Home » Newcomers » Newcomers » java 1.5 compliance
java 1.5 compliance [message #56896] Mon, 25 April 2005 11:05 Go to next message
Originally posted by: cookie.monster.somewhere.com
I have just install eclipse and started my first java project but have a
problem with java 1.5 syntax. Basically the IDE does not recognize the new
1.5 syntax. When I check the project settings the compiler compliance
allows 1.3 and 1.4 but no 1.5. What's going on? How can I get eclipse to
recognize my 1.5 java code??
I'm using the latest version from march 12th.
thanks!
cookie.
Re: java 1.5 compliance [message #56948 is a reply to message #56896] Mon, 25 April 2005 11:31 Go to previous messageGo to next message
You are using the 3.0.2 release of Eclipse which does not have the 1.5
support.
1.5 support has been added in the 3.1 stream of Eclipse. Try 3.1 M6
HTH
Darins
"Cookie Monster" <cookie.monster@somewhere.com> wrote in message
news:d4j14u$ilf$1@news.eclipse.org...
new
> thanks!
> cookie.
Re: java 1.5 compliance [message #57142 is a reply to message #56948] Mon, 25 April 2005 17:15 Go to previous messageGo to next message
Originally posted by: hendrik_maryns.despammed.com
Darin Swanson uitte de volgende tekst op 25/04/2005 17:31:
> support.
How can I upgrade from 3.0.2 without having to re-import all my
projects? It doesn't give any results if I do Help -> Search for
updates didn't give me the option to switch to 3.1.
TIA, H.
Hendrik Maryns
Interesting websites:
www.lieverleven.be (I cooperate)
www.eu04.com European Referendum Campaign
aouw.org The Art Of Urban Warfare
Re: java 1.5 compliance [message #57168 is a reply to message #57142] Mon, 25 April 2005 18:06 Go to previous messageGo to next message
Use the -data Eclipse option to point to your exsiting workspace.
Note your workspace will be upgraded for use with 3.1...you will not then be
able to go back and use this same workspace with 3.0.2
HTH
Darins
"Hendrik Maryns" <hendrik_maryns@despammed.com> wrote in message
news:d4jmqs$gt2$1@news.eclipse.org...
> > support.
> TIA, H.
> Hendrik Maryns
Re: java 1.5 compliance [message #57576 is a reply to message #57168] Tue, 26 April 2005 08:40 Go to previous messageGo to next message
Darin Swanson uitte de volgende tekst op 26/04/2005 0:06:
Thanks, but let me see if I get it right: I should download & install
3.1, then start it up from the command line with the option -data
$path-to-my-workspace?
Isn't there a clean and clear way, just some option to find inside my
current Eclipse? I guess no, ah well.
Cheers, H.
>>>support.
Hendrik Maryns
Re: java 1.5 compliance [message #57671 is a reply to message #57576] Tue, 26 April 2005 10:29 Go to previous message
Originally posted by: reply.group.com
Try, File--> Switch workspace.
news:d4ld15$gj0$1@news.eclipse.org...
>> be
> Thanks, but let me see if I get it right: I should download & install 3.1,
> Cheers, H.
>>>>support.
> Hendrik Maryns
Previous Topic:Axis web swervice example
Next Topic:creating a run-time version
Current Time: Tue Jul 22 01:48:53 EDT 2025
Powered by FUDForum. Page generated in 0.35035 seconds
