Home » Archived » XML Schema Definition (XSD) » Performance issues with loading xsds
Performance issues with loading xsds [message #56870] Tue, 04 January 2005 15:33 Go to next message
I am loading some very large XSDs using Eclipse just using the API and am
seeing that the schemas are taking a long time to load. I am calling
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.FALSE) since I don't need to track locations. I was wondering if
there was any other flag I could set that could speed things up
substantially.
The model that I am loading does not need to be manipulated in any way -
it's solely for read purposes only.
Hayden Marchant
Re: Performance issues with loading xsds [message #56898 is a reply to message #56870] Tue, 04 January 2005 16:53 Go to previous messageGo to next message
Hi Hayden,
"Hayden Marchant" <hayden.marchant@unicorn.com> wrote in message
news:creuj9$uj6$1@www.eclipse.org...
> I was wondering if
> substantially.
If you are parsing your model more than once, you should use the
XMLResource.OPTION_USE_PARSER option to specify a parser pool implementation
that caches instances of an XML parser for each subsequent parse. The
default implemenatation of parser pool is the
org.eclipse.emf.ecore.xmi.impl.XMLParserPoolImpl (default constructor is
available).
If your application only needs to read and query schemas, you might want to
look at the Xerces XML Schema API:
http://xml.apache.org/xerces2-j/faq-grammars.html#faq-5
Elena
Re: Performance issues with loading xsds [message #56925 is a reply to message #56898] Wed, 05 January 2005 03:04 Go to previous messageGo to next message
Elena,
The XML Parser is not the heavy part of the parsing - it is taking about
6% of the total CPU time. I was wondering if there was anything else I
could do about performance that could really help.
I'm sure that there must be a tiny little flag that I could set that might
save me :)
Elena Litani wrote:
> Hi Hayden,
>> I was wondering if
>> substantially.
> available).
> Elena
Re: Performance issues with loading xsds [message #57160 is a reply to message #56925] Tue, 18 January 2005 12:19 Go to previous message
--------------030506070305010403020103
Hayden,
No, there aren't any flags that will significantly boost performance.
But we do hope to have time to do some tuning in the 2.1 development cycle:
82613 <https://bugs.eclipse.org/bugs/show_bug.cgi?id=82613>
Hayden Marchant wrote:
> Elena,
> about 6% of the total CPU time. I was wondering if there was anything
> else I could do about performance that could really help.
> might save me :)
> Elena Litani wrote:
>> Hi Hayden,
>>> I was wondering if
>>> substantially.
>> implementation
>> available).
>>> way -
>> want to
>> Thanks,
>> Elena
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Hayden,<br>
<br>
Re: Performance issues with loading xsds [message #593491 is a reply to message #56870] Tue, 04 January 2005 16:53 Go to previous message
Hi Hayden,
> I was wondering if
> substantially.
available).
Elena
Re: Performance issues with loading xsds [message #593500 is a reply to message #56898] Wed, 05 January 2005 03:04 Go to previous message
Elena,
save me :)
Elena Litani wrote:
> Hi Hayden,
>> I was wondering if
>> substantially.
> available).
> Elena
Re: Performance issues with loading xsds [message #593613 is a reply to message #56925] Tue, 18 January 2005 12:19 Go to previous message
Hayden,
> Elena,
> might save me :)
> Elena Litani wrote:
>> Hi Hayden,
>>> I was wondering if
>>> substantially.
>> implementation
>> available).
>>> way -
>> want to
>> Thanks,
>> Elena
<html>
<head>
<title></title>
</head>
Hayden,<br>
<br>
Previous Topic:Create a simpleType from a DOM element
Next Topic:CPL license
Current Time: Mon Jul 21 21:12:45 EDT 2025
Powered by FUDForum. Page generated in 0.29010 seconds
