Home » Archived » M2M (model-to-model transformation) » [ATL] Is it possible to give parameters to an ATL transformation
[ATL] Is it possible to give parameters to an ATL transformation [message #56860] Thu, 09 August 2007 03:48 Go to next message
Originally posted by: tristan.faure.c-s.fr
Hi !
I have a question about ATL transformation. I have integrated my
transformation in an Eclipse plugin and i want to add some options for the
users.
I have two choices .... some asm files corresponding to options or doing a
process after the transformation directly in java.
And i wanted to know before starting if there is no possibility to give
some parameters to ATL ? For example booleans or values etc ... The goal
is to check the value of these parameters in the transformations
Re: [ATL] Is it possible to give parameters to an ATL transformation [message #56942 is a reply to message #56860] Thu, 09 August 2007 09:10 Go to previous messageGo to next message
Originally posted by: quentin.glineur.obeo.fr
Hi Tristan,
Yes it is possible to give some parameters to an ATL transformation. For
this point, I recommend you to read the wiki page:
http://wiki.eclipse.org/ATL_Howtos#How_do_I_use_extern_param eters_in_ATL_transformations.3F
Quentin GLINEUR
Tristan FAURE a écrit :
> Hi !
> the users.
> a process after the transformation directly in java.
Re: [ATL] Is it possible to give parameters to an ATL transformation [message #56964 is a reply to message #56942] Thu, 09 August 2007 09:34 Go to previous message
oops sorry ididn't notice
Thank you i will see that !
Previous Topic:uml2 profile in wsdl transformation
Next Topic:[ATL] Empty stack Exception
Current Time: Sat Jul 26 09:14:57 EDT 2025
Powered by FUDForum. Page generated in 0.04427 seconds
