PDT not flexible enough for my PHP setup? [message #5055] |
Fri, 09 March 2007 11:55 |
Originally posted by: tonyf.europa.com
First of all, a big thanks to the PDT team for tackling this project! I'm
new to Eclipse and PDT, so I thought I would ask here before submitting any
bugs.
I have an unusual PHP setup. I run multiple versions of PHP, all stored
under C:\Program Files\php. I then use perl scripts to set up the
environment properly. So if I type "php5 something.php" in a DOS window, I
can run PHP5 with the right php.ini file, PEAR location, etc. From Apache,
the script is ph5-cgi and I have more scripts for PHP4 and PHP-GTk.
When Eclipse asks me for the PHP "executable", it doesn't let me select an
executable, just a directory--this, in itself, seems misleading. It should
ask for a PHP installation folder, if that's what you need.
But my PHP executable is in C:\Program Files\php\bin and it's called
php5.pl. Eclipse doesn't seem to have a way to override whatever PDT is
doing to set up the PHP environment. Am I missing something?
I have some unit tests that I can run in CLI mode--no Web server necessary.
If I try to run one of these, it complains about not being able to run the
debugger. I selected "Run As" -> "PHP Script", not "Debug As". Again, am I
experiencing a newbie problem or is there a bug here?
Finally, I have some unusual syntax in one of my PHP files. I use a stream
filter on the require_once line so that the invalid statements become valid
PHP code (think of this like being able to use the C pre-processor on PHP
files). Since I haven't verified that I can run *any* program, this is just
a speculative question: will Eclipse prevent me from running a program if
it thinks the program has errors?
A general question: has anyone adapted Eclipse/PHP to use the doxygen
documentation tool. I used to use PHPDoc, but doxygen seems to be far
superior, specially with the class diagrams it generates.
Thanks for any and all help!
Tony
FUDForum. Page generated in 0.03399 seconds
