Home » Eclipse Projects » Mylyn » Getting http connection issues mylyn+trac
Getting http connection issues mylyn+trac [message #56610] Mon, 25 August 2008 17:26 Go to next message
An eclipse mylyn client on my Mac is able to connect to the task
respository and synchronize wihtout any issues. However the same versions
of eclipse & mylyn on Windowx XP give "HTTP connection reset" errors and
fail to synchronize. The update attributes from server button also causes
the same error on win xp.
Can somebody tell me what might be wrong and how I can correct this issue.
PK
Re: Getting http connection issues mylyn+trac [message #56664 is a reply to message #56610] Mon, 25 August 2008 20:36 Go to previous messageGo to next message
Originally posted by: steffen.pingel.eclipse.org
If your network connection to the repository works otherwise on the XP
machine (e.g. from a browser) check if Eclipse/Mylyn is blocked in your
firewall settings or if you have a proxy configured in the Eclipse
preferences that may block the connection.
Steffen
> Hello,
> PK
Re: Getting http connection issues mylyn+trac [message #56718 is a reply to message #56664] Tue, 26 August 2008 08:57 Go to previous messageGo to next message
Steffen,
Thanks for replying. The mylyn trac connector is able to validate the
connection to the server fine. After I posted the original message, I
found out that I get http connection reset errors only when i am connected
via my wireless connection. Through a wired connection it works fine.
Any hints on why i might be getting http connection reset errors when
connected via wireless? I am connecting to a tracd daemon running on my
home server and trac is my mylyn task repository.
PK
Re: Getting http connection issues mylyn+trac [message #57350 is a reply to message #56718] Tue, 09 September 2008 13:18 Go to previous message
Are you using digest authentication? If so the errors might be related to
this bug:
214341: Large XML-RPC requests fail when using digest authentication and
tracd
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214341
Steffen
PK wrote:
> Steffen,
> PK
Re: Getting http connection issues mylyn+trac [message #592777 is a reply to message #56610] Mon, 25 August 2008 20:36 Go to previous message
Steffen
> Hello,
> PK
Re: Getting http connection issues mylyn+trac [message #592798 is a reply to message #56664] Tue, 26 August 2008 08:57 Go to previous message
Steffen,
PK
Re: Getting http connection issues mylyn+trac [message #593070 is a reply to message #56718] Tue, 09 September 2008 13:18 Go to previous message
this bug:
tracd
Steffen
PK wrote:
> Steffen,
> PK
Previous Topic:Mylin JIRA Connector problems against latest Mylin features
Next Topic:Generic Web Connector - how to query where {Owner} == some value?
Current Time: Thu Jul 17 23:15:30 EDT 2025
Powered by FUDForum. Page generated in 0.08004 seconds
