shared
check
> it.
> > Thanks,
> > Mikhail
love to
> > someone
these
> > > Michael
> > > > Hi,
the
executable in
> > a
> C/C++
even
project
> > apparently
get
> > > > MI debugger: gdb
> > > > Continue?\"
> > > > Log file info:
> > > > !STACK 1
Use
> > the
> > > > \"file\" command.
> > > > at
> > > > at
> > > > at
> > > > at
> > > on.java:144)
> > > > at
> > > > at
> > > .java:95)
> > cygwin,
> > > > HEEELP!
> > > > Erwin.
> > > > Related postings:
> > > > The response is:
> > > > > Please, try this:
Re: CDT Debugging [message #57425 is a reply to message #57399] Thu, 09 January 2003 03:34 Go to previous messageGo to next message
Mikhael,
Indeed it works fine now, without the space in the project name.
Thanks for the fast diagnosis!
Erwin
> Hi Erwin,
> Thank you,
> Mikhail
> > Hi Mikhael,
> problem.
> > configuration.
> > Regards,
> > Erwin
> debug
> load
> > shared
> check
> > it.
> > > Thanks,
> > > Mikhail
> love to
> > > someone
> these
> > > > Michael
> > > > > Hi,
> the
> executable in
> > > a
> > C/C++
> even
> project
> > > apparently
> get
> > > > > MI debugger: gdb
> > > > > Continue?\"
> > > > > Log file info:
> > > > > !STACK 1
> Use
> > > the
> > > > > \"file\" command.
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > on.java:144)
> > > > > at
> > > > > at
> > > > .java:95)
> > > cygwin,
> > > > > HEEELP!
> > > > > Erwin.
> > > > > Related postings:
> > > > > The response is:
> > > > > > Please, try this:
Re: CDT Debugging [message #57579 is a reply to message #57287] Thu, 09 January 2003 13:42 Go to previous messageGo to next message
What is in your .log file? It is in the 'workspace\.metadata' directory.
Delete it, start your session again and send me the '.log' file.
Mikhail
news:avi21f$6pt$1@rogue.oti.com...
"Step
> enabled'?
> > > objects = hello.o
> > > hello : $(objects)
> > > $(objects)
> > > hello.cpp :
> > > all :
> > > ${MAKE} objects
> > > .PHONY : clean
> > > clean :
'-o'
> > and
> debug
> this
> > > but
> > > > Mikhail
specified
> > > > below.
try
> to
> > > > debug
> > load
> > > > > shared
I'll
> > > check
> > > > > it.
> > > > > > Thanks,
> > > > > > Mikhail
> would
> > > love
> > > > > to
> > sure
> > > > > > someone
> seen
> > > > these
> > > > > > > Michael
> > > > > > > > Hi,
> > > on
use
> > command
> > > in
> > > > > the
> > > > executable
> > > > > in
> > > > > > a
in
> > the
> > > > > C/C++
configuration),
> > and
> > > > > even
> bin
> > > > > project
and
> > > > > > apparently
> > 2.0.x.
> > > I
> > > > > get
> > > > > > > > MI debugger: gdb
> command.
> > > > > > > > Continue?"
> > > > > > > > Log file info:
x86 -install
> > > > > > > > !STACK 1
> > loaded.
> > > > Use
> > > > > > the
> > > > > > > > "file" command.
> > > > > > > > at
> > > > > > > > at
> > > > > > > > at
> > > > > > > > at
> > > > > > > on.java:144)
> > > > > > > > at
> > > > > > > > at
> > > > > > > .java:95)
> > 12:20:38.417
straight
> > in
> > > > > > cygwin,
> > > > > > > > HEEELP!
> > > > > > > > Erwin.
> > > > > > > > Related postings:
> > > > > > > > The response is:
> > > > > > > > > Please, try this:
Re: CDT Debugging [message #57603 is a reply to message #57579] Thu, 09 January 2003 16:00 Go to previous messageGo to next message
Log file attached. Erwin sent me his project w/ launch config. I created a
new project, imported his files ver batum and copied his launch file into my
C:\eclipse\workspace\.metadata\.plugins\org.eclipse.debug.co re\.launches
folder. I still have the same problem - none of the debug menu selections
are enabled.
