Home » Eclipse Projects » Remote Application Platform (RAP) » CalendarWidget
CalendarWidget [message #56849] Sat, 03 November 2007 13:06 Go to next message
IŽm currently implementing a CalendarWidget.
IŽm using the JSCalendar-Widget
" http://www.dynarch.com/demos/jscalendar/doc/html/reference.h tml".
I got it working so far as the Widget is instantiated. The widget expects
a div-container, where to put the calendar in itŽs setup method.
But I dont know how to do this, is it possible to implement this and get
an id for the current block-element?
I would be very thankful for any hints.
I know the CustomWidgetTutorial already.
Greetings
Martin Dilger
Re: CalendarWidget [message #56902 is a reply to message #56849] Sat, 03 November 2007 14:52 Go to previous messageGo to next message
Hi again,
maybe the JSCalendar was not so a good choice, itŽs a stupid question,
because it was already mentioned in this group, but
there is a DateChooser-Widget in Qooxdoo, which is not delivered with the
Qooxdoo Rap uses.
Now it should be quite easy to set up the rap-environment for this (I
think;))
But I dont know where the Qooxdoo-Widgets are found, and how to integrate
them.
Is there anyone who has already gained some experience in this?
Thank you very much!
Martin Dilger
Re: CalendarWidget [message #57156 is a reply to message #56902] Sat, 03 November 2007 19:46 Go to previous message
Solved. I had the wrong Qooxdoo-Library here.
Greetings
Martin Dilger
Previous Topic:RAP and EclipseCon 2008
Next Topic:link to external page
Current Time: Thu Jul 24 04:17:25 EDT 2025
Powered by FUDForum. Page generated in 0.24329 seconds
