Home » Modeling » OCL » OCL expression for return type
OCL expression for return type [message #56653] Sun, 25 May 2008 06:32 Go to next message
Hi all,
i've read the parts of OCL Specification that deals with the return type
of an Operation. IMHO, this section is a bit confusing, so i think i
didn't get it at all.
I have an Operation foo in class A, which should return the property
name of that class. Now, i want to add this as a constraint into my uml
model with value:
context core::A::foo:String() result = self.name
Does this mean the same as in-code:
class A{
String name;
String foo(){
return this.name;
Thx
-tm
Re: OCL expression for return type [message #56761 is a reply to message #56653] Mon, 26 May 2008 09:22 Go to previous message
Originally posted by: cdamus.zeligsoft.com
Hi, tm,
This is one of those points where the OCL and UML specifications don't
agree on the definition of operation bodies.
The OCL specification of an operation body condition constraint is:
context core::A::foo() : String
self.name
In UML, all constraints are required to be boolean-valued, which is why
UML requires the "result = " part that makes it look like a
post-condition constraint.
HTH,
Christian
On Sun, 2008-05-25 at 12:32 +0200, Timothy Marc wrote:
> Hi all,
> model with value:
> class A{
> String name;
> String foo(){
> return this.name;
> Thx
> -tm
Previous Topic:OCL dependency not being picked up.
Next Topic:Re: [OCL] AstNode - startPosition is a transient attribute
Current Time: Mon Sep 01 02:32:10 EDT 2025
Powered by FUDForum. Page generated in 0.04364 seconds