Thank you for your patience.
news:avkeue$muj$1@rogue.oti.com...
> Mikhail
attached.
> "Step
> > enabled'?
directory.
the
> > > > objects = hello.o
> > > > hello : $(objects)
> > > > $(objects)
> > > > hello.cpp :
> > > > all :
> > > > ${MAKE} objects
> > > > .PHONY : clean
> > > > clean :
> '-o'
> > > and
> > debug
> > this
> > > > but
> > > > > Mikhail
> specified
> > > > > below.
> try
> > to
> > > > > debug
'Automatically
> > > load
> > > > > > shared
> I'll
> > > > check
> > > > > > it.
> > > > > > > Thanks,
> > > > > > > Mikhail
> > would
> > > > love
> > > > > > to
I'm
> > > sure
> > > > > > > someone
> > seen
> > > > > these
> > > > > > > > Michael
> > > > > > > > > Hi,
> > > > on
> use
> > > command
> > > > in
> > > > > > the
> > > > > executable
> > > > > > in
> > > > > > > a
"bin/dbc_ecs.exe"
> in
> > > the
> > > > > > C/C++
> configuration),
> > > and
> > > > > > even
the
> > bin
> > > > > > project
> and
> > > > > > > apparently
> > > 2.0.x.
> > > > I
> > > > > > get
> > > > > > > > > MI debugger: gdb
> > command.
> > > > > > > > > Continue?"
> > > > > > > > > Log file info:
NL=en_GB
> x86 -install
12:20:38.387
> > > > > > > > > !STACK 1
> > > loaded.
> > > > > Use
> > > > > > > the
> > > > > > > > > "file" command.
> > > > > > > > > at
> > > > > > > > > at
> > > > > > > > > at
> > > > > > > > > at
> > > > > > > > on.java:144)
> > > > > > > > > at
> > > > > > > > > at
> > > > > > > > .java:95)
> > > 12:20:38.417
command.
> straight
> > > in
> > > > > > > cygwin,
> > > > > > > > > HEEELP!
> > > > > > > > > Erwin.
> > > > > > > > > Related postings:
> > > > > > > > > The response is:
\n"
> > > > > > > > > > Please, try this:
  • Attachment: .log
    (Size: 1.64KB, Downloaded 257 times)
Re: CDT Debugging [message #57630 is a reply to message #57603] Thu, 09 January 2003 18:37 Go to previous messageGo to next message
It looks like gdb dies. Can you check if it is running or not when you get
this error?
news:avkn2h$sg8$1@rogue.oti.com...
a
my
> are enabled.
> > Thanks,
> > Mikhail
> attached.
> > "Step
> > > enabled'?
> directory.
> the
> > > > > objects = hello.o
> > > > > hello : $(objects)
> > > > > $(objects)
> > > > > hello.cpp :
> > > > > all :
> > > > > ${MAKE} objects
> > > > > .PHONY : clean
> > > > > clean :
> > '-o'
> > > > and
to
> > > debug
verify
> > > this
> > > > > but
> > > > > > Mikhail
> > specified
> > > > > > below.
and
> > try
> > > to
> > > > > > debug
> 'Automatically
> > > > load
> > > > > > > shared
and
> > I'll
> > > > > check
> > > > > > > it.
> > > > > > > > Thanks,
> > > > > > > > Mikhail
weeks -
> > > would
> > > > > love
> > > > > > > to
> I'm
> > > > sure
> > > > > > > > someone
not
> > > seen
> > > > > > these
> > > > > > > > > Michael
> > > > > > > > > > Hi,
> > > > > on
I
> > use
build
> > > > command
> > > > > in
> > > > > > > the
an
> > > > > > executable
> > > > > > > in
> > > > > > > > a
> "bin/dbc_ecs.exe"
> > in
> > > > the
> > > > > > > C/C++
> > configuration),
> > > > and
> > > > > > > even
> the
> > > bin
> > > > > > > project
debugging,
> > and
> > > > > > > > apparently
eclipse
> > > > 2.0.x.
> > > > > I
> > > > > > > get
> > > > > > > > > > MI debugger: gdb
> > > command.
> > > > > > > > > > Continue?"
