Home » Language IDEs » PHP Development Tools (PDT) » incorrect xdebug launch url
incorrect xdebug launch url [message #56634] Wed, 03 October 2007 15:39 Go to next message
When I launch the xdebug remote debugger, notepad (!) pops up with the
error message:
"C:\Documents and Settings\Michael
Stillwell\http://ski.ms/simpletest/reservation.html?XDEBUG_S ESSION_START=ECLIPSE_DBGP&KEY=119143983189813"
not found. Would you like to create this file?
As one might imagine, the debugger does not work. If I enter the embedded
URL into a web browser, XDebug operates as normal.
I'm not using the "auto-generate" url function--I enter
http://ski.ms/simpletest/reservation.html into the URL field but I end up
with the error message described above.
Is there some way to fix this?
--M.
Re: incorrect xdebug launch url [message #56689 is a reply to message #56634] Wed, 03 October 2007 16:14 Go to previous messageGo to next message
Originally posted by: dkel50.hotnospmail.com
Which web browser have you configured eclipse to use ?. You could try
changing it to firefox and see if that helps.
Apart from that I have never seen it do anything like that before. I
make a request to an eclipse API to open the URL for me.
Dave Kelsey
> error message:
> embedded URL into a web browser, XDebug operates as normal.
> up with the error message described above.
> --M.
Re: incorrect xdebug launch url [message #56825 is a reply to message #56689] Thu, 04 October 2007 03:33 Go to previous messageGo to next message
Originally posted by: pdt.neveron.de
I think that is related to the Windows settings which programm is linked
to .html files.
I had the same problem that PDT opened my HTML-editor until i explicitly
told eclipse which browser it should use.
> Dave Kelsey
>> error message:
>> --M.
Re: incorrect xdebug launch url [message #56852 is a reply to message #56825] Thu, 04 October 2007 03:34 Go to previous messageGo to next message
make that .php files :)
> to .html files.
>> Dave Kelsey
>>> the error message:
>>> end up with the error message described above.
>>> --M.
Re: incorrect xdebug launch url [message #56879 is a reply to message #56825] Thu, 04 October 2007 06:22 Go to previous message
I though something like this might be the problem, but the "path" itself
was completely messed up (being prepended with my home directory).
However, as Dave suggested, I changed (Eclipse's) default browser to
Firefox, and tried launching the debugger again, and it worked.
Maybe there's some strange optimisation whereby the internal web browser
tries to read the file on the filesystem directly if it thinks it's
equivalent to the URL it's being asked to load??
Anyway, thanks for the help.
--M.
> to .html files.
>> Dave Kelsey
>>> error message:
>>> "C:Documents and SettingsMichael
Stillwellhttp://ski.ms/simpletest/reservation.html?XDEBUG_SE SSION_START=ECLIPSE_DBGP&KEY=119143983189813"
>>> --M.
Previous Topic:Zend Debugger and breakpoints
Next Topic:Source > Shift Right/Shift Left
Current Time: Sun Jul 27 04:26:06 EDT 2025
Powered by FUDForum. Page generated in 0.04046 seconds
