GEF draw2D Tabbed Pane [message #56833] |
Tue, 21 January 2003 10:51  |
Originally posted by: truenoto.yahoo.com
Is there a Tabbed Pane widget for GEF Draw 2d? I can only find ScrollPane.
Re: GEF draw2D Tabbed Pane [message #57993 is a reply to message #56886] |
Fri, 24 January 2003 20:17   |
Eric,
I try creating a TabFolder for testing, and wrap it with a FigureCanvas.
But how can I setup the content of that FigureCanvas. If I call return
FigureCanvas.getContents(), it returns null;
<<<< my test code >>>>>>>>>>>>>>>>>>>>>
Display display = Display.getCurrent();
final Shell shell = new Shell (display);
final TabFolder tabFolder = new TabFolder (shell, SWT.BORDER);
for (int i=0; i<6; i++) {
TabItem item = new TabItem (tabFolder, SWT.NULL);
item.setText ("TabItem " + i);
org.eclipse.swt.widgets.Button button = new org.eclipse.swt.widgets.Button
(tabFolder, SWT.PUSH);
button.setText ("Page " + i);
item.setControl (button);
tabFolder.setSize (100, 100);
FigureCanvas fc = new FigureCanvas(tabFolder);
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:b0jqqq$n6b$1@rogue.oti.com...
> No, but could you use an SWT TabFolder? You could put a separate
LightweightSystem or FigureCanvas
> on each page.
> Eric
> Takumi Fujiwara wrote:
> > Hi,
ScrollPane.
> > Thanks
Re: GEF draw2D Tabbed Pane [message #58016 is a reply to message #57993] |
Sat, 25 January 2003 11:05   |
You have to call setContents(IFigure) on the FigureCanvas before you can get anything back from
getContents().
Eric
> Eric,
>>on each page.
>>Eric
>>>Hi,
> ScrollPane.
>>>Thanks
Re: GEF draw2D Tabbed Pane [message #58116 is a reply to message #58016] |
Sat, 25 January 2003 18:13   |
what can I pass in to setContents()of FigureCanvas ?
I can't get an IFigure from TabFolder
Thank you.
news:b0uber$lpg$1@rogue.oti.com...
> getContents().
> Eric
> > Eric,
> >>on each page.
> >>Eric
> >>>Hi,
> > ScrollPane.
> >>>Thanks
Re: GEF draw2D Tabbed Pane [message #58165 is a reply to message #58116] |
Sat, 25 January 2003 21:15   |
I'm sorry. I misunderstood you. Originally, I suggested you create a TabFolder and put a
FigureCanvas on each separate tab...
Shell shell = new Shell();
FigureCanvas[] fc = new FigureCanvas[6];
TabFolder tabFolder = new TabFolder(shell, SWT.BORDER);
TabItem item = new TabItem(tabFolder, SWT.NONE);
item.setText("TabItem " + i);
fc[i] = new FigureCanvas(tabFolder);
fc[i].setContents(new Figure());
item.setControl(fc[i]);
Now you have an array of FigureCanvases to manipulate.
Eric
> Thank you.
>>getContents().
>>Eric
>>>Eric,
>>>>on each page.
>>>>Eric
>>>>>Hi,
>>>ScrollPane.
>>>>>Thanks
Re: GEF draw2D Tabbed Pane [message #58240 is a reply to message #56833] |
Mon, 27 January 2003 09:22  |
Originally posted by: hudsonr.us.i_b_m.com
It sounds like you want a lightweight TabFolder for use withing your
diagram.
No such figure exists, but you should have no trouble composing a couple of
figures to create this behavior. I would use a row of Clickables inside a
Figure with a horizontal Toolbar layout. Place this figure in the NORTH
location of another Figure in a BorderLayout. Then create a figure in
StackLayout to host the pages, and place it in the CENTER location of the
borderlayout. when "action performed" happens on the clickable, use
setVisible() to switch the visible page.
"Takumi Fujiwara" <truenoto@yahoo.com> wrote in message
news:b0jp74$m3r$1@rogue.oti.com...
> Thanks
FUDForum. Page generated in 0.07650 seconds