> > > > > > > > > > Log file info:
> NL=en_GB
> > x86 -install
> 12:20:38.387
> > > > > > > > > > !STACK 1
is
> > > > loaded.
> > > > > > Use
> > > > > > > > the
> > > > > > > > > > "file" command.
> > > > > > > > > > at
> > > > > > > > > > at
> > > > > > > > > > at
> > > > > > > > > > at
> > > > > > > > > on.java:144)
> > > > > > > > > > at
> > > > > > > > > > at
> > > > > > > > > .java:95)
> > > > 12:20:38.417
> command.
> > straight
> > > > in
> > > > > > > > cygwin,
> > > > > > > > > > HEEELP!
> > > > > > > > > > Erwin.
> > > > > > > > > > Related postings:
> > > > > > > > > > The response is:
> \n"
message
> > > > > > > > > > > Please, try this:
Re: CDT Debugging [message #57702 is a reply to message #57630] Fri, 10 January 2003 09:00 Go to previous messageGo to next message
gdb only dies because I have to exit eclipse while gdb is still under
eclipse's control. Eclipse starts gdb fine, then gdb hits the breakpoint
and stops. Because all of the debug runtime menus are not enabled, there is
no way for me to tell gdb to continue. So, effectively eclipse is locked up
with gdb at the first breakpoint and I have to kill eclipse.
I attached a zip file with bitmaps of the applications and tasks running in
Task Manager when gdb hits the breakpoint. So, the Task Manager shows
everything thats running when the first breakpoint is hit, i.e., just before
I shutdown eclipse.
news:avl08i$3d5$1@rogue.oti.com...
> this error?
created
> a
into
> my
selections
> > are enabled.
directory.
> > > Thanks,
> > > Mikhail
> > attached.
Into",
> > > "Step
> > > > enabled'?
> > directory.
modified
> > the
> > > > > > objects = hello.o
> > > > > > hello : $(objects)
> > > > > > $(objects)
> > > > > > hello.cpp :
> > > > > > all :
> > > > > > ${MAKE} objects
> > > > > > .PHONY : clean
> > > > > > clean :
between
> > > '-o'
> > > > > and
trying
> to
> > > > debug
> verify
> > > > this
> > > > > > but
> > > > > > > Mikhail
> > > specified
> > > > > > > below.
> and
> > > try
> > > > to
> > > > > > > debug
> > 'Automatically
> > > > > load
> > > > > > > > shared
> and
> > > I'll
> > > > > > check
> > > > > > > > it.
> > > > > > > > > Thanks,
> > > > > > > > > Mikhail
> weeks -
> > > > would
> > > > > > love
> > > > > > > > to
environment.
> > I'm
> > > > > sure
> > > > > > > > > someone
> not
> > > > seen
> > > > > > > these
> > > > > > > > > > Michael
> > > > > > > > > > > Hi,
> > > > > > on
combination.
> I
> > > use
> build
> > > > > command
> > > > > > in
> > > > > > > > the
to
> an
> > > > > > > executable
> > > > > > > > in
> > > > > > > > > a
> > "bin/dbc_ecs.exe"
> > > in
> > > > > the
> > > > > > > > C/C++
> > > configuration),
> > > > > and
> > > > > > > > even
to
> > the
> > > > bin
> > > > > > > > project
> debugging,
> > > and
> > > > > > > > > apparently
> eclipse
> > > > > 2.0.x.
> > > > > > I
> > > > > > > > get
> > > > > > > > > > > MI debugger: gdb
"file"
> > > > command.
> > > > > > > > > > > Continue?"
> > > > > > > > > > > Log file info:
> > NL=en_GB
> > > x86 -install
> > 12:20:38.387
> > > > > > > > > > > !STACK 1
> is
> > > > > loaded.
> > > > > > > Use
> > > > > > > > > the
> > > > > > > > > > > "file" command.
> > > > > > > > > > > at
> > > > > > > > > > > at
> > > > > > > > > > > at
> > > > > > > > > > > at
> > > > > > > > > > on.java:144)
> > > > > > > > > > > at
> > > > > > > > > > > at
> > > > > > > > > > .java:95)
> > > > > 12:20:38.417
> > command.
