Home » Archived » BIRT » BAM and EAI platform support?
BAM and EAI platform support? [message #5057] Fri, 21 January 2005 17:44 Go to next message
Originally posted by: asinha.vitria.com
I've been looking into various software suites that offer BI and reporting
to see if there are ways to integrate reporting into Integration Platforms.
e.g. The Reporting tools can be provided with hooks to probe the Business
Process Model (BPM) for its data objects and their schemas so that the
report designer does not have to duplicate the efforts of the BPM designer
while designing the reports. This would provide BAM capabilities to the
Integration model and the reporting would have Business Process Intelligence
built-in.
Are there any thought processes going on in this direction for the BIRT
project?
thanks,
Ayon
Re: BAM and EAI platform support? [message #5332 is a reply to message #5057] Sat, 22 January 2005 18:54 Go to previous messageGo to next message
Ayon,
BIRT may be great fit for your application. While Release 1 of BIRT won't
provide such integration out-of-the-box, others can certainly build on top
of BIRT to provide it. To see how, let's divide reporting into two steps:
design and execution. The design step is the one where BPM integration would
likely occur.
A BIRT design is an XML file that contains instructions for accessing a data
source, transforming the data (sorting, filtering, totals), and presenting
the results. It sounds like your application needs the ability to build a
query based on the BPM. Once the report developer has that data, he'd use
BIRT's features for identifying totals and formatting the results. The
result of this process would be a BIRT XML design file that the BIRT Report
Engine executes to produce your final report.
There are two ways that you can integrate BIRT with your BPM system at
design time.
First, you can develop a custom data set builder extension to the BIRT
designer. ("Data set" is BIRT's generic name for any kind of data source:
SQL query, stored procedure, SOAP message or whatever.) The builder could
leverage the meta-data information in the BPM. The custom builder would be
integrated with BIRT using the great extension features of Eclipse. The
result would be a custom data set that looks to BIRT just like any other
data set.
Suppose that the BPM system identifies that there is a Customer concept, and
that Orders are related to Customers. Suppose further that the BPM system
can provide descriptive information about customers, and about the fields
for a customer. A custom data set builder could display this information to
help the user understand the data, and use the relationships to help the
user choose the data of interest. The details, of course, are likely to
depend on the specific BPM system in question.
Second, you can develop a custom report designer that is tightly integrated
with the BPM system. Suppose that the system provides sufficient information
to generate a wide range of reports. Suppose further that the application
requires only a small set of formats, so that designs could be created
automatically. In this case, you can write an application that generates
BIRT designs directly from the BPM system. You can then directly execute
those designs in the BIRT report engine, or load them into the BIRT designer
for further refinement.
In either case, you'd leverage one of BIRT's key goals: the ability for
others to add application-specific functionality to BIRT.
- Paul
Paul Rogers
BIRT PMC
"Ayon Sinha" <asinha@vitria.com> wrote in message
news:css0k0$pns$1@www.eclipse.org...
> Platforms.
> Intelligence
> built-in.
> project?
> thanks,
> Ayon
Re: BAM and EAI platform support? [message #6074 is a reply to message #5332] Mon, 24 January 2005 20:06 Go to previous messageGo to next message
Thank Paul,
That sounds interesting. When would be a beta available for us to play with?
-Ayon
"Paul Rogers" <progers@actuate.com> wrote in message
news:csup3p$imv$1@www.eclipse.org...
> Ayon,
would
> likely occur.
data
Report
> design time.
> data set.
and
to
integrated
information
designer
> - Paul
> Paul Rogers
> BIRT PMC
> > Hi,
reporting
> > Platforms.
Business
designer
> > Intelligence
> > built-in.
> > project?
> > thanks,
> > Ayon
Re: BAM and EAI platform support? [message #6133 is a reply to message #6074] Wed, 26 January 2005 14:13 Go to previous message
Ayon,
We'll have a build no later than EclipseCon on 2/28. See the post under the
"Plan" topic for more details.
- Paul
Paul Rogers
BIRT PMC
news:ct4622$423$1@www.eclipse.org...
> Thank Paul,
> with?
> -Ayon
Previous Topic:Plan
Next Topic:Any concerns with XSL:FO performance/scalability?
Current Time: Thu Jul 24 03:40:37 EDT 2025
Powered by FUDForum. Page generated in 0.04100 seconds
