Home » Archived » Visual Editor (VE) » VE and Application Look and Feel
VE and Application Look and Feel [message #56710] Sat, 21 August 2004 10:00 Go to next message
Originally posted by: Jeffrey_Mason.MSN.com
Can anyone tell me why the following will not change the look and feel on my
XP Workstation:
ImportBonds ste = new ImportBonds();
//JFrame.setDefaultLookAndFeelDecorated(true);
String lookAndFeel = null;
//lookAndFeel = "com.sun.java.swing.plaf.gtk.GTKLookAndFeel";
lookAndFeel = "com.sun.java.swing.plaf.motif.MotifLookAndFeel";
try {
UIManager.setLookAndFeel(lookAndFeel);
} catch (Exception e) { }
ste.show();
BoomerangThree
Re: VE and Application Look and Feel [message #56737 is a reply to message #56710] Sat, 21 August 2004 18:57 Go to previous message
Originally posted by: myersj.nospam.gmail.com
Are you using Run As->Java Bean or Run As->Java Application? When you
run as a Java Bean, the main method isn't executed. If you want the L&F
change to reflect in the VE, choose the L&F in the Visual Editor
preferences under the Java item.
- Jeff
> XP Workstation:
> public static void main(String[] args) {
> try {
> ste.show();
Re: VE and Application Look and Feel [message #597526 is a reply to message #56710] Sat, 21 August 2004 18:57 Go to previous message
- Jeff
> XP Workstation:
> try {
> ste.show();
Previous Topic:VE and Application Look and Feel
Next Topic:Cann't create Visual Class with VE
Current Time: Sun Jul 13 19:31:56 EDT 2025
Powered by FUDForum. Page generated in 0.04007 seconds