> > > straight
> > > > > in
> > > > > > > > > cygwin,
> > > > > > > > > > > HEEELP!
> > > > > > > > > > > Erwin.
> > > > > > > > > > > Related postings:
> > > > > > > > > > > The response is:
command.
> > \n"
> message
> > > > > > > > > > > > Please, try this:
Enter
Re: CDT Debugging [message #57731 is a reply to message #57702] Fri, 10 January 2003 13:53 Go to previous messageGo to next message
Copy this file to your file system and start eclipse with
-debug "file:<path>\.options", where path is the directory of .options.
This sets the gdb/mi tracing on and you will the trace in the Windows
console. Please, copy the content of the console and send it to me.
Thank you,
Mikhail
news:avmir7$10n$1@rogue.oti.com...
is
up
in
before
> I shutdown eclipse.
get
> > this error?
> created
> > a
> into
> > my
> selections
> > > are enabled.
> directory.
> > > > Thanks,
> > > > Mikhail
> > > attached.
> Into",
> > > > "Step
not
> > > > > enabled'?
> > > directory.
> modified
> > > the
> > > > > > > objects = hello.o
> > > > > > > hello : $(objects)
> > > > > > > $(objects)
> > > > > > > hello.cpp :
> > > > > > > all :
> > > > > > > ${MAKE} objects
> > > > > > > .PHONY : clean
> > > > > > > clean :
> between
> > > > '-o'
> > > > > > and
> trying
> > to
> > > > > debug
> > verify
> > > > > this
> > > > > > > but
> > > > > > > > Mikhail
> > > > specified
> > > > > > > > below.
'-g'
> > and
> > > > try
> > > > > to
> > > > > > > > debug
> > > 'Automatically
> > > > > > load
> > > > > > > > > shared
project
> > and
> > > > I'll
> > > > > > > check
> > > > > > > > > it.
> > > > > > > > > > Thanks,
> > > > > > > > > > Mikhail
> > weeks -
> > > > > would
> > > > > > > love
> > > > > > > > > to
> environment.
> > > I'm
> > > > > > sure
> > > > > > > > > > someone
have
> > not
> > > > > seen
> > > > > > > > these
> > > > > > > > > > > Michael
> > > > > > > > > > > > Hi,
> > > > > > > on
> combination.
> > I
> > > > use
> > build
> > > > > > command
> > > > > > > in
> > > > > > > > > the
> to
> > an
> > > > > > > > executable
> > > > > > > > > in
> > > > > > > > > > a
> > > "bin/dbc_ecs.exe"
> > > > in
> > > > > > the
> > > > > > > > > C/C++
> > > > configuration),
> > > > > > and
> > > > > > > > > even
referring
> to
> > > the
> > > > > bin
> > > > > > > > > project
> > debugging,
> > > > and
> > > > > > > > > > apparently
> > eclipse
> > > > > > 2.0.x.
> > > > > > > I
> > > > > > > > > get
postings:
> > > > > > > > > > > > MI debugger: gdb
> "file"
> > > > > command.
> > > > > > > > > > > > Continue?"
> > > > > > > > > > > > Log file info:
> > > NL=en_GB
> > > > x86 -install
> > > 12:20:38.387
> > > > > > > > > > > > !STACK 1
table
> > is
> > > > > > loaded.
> > > > > > > > Use
> > > > > > > > > > the
> > > > > > > > > > > > "file" command.
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > > > > > > > on.java:144)
> > > > > > > > > > > > at
> > > > > > > > > > > > at
> > > > > > > > > > > .java:95)
2003
> > > > > > 12:20:38.417
> > > command.
below
> > > > straight
> > > > > > in
> > > > > > > > > > cygwin,
> > > > > > > > > > > > HEEELP!
> > > > > > > > > > > > Erwin.
> > > > > > > > > > > > Related postings:
> > > > > > > > > > > > The response is:
> command.
> > > \n"
> > message
> > > > > > > > > > > > > Please, try this:
> Enter
  • Attachment: .options
    (Size: 0.04KB, Downloaded 113 times)
Re: CDT Debugging [message #57758 is a reply to message #57731] Fri, 10 January 2003 15:47 Go to previous message
file attached
news:avn3vk$ekt$1@rogue.oti.com...
