Home » Archived » EPF » Help to translate the EPF from English to Portuguese
Help to translate the EPF from English to Portuguese [message #56846] Thu, 07 May 2009 09:09 Go to next message
I want a help to translate the EPF from English to Portuguese, I'm using
the EPF 1.5.0.2 with JDK 1.5.0 and NLS. what am I doing wrong?
Nilton
Re: Help to translate the EPF from English to Portuguese [message #56873 is a reply to message #56846] Thu, 07 May 2009 13:31 Go to previous messageGo to next message
Hi Nilton,
You also added the locale_id to the command-line?
Best Regards,
Onno
Re: Help to translate the EPF from English to Portuguese [message #57107 is a reply to message #56873] Tue, 23 June 2009 11:16 Go to previous messageGo to next message
yes, but it did not work ... other suggestions?
Re: Help to translate the EPF from English to Portuguese [message #57133 is a reply to message #57107] Tue, 23 June 2009 18:20 Go to previous message
Are you talking about EPF tool ? what locale did you use in command prompt
NLS pack for EPF 1.5.x was released last week, so you may need to update
it.
Shilpa Toraskar
EPF Committer
Re: Help to translate the EPF from English to Portuguese [message #598680 is a reply to message #56846] Thu, 07 May 2009 13:31 Go to previous message
Hi Nilton,
Best Regards,
Onno
Re: Help to translate the EPF from English to Portuguese [message #598739 is a reply to message #56873] Tue, 23 June 2009 11:16 Go to previous message
Re: Help to translate the EPF from English to Portuguese [message #598745 is a reply to message #57107] Tue, 23 June 2009 18:20 Go to previous message
it.
Shilpa Toraskar
EPF Committer
Previous Topic:EPF Practices / Changing Templates
Next Topic:[EPF] RichTExtEditor sample
Current Time: Sun Aug 31 20:00:14 EDT 2025
Powered by FUDForum. Page generated in 0.06548 seconds
