VE will not start properly with N20040819 and 1.0M2 [message #56604] |
Sat, 21 August 2004 07:45  |
Originally posted by: Jeffrey_Mason.MSN.com
When I attempt to open an existing project that was constructed with VE I
get the following error:
Launch mode run not supported for configuration type
org.eclipse.jem.proxy.LocalProxyLaunchConfigurationType
org.eclipse.core.runtime.CoreException: Launch mode run not supported for
configuration type org.eclipse.jem.proxy.LocalProxyLaunchConfigurationType
org.eclipse.debug.internal.core.LaunchConfigurationType.getD elegate(LaunchConfigurationType.java:221)
org.eclipse.debug.internal.core.LaunchConfiguration.getDeleg ate(LaunchConfiguration.java:360)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:514)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:150)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:481)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:292)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:224)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$CreateRegistry.run(JavaVisualEditorVMContro ller.java:164)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
It seems to be erratic. Anyone have any ideas?
BoomerangThree
FUDForum. Page generated in 0.05647 seconds
