Home » Eclipse Projects » Mylyn » web connector - how to specify common patterns as parameters
web connector - how to specify common patterns as parameters [message #56909] Wed, 27 August 2008 17:12
I have several queries that match a common date time string somewhere in the
pattern:
<td>[^0-9]*?[0-9][0-9][0-9][0-9]-[0-9][0-9]-[0-9][0-9]
[0-9][0-9]:[0-9][0-9]</td>
I tried to specify this pattern as a parameter then use a variable reference
in the Query Pattern of the query:
......${date_time}....
This did not return any rows.
Is there a way to define common pattern bits?
Michael
Previous Topic:How to contribute new Generic Web templates
Next Topic:When I can use connector that connects with bugzilla 3.2 or higher version.
Current Time: Thu Nov 20 19:24:57 EST 2025
Powered by FUDForum. Page generated in 0.03778 seconds
