Home » Modeling » TMF (Xtext) » Using existing .uml file in textuell modell?
Using existing .uml file in textuell modell? [message #56624] Thu, 09 July 2009 07:17 Go to next message
I have a graphical representation of my business system including all
requried classes. Now I have to define a mapping between gui and
persistence attributes. I'd like to do this in a textuell modell.
Therefor I need the graphical modell as input of my textuell modell.
Is it possible to import the existing uml modell?
Re: Using existing .uml file in textuell modell? [message #56651 is a reply to message #56624] Thu, 09 July 2009 07:53 Go to previous messageGo to next message
Hi Michael,
do you want to migrate your existing graphical model to a textual model
or do you want to refer to elements in your graphical model from your
textual model?
I expect some conrete syntax like:
import 'path/to/uml/file.uml'
keyword Something refers ExistingClass ...
The grammar would look like:
grammar foo.bar with org.eclipse.xtext.common.Terminals
import 'http://ns.uri.of.uml.metamodel' as uml
generate mappingModel 'nsuri'
Model:
'keyword' name=ID 'refers' umlClass=[uml::Class]
This should work out of the box with Xtext if you use the default import
feature. It may be necessary to implement a scope provider to resolve
references properly.
Sebastian
Am 09.07.2009 13:17 Uhr, schrieb Michael Baedorf:
Re: Using existing .uml file in textuell modell? [message #56920 is a reply to message #56651] Fri, 10 July 2009 03:05 Go to previous messageGo to next message
Hi Sebastian,
I don't know what's easier... At the moment I only work with the graphical
modell and I don't know if and howto work on two different modells in
different modell slots. So it could be necessary to migrate the existing
modell, but I don't know...
Do you have any experience with such a situation?
Greetings,
Michael
Re: Using existing .uml file in textuell modell? [message #56972 is a reply to message #56920] Fri, 10 July 2009 04:19 Go to previous message
Hi Michael,
I don't think that I understood your usecase. Please decribe the input
models, their relationship and transformations and what you want to
achieve. Maybe it's easier to attach your workflow-file.
Sebastian
Am 10.07.2009 9:05 Uhr, schrieb Michael Baedorf:
> Hi Sebastian,
> graphical modell and I don't know if and howto work on two different
> modells in different modell slots. So it could be necessary to migrate
> the existing modell, but I don't know...
> Greetings,
> Michael
Previous Topic:Recipe framework gone?
Next Topic:[xtext] Serializing parsed DSL Model
Current Time: Tue Nov 18 22:33:51 EST 2025
Powered by FUDForum. Page generated in 0.04028 seconds