> Thank you,
> Mikhail
breakpoint
there
> is
locked
> up
> in
> before
> > I shutdown eclipse.
> get
> > > this error?
> > created
> > > a
> > into
> > > my
> > selections
> > > > are enabled.
> > directory.
> > > > > Thanks,
> > > > > Mikhail
> > > > attached.
> > Into",
> > > > > "Step
> not
> > > > > > enabled'?
> > > > directory.
> > modified
> > > > the
> > > > > > > > objects = hello.o
> > > > > > > > hello : $(objects)
> > > > > > > > $(objects)
> > > > > > > > hello.cpp :
> > > > > > > > all :
> > > > > > > > ${MAKE} objects
> > > > > > > > .PHONY : clean
> > > > > > > > clean :
> > between
> > > > > '-o'
> > > > > > > and
> > trying
> > > to
> > > > > > debug
should
> > > verify
> > > > > > this
> > > > > > > > but
> > > > > > > > > Mikhail
as
> > > > > specified
> > > > > > > > > below.
message
> '-g'
> > > and
> > > > > try
> > > > > > to
> > > > > > > > > debug
> > > > 'Automatically
> > > > > > > load
> > > > > > > > > > shared
> project
> > > and
> > > > > I'll
> > > > > > > > check
> > > > > > > > > > it.
> > > > > > > > > > > Thanks,
> > > > > > > > > > > Mikhail
> > > weeks -
> > > > > > would
> > > > > > > > love
> > > > > > > > > > to
> > environment.
> > > > I'm
> > > > > > > sure
> > > > > > > > > > > someone
> have
> > > not
> > > > > > seen
> > > > > > > > > these
> > > > > > > > > > > > Michael
> > > > > > > > > > > > > Hi,
> > > > > > > > on
> > combination.
> > > I
> > > > > use
the
> > > build
> > > > > > > command
> > > > > > > > in
> > > > > > > > > > the
makefile").
referring
> > to
> > > an
> > > > > > > > > executable
> > > > > > > > > > in
> > > > > > > > > > > a
> > > > "bin/dbc_ecs.exe"
> > > > > in
> > > > > > > the
> > > > > > > > > > C/C++
> > > > > configuration),
> > > > > > > and
> > > > > > > > > > even
> referring
> > to
> > > > the
> > > > > > bin
> > > > > > > > > > project
> > > debugging,
> > > > > and
> > > > > > > > > > > apparently
> > > eclipse
> > > > > > > 2.0.x.
> > > > > > > > I
> > > > > > > > > > get
> postings:
> > > > > > > > > > > > > MI debugger: gdb
> > "file"
> > > > > > command.
> > > > > > > > > > > > > Continue?"
> > > > > > > > > > > > > Log file info:
WS=win32,
> > > > NL=en_GB
> > > > > x86 -install
> > > > 12:20:38.387
> > > > > > > > > > > > > !STACK 1
> table
> > > is
> > > > > > > loaded.
> > > > > > > > > Use
> > > > > > > > > > > the
> > > > > > > > > > > > > "file" command.
> > > > > > > > > > > > > at
> > > > > > > > > > > > > at
> > > > > > > > > > > > > at
> > > > > > > > > > > > > at
> > > > > > > > > > > > on.java:144)
> > > > > > > > > > > > > at
> > > > > > > > > > > > > at
> > > > > > > > > > > > .java:95)
> 2003
> > > > > > > 12:20:38.417
"file"
> > > > command.
> below
> > > > > straight
> > > > > > > in
> > > > > > > > > > > cygwin,
> > > > > > > > > > > > > HEEELP!
> > > > > > > > > > > > > Erwin.
> > > > > > > > > > > > > Related postings:
> > > > > > > > > > > > > The response is:
> > command.
> > > > \n"
> > > message
> > > > > > > > > > > > > > Please, try this:
> > Enter
  • Attachment: debug.txt
    (Size: 1.93KB, Downloaded 310 times)
Previous Topic:C++ Make
Next Topic:Missing "C/C++ Development User's guide" in Help.
Current Time: Sat Jul 26 13:14:49 EDT 2025
Powered by FUDForum. Page generated in 0.07760 seconds
