Home » Eclipse Projects » DTP » erroneous repeating row values in SQL Results view
erroneous repeating row values in SQL Results view [message #56748] Tue, 02 June 2009 08:48 Go to next message
When I perform a join on two tables (each table has ~3400 rows), a
number of rows are copiously repeated towards the end of the displayed
result set. For example, there will be 12 "John Smith" rows followed by
7 "John Doe" rows. I know that these rows really do not occur in
duplicate in the tables, I suspect something is wrong in the result set
processing.
The join statement is nothing crazy:
select app.id.cn,app.hr.hrnum from app.id join app.hr on app.id.empnum =
app.hr.hrnum
In the Data Management Preferences, I have set max row count and max
display row count both to 4000. It is as if the result view fills up the
empty rows at the end with duplicates from the result set. That is,
fills up all 4000 rows even though result set was some 3000 rows.
I am using a ganymede birt build from eclipse.org with these versions:
BIRT 2.3.2
DTP 1.6.2
Eclipse 3.4.2
EMF 2.4.2
Has anyone else also seen this behavior?
Thanks, chris
Re: erroneous repeating row values in SQL Results view [message #56829 is a reply to message #56748] Tue, 02 June 2009 13:47 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hi Chris...
The people who would typically respond to your question are on holiday at
the moment. Please be patient and I'm sure they'll respond when they get
back next week.
--Fitz
"Chris Giblin" <cgi@zurich.ibm.com> wrote in message
news:h0372v$96d$1@build.eclipse.org...
> When I perform a join on two tables (each table has ~3400 rows), a number
> of rows are copiously repeated towards the end of the displayed result
> set. For example, there will be 12 "John Smith" rows followed by 7 "John
> Doe" rows. I know that these rows really do not occur in duplicate in the
> tables, I suspect something is wrong in the result set processing.
> app.hr.hrnum
> empty rows at the end with duplicates from the result set. That is, fills
> BIRT 2.3.2
> DTP 1.6.2
> Eclipse 3.4.2
> EMF 2.4.2
> Thanks, chris
Re: erroneous repeating row values in SQL Results view [message #499647 is a reply to message #56748] Mon, 23 November 2009 10:38 Go to previous message
Hi Chris,
could you solve the problem in the mean time?
We are struggling right now with a problem that might be related to yours: Our Birt reports are filled up with duplicate rows when produced with the Birt web viewer. The local previews in Eclipse are fine.
Does anyone have an idea what might be the reason for this behavior?
Dominik
Re: erroneous repeating row values in SQL Results view [message #595914 is a reply to message #56748] Tue, 02 June 2009 13:47 Go to previous message
Hi Chris...
back next week.
--Fitz
> app.hr.hrnum
> BIRT 2.3.2
> DTP 1.6.2
> Eclipse 3.4.2
> EMF 2.4.2
> Thanks, chris
Re: erroneous repeating row values in SQL Results view [message #596839 is a reply to message #56748] Mon, 23 November 2009 10:38 Go to previous message
Hi Chris,
Dominik
Previous Topic:Is there an ODA datasource visualizer available?
Next Topic:Data Soruce Explorer, No tables, only Schemas visible
Current Time: Sun Jul 06 23:39:40 EDT 2025
Powered by FUDForum. Page generated in 0.05426 seconds
